Question about Maytag Atlantis MDG6400AW Gas Dryer
Dryer produces heat, but clothes don't dry - Maytag Atlantis MDG6400AW Gas Dryer
  • 10,319 Answers
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Posted on Jul 08, 2010
docjohn174
  • 943 Answers
SOURCE: Kenmore 80's series dryer
HI thanks for the question. you said it took 3 or 4 hrs to dry a load. check the venting its cheap . clean all venting. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 11, 2008
dragonsthatk
  • 547 Answers
SOURCE: My Dryer has stop producing heat
hi mark it the heating coil in the back of the dryer
Posted on Feb 11, 2009
  • 686 Answers
SOURCE: dryer is not heating up
CHECK THERMAL FUSE ON BLOWER HOUSING IF OPEN (BLOWN) ALSO CHANGE HEATING ELEMENT THERMAL CUT-OFF (THERMAL FUSE) 309 DEGREES AND HIGH-LIMIT THERMOSTAT 250 DEGREES. GO TO www.repairclinic.com ENTER MODEL NUMBER AND LOOK FOR PARTS 2986 AND 2651 OR 2924. ALSO LOOK AT PART 2895. WHEN YU GET THERE SCROLL ALL THE WAY DOWN AND CLICK THE RED 100 AND LOOK FOR THESE PARTS ONE OR MORE IS YOUR PROBLEM GOOD LUCK
Posted on Apr 10, 2009
  • 1122 Answers
SOURCE: blowing cold air-no heat to dry clothing-how do i know it is the heating element that is bad?
you have to see if you see any broken wire on it,also there should be a fuse on the top left side of the heater box at might be bad,let me know what you find-mike
Posted on Apr 15, 2009
SOURCE: my dryer is not producing heat?
the thermostat may be broke or the heating element may have worn out.
Posted on Oct 17, 2009
Dryer won't dry clothes
Heating element faulty not giving as much heat as it should
Nov 14, 2015 | Dryers
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
Dryer is taking much longer to dry clothes than it once did. Took 3 hours to dry clothes last night and had an unusal odor. Dryer is 3 years old, the dryer vent is not clogged up.
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer that is clogged, or has restricted air flow, will not dry efficiently and will cause the heating circuits to OVERHEAT. This will eventually will lead to component failures and is the source of many fire hazards.
If you have any questions, please post back and let me know. I hope you find this information helpful.
FYI: There are no adjustments that can be made to any of the internal thermostats or heating element to make it run at a higher temperature. All these components have a fixed setting. If the dryer still produces heat, the heating element is working. If the dryer is clogged, however, the internal protection devices, such as the Hi-Limit Thermostat and Internal Bias Thermostat will shut the heating element off prematurely to prevent the dryer from overheating, and to prevent damage to the heating element. Eventually, the Thermal Cut-Out (TCO) or Thermal Fuse will trip and the dryer will not run.or produce heat.
Nov 03, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool dryer not heating
Check the heater element and the 2 thermal fuses for continuety
Mar 06, 2010 | Whirlpool LER4634J Electric Dryer
My dryer spins and heat just a little but not enough to dry any clothes
Need to change the heater filament. The heater filament has several portions to produce heat. As it ages, some portions are not producing heat anymore hence the total heat produced by an old filament can not put out as much as originally designed.
Jan 08, 2010 | Estate EED4300TQ Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer isn't getting as hot as it should, clothes take twice as long to dry
clean out your wall vent,dryer hose and lint trap that should do it,what happens if you have a clogged vent the dryer keeps the wet hot air in loner and it take twice as long to dry-mike
Apr 20, 2009 | Dryers
Gas dryer does not provide heat or air
If you don't have heat the timer will not advance in auto dry. The first thing to check is the glow bar ignitor part number 279311.
Mar 30, 2009 | Whirlpool LGV4634JQ Gas Dryer
Feb 10, 2009 | Whirlpool LER4634J Electric Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
149 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
