Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
Should I remove the filter when using it as a wet vac. I t does not seem to have much suction.
  • 10,865 Answers
Absolutely remove the filter for wet vac. Also, if your present filter got wet replace it as the pores are now clogged and you can't save it. J.
Posted on Jul 08, 2010
Hoover nano cyclonic shut off while in use/no suction when turned back on
That is more than likely the problem, NEVER put wet or even damp filters back into your vac
Oct 23, 2014 | Hoover Nano Cyclonic Compact Bagless...
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
My Craftsman wet/dry vac is not picking anything up. It seems have some suction...not as much as it used to. I just replaced the filter and that did not help. Any suggestions?
disconnect hose and check suction at vacuum port. if suction is poor ther turn off, lift lid, e stick coat hanger wire in port from the backside diverter. also, clean filter.
May 16, 2010 | Vacuums
Do I take the filter off when I am vacuuming up wet things?
If it's a paper filter, take it off. If it's a cloth filter that can be washed and dried, leave it on. Your machine will have a float to close off the suction when the tub needs emptying. Anyway, air from the tub only goes through the turbine, not through the motor itself, so you need not worry. It's good practice to run the vac dry for a few minutes after using it wet, just to make sure the turbine's dry.
Aug 15, 2009 | Craftsman 17026 Wet/Dry Vacuum
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Suction paower
First thing is to check all your hoses, and filters. Filters rob your vacuum of air flow which equals power.. I don't think that you have a clog so much as I am inclined to think that you have dirty filters. In a wet vac, you can rinse your filters out, but they will eventually need replaced. It's a good idea to have an extra filter around for such an instance.
Jan 19, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Automatic pump for 10 gal shop vac
first you have to remove the filter in the vac then at the bottom of the vac tyhere should be a cap you remove and screw a water hose on and run it out side then when the vac fills the water will run out put the main hose on the suction side
Mar 21, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Wet dry vac suction not woking
The wet and dry vaccuums should normally have the dust filter removed when used for wet work. If the filter was left in, it will certainly be clogged and useless. I would suggest trying the unit with no filter, just to check there is good suction. If there is, a replacement filter is required. If there is still little or no suction, then it is possible that there is a blockage within the impeller area somewhere. Wet dust/dirt tends to stick really well to the impeller blades, reducing their efficiency to point of almost no suction. I'm not sure if you can get that far into your unit, if you can, it would be worth using a stiff brush to remove and adhered debris.
Dec 17, 2007 | Vacuums
Shop Vac not working well
The only thing after the filter and bag is the motor. Do you have suction with the hose removed? If not then the hose is clogged. If you have some, then the motor is the problem.
Nov 18, 2007 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Wet vac has no suction
check for clogs in hose. maybee clogged filter, clean or replace.
Nov 09, 2007 | Pullman Holt EVAC II 15 Gallon Wet/Dry...
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
449 people viewed this question
Top Ridgid Vacuums Experts
ken skalski
Thomas Perkins
Thomas Perkins
Tim Hunt
Tim Hunt
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
