Question about Akai LCT3701AD 37 in. LCD Television
When I turn on my Akai, I sometimes get a clear picture and then it fades out I still see what I'm watching but its faded out, the people on the tv look florescent
  • Akai Master
  • 5,103 Answers
This could be the backlight failing (most often the images will tend to go pink). If the TV is out of warranty, you can replace the backlight(s) yourself. lcdparts.net has many backlights but you need to match the length and width to the original. Next you need to open up the back of the TV and carefully remove the old backlight(s). The backlights are on the perimeter of the TV (laptop screens started with one but most TVs have several to maintain an even lighting of the image).) The removal takes some work and paying attention to how the original is put together. The backlights are often molded into the frame of the TV and a Dremel or other rotary tool is needed to get the backlight out. Google backlight replacement for videos, pictures and descriptions of the process.
I hope this helps.
Posted on Jul 08, 2010
My 55" lcd tv has a picture which is clear on the right and fades to black on the left. Which component do I need to replace???
Sounds like the backlight bulb on the left is out. May need to replace the bulb, but do all of them at the same time.
Nov 12, 2014 | Televison & Video
Sometimes pictures are too brigth or too dark also it just suddely fades away. it has to be dark in order to watch tv. i just cannot get right colors or a clear picture,
may be the channel reception is bad.try adjusting the colour,brightness and contrast levels if problem is not solved contact the customer care
Feb 13, 2011 | Zenith Z50PX2D 50 in. Plasma HDTV
Picture is not very clear and the color is faded and can not adjust it
This mite sound crazy but it is time to change the oil in your TV. Yes your TV has three seperate picture tubes on the inside of it. A red tube, blue tube, and green tube. Each one of thses tubes has a clear oil that the light shines through. Over time this oil gets cloudy and distorts the light thus dimming and fadeing your picture please have a tech change the oil in your tubes.
Nov 08, 2010 | Akai PT4250A 42" HDTV
Picture fading
YES, THE CRTS WILL START SHOWING THEIR SIGNS OF WEAR. TO REPLACE THEM IS MORE THAN YOU PAID FOR THE SET.
Mar 20, 2009 | Akai LCT2715 27 in. LCD Television
Picture failure
Do not have a clue without a model number and make. Are we to be fortune tellers here too?
Oct 04, 2007 | Televison & Video
Flashing in and out picture
This is crt base failure due to corrosion. That is why to wont get clear picture initially when you switched on in long interval period. Change crt base problem solved.
Sep 09, 2007 | Toshiba 27AF41 27" TV
RCA 32" TV - Model #32F531T - Faded to black
Isolate filament voltage from CRT,i.e. unplug Crt socket from pix tube.Measure filament voltage on CRT PCB.If present,suspect bad pix tube.If missing,solder any/all connects in filament circuit,meaning CRT board first then main PCB.
Aug 08, 2007 | RCA 32F531T 32" TV
Picture faded to black, came back, faded again and had stayed black.
It seems your set has a loose conection in the high voltage circuits,in fact by now it should have many loose conections in different areas like the power supply and the horizontal deflection circuits,if you are familiar with tv service you can use the information as the first step to take,some of the loose conections are hard to see even for the trained technician but the one giving you this problem should not be hard to see,if you are not too familiar with tv service be safe and call for assistance from a servicer a least for an estimate.
Oct 11, 2006 | Mitsubishi CS-40507 40" TV
Akai LCT3701AD 37 in. LCD Television Logo
122 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
