Question about Sony Cyber-shot DSC-T100 Digital Camera
On my Sony cyber-shot camera its blinking E:62:11.. what does that mean
sharq
  • 15 Answers
SOURCE: Error code E:62:20 meaning
This appears to be a problem with a connector inside the camera. Try:
  • Take the memory card out, clean the bay and the memory card with compressed air
  • Take the battery out, clean it and the battery compartment with compressed air.
  • Some users report that you can 'fix' the problem by tapping it gently on the battery compartment, so that may be worth trying as well.
If these things don't work, it will have to taken to a service technician - it's quite expensive to repair, sadly.
Posted on Apr 14, 2008
SOURCE: Blinking notice on screen E:62:10
E:62:10 means one of the flat cables is loose that leads to the imaging module. Remove the battery and memory card. Remove the five screws and open the camera by lifting the front off. There will be a black plastic sheet lightly glued slightly to the tight of center. This covers two connectors for flat connectors. each has a tiny black hinged bar that can be popped uo with a small flat blade. Then slide the connecter as deep in the socket as possible. Snap the retaining bars back down and replace the black plastic insulator. Reassemble camera.
While you have the camera open canned air can be used to get any lint or dust out of the camera while it its open.
Posted on May 18, 2009
  • 65 Answers
SOURCE: My cyber shot DSC-T20 have a Error Code E:62:12
Press HOME> SETTINGS> MAIN SETTINGS> INITIALIZE> OK
Shake camera whilst it turns back on..may have to repeat a few times
The error E:62:12 is with sensor that tells to the camera in what position is it. (hor, ver..)
hope this helps you.
Posted on Aug 10, 2009
  • 58 Answers
SOURCE: I turn my Sony Cyber Shot camera and I get ACCESS
I'll forward a link to a page where you can view the information to troubleshoot this issue.
Please click on the link to view the troubleshooting steps and follow all the steps and check if that helps.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C267279&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=91362627&stateId=1%200%2091366820
Thank You!
Posted on Mar 31, 2010
SOURCE: I have a sony cyber-shot 1.3 mega pixels camera
Did you find the manual and disc you were looking for? I have them and might be able to help you buy making copies for you if you are interested. write me at barneysworld@zoominternet.net my name is barney I love that camera and use it everyday. I am finally looking to upgrade from 1.3 mp.... I paid $350.00 for that camera in 2001... can you believe what you can buy for $350.00 in cameras now??? I have had to buy 3 teenage daughters and their mom cameras in the mean time, I just got my 16 yr. old a Nikon 3000.... that stuff was expensive. Let me know about the manual, sincerely, ( I have kept it all these years for something , it must be for you.) I will help you if I can.
Posted on Jun 29, 2010
I have a sony 8.1 mega pixels super steady shot dsc-t100 .cyber-shot it got a e61 10 fault can u help
It means that a camera malfunction that you cannot reverse has occured.
You can try to press the reset button located inside the jack cover and then turn on the camera again.
May 22, 2011 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-Shot DSC-F828 Digital Camera won't flash
Make sure Flash Shoe option is Off in setup menu then check flash light.
Does camera give any blinking error code when flash fails to fire?
Does flash pop up when you press shutter button to take picture in low light?
Let me know to find out possible cause of problem.
Oct 13, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
Flash wont work helppppp
That usually means the flash is charging but if it continues, that usually means the battery is low or the battery contacts in the camera need cleaning.
Jan 30, 2010 | Sony Cyber-shot DSC-W190 Digital Camera
Mar 03, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
Flashing E62:12 on screen?
Check error still comes after RESET camera by going into camera Menu -> Initialize ->OK
E62:12 is error code means "Lens Overheating". Camera has "Angular Velocity Sensor" on its main board and that can be cause of problem. If still error blinks, contact Sony Service Center for proper fix as this will requires special tools.
Feb 25, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
New camera and I can not get out of "RECORDING" mode.
please see the manul and take still shot in photo mode.
Dec 16, 2008 | Sony Cyber-shot DSC-H2 Digital Camera
Troubleshooting
Its error code E:91:01 corresponds to fault or problem with Flash Circuit. Flash is not working in your camera.
Aug 10, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-shot DSC-F717 5.0 Megapixel
Hi Bella
That code means that the lens unit was unable to move from home position to switch on position.
These lens are extremely complex and I doubt if you could find someone able to repair the lens.
Therefore I suggest contacting Sony to find a accredited dealer to quote you on replacement of the lens.
My guess is it will cost half of what you originally paid for the camera.
Good luck.
Sep 06, 2006 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-shot  DSC-T100 Digital Camera Logo
487 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
