Question about Epson Stylus Color 600 InkJet Printer
Unable to use Epson Stylus Color 66 with Windows 7 x64. Using a cable parallel at printer to USB on new laptop. I found the correct driver at Windows Update site.
  • tolkq Jul 09, 2010
    Still unsolved
    President:
  • 1,070 Answers
Welcome to FixYa
Sir/Madom,
>Correctly Plug in Cable to Laptop a swell as Printer
>Correctly Plug in Power Code
>Properly Install Driver for your Printer
  • Here is Guides for Your Product Click here[download it]
  • You can download the latest software from here[Download and install XP driver]
  • How to install your printer software from the CD-ROM here
If the printer is plugged into an outlet on a power strip and won't turn on, try plugging the printer directly into a wall outlet. Also, make sure the outlet you're using isn't controlled by a timer or wall switch that could be making the outlet inactive...Still have Problem you may need to Send it for Service under warranty...
Now you are Solved.....I hope you got an idea...Thanks for Contacting FixYa...
Posted on Jul 09, 2010
  • 3 more comments
  • tolkq Jul 10, 2010
    MY CLUMSY TYPING 66 SHOULD BE 600.
  • shafi
    shafi Jul 10, 2010
    Here is Driver for your Model-Properly Install it Here
    Also Read this Frequently Troubles Here and Here
    You will surely Solved...Let me know result...Thanks for Using FixYa
  • tolkq Jul 11, 2010
    Still no luck. I downloaded the driver you suggested, but because
    "Add Printer" finds one in "Windows Update" I cannot find a way
    to insert the "Windows Update" (which are probably the same
    Interesting pieces taken from forums, etc.
    My old Epson Stylus Color 600 was working fine with Vista (and XP before that). Now it won't print - anything sent to the printer just sits in the queue saying "printing - error".
    another
    Published: January 11, 2010
    I have connected my printer via USB in Windows 7, but the hardware Wizard fails to install the built-in Windows 7 driver. What should I do? (Since then I believe Windows 7 has been updated to include his driver and mine in "Windows Update".
    Follow these steps:
    1. Click and select Devices and Printers.
    2. Right-click your printer and select Printer Properties.
    3. Click the Ports tab.
    4. Uncheck the box for the LPT1 port and select the
    appropriate USB port.
    Which sounds like a winner, but as described, there is no ports
    tab there. Also, what is an appropriate USB Port?
    Parallel ports LPT 1 Epson Stylus ...
    LPT 2 Epson Stylus ... (I was trying anything)
    My laptop has 4 USB ports listed as:
    File: print to file
    USB001: virtual printer port
    USB002: virtual printer port
    (Lexmark 2600 Series I have)
    Fax Lexmark Fax
    The OS says I cannot delete any of the ports (I think all)
    but has an add port button.
    I think my solution might be to clean up the parallel ports
    and somehow change USB002 to Epson Stylus Color
    Thank you for your time and effort.
  • shafi
    shafi Jul 12, 2010
    Windows XP/Window7 has built-in support for Epson Printer Product- Stylus Color 600.This product installs automatically without extra software.
    Try in Different PC...Sometimes there might be Error Occured when installation.
    Also Check this Link
    So Go to Device manager{Control panel > System and Security > Device Manager]....Uninstall Driver by Right Clicking OR Check there for your Hardware [Epson Product name]
    Also check if there is yellow icon[Yellow icon for Not detected Hardwares]
    If you cant find out Epson Product name in Device manager-Action> Scan for Hardware Change-Now it will Detect and Install it manually.....
    Hope this Helps...Still have trouble it might be Hardware Damage- Contact Manufacurer or Nearest Service centre....Keep Using...
  • tolkq Jul 13, 2010
    TIME OUT. Real problem Windows 7. Am writing this on old Dell Desktop XP. Thank for all your
    help. I would like to follow through with you, but will have to get back to you when I can. Tomorrow I
    will be searching the internet (Microsoft & Gateway) for lap top help.
  • 3,083 Answers
It sounds like it should be working. I searched around on the net, and found one thing that might apply to your situation. Read the first few paragraphs of this blog, and see if it helps:
http://www.epson.com/cgi-bin/Store/support/supAdvice.jsp?type=highlights&noteoid=86150
Hope this helps.
Posted on Jul 08, 2010
  • 1 more comment
  • tolkq Jul 08, 2010
    Answer tomorrow. I read the blog, seems no help. As I said,
    I found the correct driver in Windows Update.
    Printer in question is Epson Stylus 600.
    A while back on searching the net for an answer, I found this site.
    I am the last entry, curious22. Reading the forum led me to
    believe a solution was found, but I was unable to cipher what all
    was said.
    Sorry not as a hyperlink.
    http://www.tomshardware.com/forum/4022-6...
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
How can connect with computer?
plug in your usb or parallel cable from the printer to pc.. then install the driver.
Switch on the printer to see if the pc can able to detect .
May 30, 2010 | Epson Stylus Color 440 InkJet Printer
I have a EPSON stylus color 740. Unable to find software driver to download in my laptop window 7
Sorry to say that your printer is not having any compatible driver for windows 7 . You need to contact epson for getting any compatible driver so that it works with windows 7.
Hope this helps.
Mar 16, 2010 | Epson Stylus Color 740 InkJet Printer
Sir Is it possible to run an old 640 with the
Epson has not released a printer driver for Win 7 and this printer.
My best guess at this point is that Epson has chosen to stop any additional driver development for this model printer.
Don
Oct 27, 2009 | Epson Stylus Color 640 InkJet Printer
Need what type of printer cable to fix to the compaq laptop from Epson Stylus C86 so i can print from laptop
You can use USB or Parallel according to the user guide. Most laptops made recently wont have a parallel port and the cables are harder to find so I recommend USB.
Jul 29, 2009 | Epson Stylus C86 InkJet Printer
Problem printing from Dell Inspiron 1720 with Vista Home Premium to Epson Stylus Colour 1160 using Nikkai USB to Parallel Convertor. Cable supposed to be plug and play. Any pointers?
You pretty much said it when you mentioned "Other than buying the cable in the first place" I have never successfully used a USB to parallel converter cable on any system. My suggestion, asisde from getting a true USB printer, is a parallel port card
http://www.newegg.com/Product/Product.aspx?Item=N82E16839328010&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-PC+Cards/PCMCIA+Add-on+Cards-_-Syba-_-39328010
May 16, 2009 | Dell Computers & Internet
Connection problem with parallel to USB cable
Toriom,
Uninstalling the driver and reinstalling the driver is a veriable solution, please try it.
I'm surprised that Epson does not have an LA (Latin America) center.
Don
May 04, 2009 | Epson Stylus Color 480 InkJet Printer
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
Window vista
You first need to get a Parallel Printer to USB cable. Once you have that, in Vista, click add a printer, do the windows update, and Epson Stylus Color 1520 should appear. Now you need to make sure that the port being used is the Virtual USB Printing Port, for example USB001....and there you have it...
Jun 25, 2008 | Epson Stylus 1520 InkJet Color Printer
CX9400 Windows 98???
Unfortunately, Windows 95, 98, and Me are not supported with this printer.
Listed below are the system requirements for your printer.
Windows Requirements
- A Microsoft Windows compatible PC with an 800MHz processor (1GHz or faster processor recommended)
- Microsoft Windows 2000, Windows XP, Windows XP Professional x64 Edition, or Windows Vista
- 256MB RAM for Windows 2000, Windows XP, and Windows XP Professional x64 Edition (512MB recommended) - 512MB RAM for Windows Vista (1GB recommended)
- 300MB free hard disk space (550MB recommended)
- 4x or faster CD-ROM drive for installing the software
- A Windows-compliant USB port and shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
Macintosh Requirements
- An Apple Macintosh with a PowerPC or Intel processor
- Macintosh OS X 10.2.8, 10.3.9 to 10.4.x or later
- 256MB RAM (512MB recommended)
- A USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable may cause the Epson Stylus CX9400Fax Series to malfunction.
May 25, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus Color 600 InkJet Printer Logo
47 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
