Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Cannot program a remote with the codes that I have.Tv is a Philips-Magnavox. Model PR1398B102 Serial 80743475
    President:
  • 2,712 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 03, 2008
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    This thread has gone 14 days or more without a response.
    Please close the thread with a “FixYa” or “Helpful” rating.
    Or post back with latest developments, what steps you took,
    etc. and I will assist you further as best I can.
    Thank you.
    IrishDruid
I need to program a remote for a philips magnavox tv and need codes
Hello
Setup codes to check with Magnavox TV to Magnavox remote control are:
002 009 109
118 209 309 402 408
502 508 510 807 914 917
OK.
Nov 06, 2011 | Philips Magnavox Learning Universal Remote
I'm having problems programing my Philips RC19041006/01 remote that came with a Philips 15pf9936/37 15" LCD TV to work on a Magnavox MDV21001F7 DVD Player
Unfortunately, you will not be able to program your TV remote for the DVD Player. The MDV2100F7 was produced in 2010. Your Philips TV was has a manual with a copywrite date of 2003. Other documentation on the Philips site is from 2004 and 2006. (I am assuming that the MDV2100F7 is your model since no MDV21001F7 is listed at Magnavox or Funai (which made the unit).)
The codes in a universal remote control are only for devices released 6 months or more before the remote was programmed. A DVD player released 4 years later is likely to have a different set of control frequencies.
You need a newer remote or control everything with separate remotes. I wish that I had better news for you.
(The manual for the Philips TV is available from the Philips product site. For the Magnavox DVD player documentation, see the Magnavox (http://www.magnavox.com ) site or the Funai support site (http://www.funai.com/us ). At Funai, search for the model number but leave off the brand. They make units for a number of brands.)
Oct 04, 2011 | Philips Rc1904100601 Remote Control
I have one forall remote need codes for phillips magnavox tv so i can program my tv
Codes and manuals for most One For All remotes are available here: http://www.oneforall.com/support/manual . Select Universal Remote Control and then your specific model to download the manual as a PDF. Note: some of the English only manuals truncate before the code list which follows the Spanish translation for bilingual manuals.
For example the codes for the 8820N are CRT: Philips 1454, 0054, 0690, 1744, 1867 and Magnavox 1454, 1866, 0054, 0096, 0802, 1198, 1254, 1365, 1931, 1944, 1963, 1990
LCD: Magnavox 1866, 0802, 1198, 1365, 1990 and Philips 1454, 1744, 1867
Plasma: Magnavox 1866 and Philips 0690, 1744
Combination units have additional codes. Please note that if the remote is older than the TV, you may need a new remote. Codes are usually limited to those for devices released 6 months or more before the remote was programmed.
I hope this helps. If you can't find your model, please let me know and I'll try to find the code. Just provide your TV type (CRT, LCD, Plasma) and the remote model.
Mar 17, 2011 | Televison & Video
Need codes for a universal Philips Magnavox control for my insignia tv.
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
May 12, 2010 | Philips Magnavox Learning Universal Remote
Need the instructions and Code to Program universal remote control PHILIPS (Magnavox) and Magnavox TV.
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Feb 03, 2008 | Philips Magnavox Learning Universal Remote
REMOTE CONTROLLER MAGNAVOX MODEL CCU131ATO1 SERIAL 55233557
May I suggest doing a search on Google or Yahoo etc for "Magnavox remotes" or "Philips remotes" or try to find the contact number to Philips Consumer Electronics. Hope this helps
Dec 30, 2007 | Philips Magnavox 27MS343S 27" TV
Model MW C20T6 Serial # V08613170
the Magnavox TV codes for a phillips universal remote are:
MAGNAVOX 0807, 0002, 0502, 0247, 0919, 0224, 0430, 0402, 0408, 0109, 0715
Nov 18, 2007 | Philips Magnavox 27MS343S 27" TV
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
82 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
