Question about Sony VAIO Notebook
When I connect the power cord, sparks come out of my laptop. It's on its last legs and I have a new laptop, but if I can't get it to turn on then I can't back up everything to transport it to my new computer. I don't know if this is a sign that the computer is completely shot or if the information on it is still retrievable. Please help! Thank you.
  • 903 Answers
If your laptop is sparking when you plug the cord in, don't attempt to turn it on -- you could start a fire. You're better off giving up on the laptop, especially if you already have a new one.
However, if you need to get data off the old laptop, you can do so with a laptop hard drive adapter, as long as the hard drive hasn't been damaged. Laptop hard drive adapters aren't expensive, and you can get more information on them from this TechRepublic article:
http://articles.techrepublic.com.com/5100-10878_11-5160538.html
Posted on Jul 08, 2010
Testimonial: "freginold was very helpful, linking me to a detailed description of how to deal with the problem. Now I get to take apart a computer for the first time!"
Husky power cord reel won't retract
spring in cordreel is sprung. cord is probably on last leg. Go to vac replacement parts online store and order a new one.
Feb 04, 2013 | Vacuums
Earlier my laptop shut down with no warning even though the charger was all connected and plugged in. now even though the charger is plugged in everytime i try to turn it back on the needs to be charged...
This could be caused by several things, but try the obvious first. I just bought a brand new power supply, and in less than a week the customer called and said it stopped working. I suggested she take the cord from the old charger and try it - it worked - the brand new cord lasted less than a week. The other thing that could cause this is a bad connection on the end of the power supply, going into the computer. It could even be a bad power supply.The last thing I can think of is a bad battery that won't hold a charge.
Aug 12, 2010 | HP Pavilion dv4000 Notebook
The terminal block that the power cord plugs into sparks
The part is called the terminal block and is part number 5304409888
It gets burned due to not being connected tight when the oven was installed or worked on last.
Replace the block and repair any burned wire ends. Make sure connections are tight and you will be good to go
May 07, 2010 | Frigidaire FEB27S5A Electric Single Oven
Power adapter isn't charging the battery when plugged in. Comp also won't stay on since the battery isn't charged and the power adapter isn't being recognized, even though it's plugged in. What do I do?
You need a new power cord. Walmart has a Universal one for about $78. This also happened to my laptop last week and I had to get a new one because it was shorting out. Even had sparks...
Jan 26, 2010 | Gateway 450SX4 Notebook
Can't get laptop to boot - power supply issue?
even AT 20% it should turn on Doubt it has anything to do with the power cord. Check that the battery is correctly seated in the housing and there is no corrosion evident.
Aug 12, 2009 | Computers & Internet
Hot leg of power supply cord melted
This is almost positively caused by a poor electrical connection. If the connections at the cord to the dryer are good and tight, check the receptacle that the cord plugs into. Turn the breaker off, remove cover or receptacle, and tighten all connections. If necessary, replace the dryer receptacle along with installing a new cord.
Dec 11, 2008 | Dryers
Gateway MX6453 or MA3
Because the power jack is soldered directly to the motherboard, side to side stress on the plug over time damages more than the solder joint, it also loosens the little copper sleeve that lines the hole in the motherboard. Simply resoldering the joint only cures the problem for a month or so. You must remove the plug, wrap and then solder a thin piece of wire clipped from a small resisitor lead to the base of the center pin connector leg (the one to the back of the jack) and pull through the board with the leg. Then the extra wire is bent over like a hook and coiled around the spot -- squashed flat. then the coiled extra wire acts as an added anchor when soldered (hooking the power jack connector to the board.) this joint will survive like or even better than new. Not doing this added step gaurantees you joint repair will fail not long after it is made.
Jul 23, 2008 | Computers & Internet
No power or lights on my inspiron 2650 laptop
First you need to test your adapter first not the power cord.Check that your adapter can give out according to the adapter spec..maybe 16-19ou V.If it does and still you laptop don't turn on then you have motherboard problem.
takecare.
May 05, 2008 | Dell Inspiron 2650 Notebook
Laptop wont turn on
when you take the battery out and unplug the power cord you can press and hold down the power button to reset the CMOS you also can on some toshiba models flip it over on the backside and press a pen in the "gold lined" screw hole.
hope that helps!
Jan 27, 2008 | Toshiba Computers>Laptops Satellite A10 PC...
Sony VAIO Notebook Logo
258 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
