Question about Husqvarna Viking 1
Machine not receiving power
Machine has power plug to foot pedal, both plugged into wall and machine, however there is another plug receptical - are there suppose to be 2 cords?
thank you
  • 135 Answers
Yes, there is 2 cords.
Posted on Aug 19, 2010
The needle is not going up and down, the fabric is not feeding thru. The foot pedal is not working at all. How do I fix this?
Is it plugged in? (The foot pedal) Your machine may have power but in most setups the foot pedal is the master controller; since it controls motor speed everything mechanical is affected by whether it works or not.
Mar 06, 2016 | Sewing Machines
My machine comes on but the foot pedal does not work, what should I do?
First, check to see that the cord is plugged in fully and the socket you have it plugged into is also working. Then turn the pedal upside down and check that there isn't something that is preventing the pedal from pushing down all the way. If you are brave unplug it from the wall & sewing machine open the case (likely there are some screws) you may find that there is just dust keeping it from making proper contact. Failing all that check on ebay or with a dealer for a replacement foot pedal. You have to specify brands to keep any more specific. Replacing the foot pedal is potentially cheaper than replacing the whole machine.
Oct 12, 2014 | Sewing Machines
Viking 980 foot pedal not making contact with machine although machine has power.
It could be lint jammed into the jack the cord plugs into. Make sure the jack and plug are both clean and free of lint. It also could be a damaged cord. If a friend has a working Viking pedal try borrowing theirs to see if it works on your machine. If not, your machine might need service.
Sep 15, 2014 | Husqvarna Viking 1
My juki serger mo-634de suddenly stopped working. Lights on, wheels and parts move freely, even stitching seems to work if I turn it manually, but nothing happens when I push the pedal. No sound. ...
Hi, I have the exact same machine. it sounds like the wire from the foot pedal to the machine is broken. You would still get power from the wall to the machine to light the light, but no 'gas pedal'. You could maybe get an electrian to test the connection under the foot pedal and if the wire is damaged? or maybe the part that plugs in the machine is cracked or damaged?
Good luck! Annette
Jan 08, 2012 | Sewing Machines
I have no movement/power when pressing foot pedal. I checked and doesnt appear to be any thread issues. It is like the machine does not have power.
if the machine is plugged in the wall socket
then it's possible it could be the power cord & foot pedal have gone out
here's site that have sewing machine parts
sewingpartsonline.com
sewvacdoctor.com
whitesewingcenter.com
sewingpartsdirect.com
sewingsupplywarehouse.com
sewforless.com
Sep 12, 2011 | Singer 3116 Simple
I have a white quilter's sewing machine, model 1740. I cannot get the foot pedal to work. It only sews if I push the start/stop button on front of machine. How do I get the foot pedal to work?
Hi, follow the instruction below to troubleshoot the foot pedal
  • Unplug the machine plug and wall plug on the sewing machine.
  • Check the power cord for cracks, burns, or faulty contacts as this could be a possible reason for the foot control not working.
  • Open the foot control by using a knife or flat surface tool, such as a flathead screwdriver, to pry open the corner of the foot control.
  • Check the wires to see if they are disconnected; this can happen if the foot control drops to the ground. To check wires, remove the circuit board using a flat knife. Inspect the wires inside the foot control. You will see some wires that are soldered together. Check to see if there are any broken wires, as this could be the problem. If the wire is broken, clean the area to remove any debris or dirt. Remove a small amount of the insulation before soldering. Solder wires together.
  • When you are done, reassemble the foot control and make sure it's working again.
Dec 23, 2010 | Sewing Machines
I checked out my machine and everything seems to be intact. The machine is plugged in the machine's light is on but it's not getting any power from the foot pedal. I don't know what to do. Please...
If foot pedal alows you to control the speed of the machine. They do go bad occasionally. If your machine motor plugs into the foot pedal unplug it and try it in a wall outlet if able. This will tel you if the machine motor is good or bad. Plug a lamp with a regular bulb(incandesent not flourescent) into the foot pedal. As you press the pedal the bulb should get brighter. This will tell you if the pedal control is good. Be sure the lamp is in the on position
Thank you for contacting Fixya.com
Nov 22, 2009 | Kenmore Sewing Machines
There is power to the foot control but not to the machine to make it sew
If foot pedal alows you to control the speed of the machine. They do go bad occasionally. If your machine motor plugs into the foot pedal unplug it and try it in a wall outlet if able. This will tel you if the machine motor is good or bad. Plug a lamp with a regular bulb(incandesent not flourescent) into the foot pedal. As you press the pedal the bulb should get brighter. This will tell you if the pedal control is good. Be sure the lamp is in the on position. If this is helpful, Please leave Feedback.
Thanks, SnugglePants
Oct 21, 2009 | Sewing Machines
Sewing Machines Logo
44 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
