Question about Sony CMT-HPX9 CD Shelf System
Cmt-eh10 wont turn on
When try to turn the power on, the power indicator flashes and the system doesn't turn on. The manual says that this could be a problem with the speakers (short circuit or wrong speakers), blocked vent holes (which are clear), or a problem with the voltage selector (which this model doesn't have). I've checked these issues and everything appears to be fine.
5 Suggested Answers
bogue-engine
  • 24 Answers
SOURCE: I am trying to locate speaker connectors for the
Yes please gogto www.BogueEngineering.com
and you will find the special proprietary connectors for your system. All the big companies like Sony and Samsung will charge way too much for the cables and they only work with some systems but Bogue Engineering connectors and cables are universal so they work with all the systems at a fraction of the cost. Hope that helps! Thanks, Gary
Posted on Sep 08, 2010
gopakumarg43
  • 75169 Answers
SOURCE: Sont CMT-NEZ5 won't stay on, standby light blinks
Hello
I haven't the schematic diagram to your set at present. If you send the schematic you have with me now, I'll refer it and will give you further assistance. OK.
gopalan.gopakumar327@gmail.com
Posted on Jan 24, 2012
  • 6771 Answers
SOURCE: my sony cmt-nex3 has the standby light flashing, but when i press the on butto, it doesn't turn on
Check the back for speaker wire shorts, next! there may be a short in the audio output chip or surrounding parts in the stereo, this is more suited for a technician to sort out.
Posted on Jul 03, 2012
  • 6771 Answers
SOURCE: Sony CMT-GP5 subwoofer output very quiet
From the description the subwoofer is the problem, since the item is new return it to the place of purchase, this is a manufacture issue.
Posted on Aug 13, 2012
My sony cmt-nex3 has the standby light flashing, but when i press the on butto, it doesn't turn on
Jul 03, 2012 | Sony CMT-NEZ3 Shelf System
Flashing a dead nokia n97
Hi according to my experience your problem seems to the wrong selection of flash file.So, try to download it from here n97 or if this link doesn't works please use what you have download previously .There are many flash files with a higher version.Make sure that you should select the file of your correct phone type (RM-505 or 507).....Download the flash file what it is written on your phone.After you have done this please repeat the steps.Good luck
Jun 20, 2012 | Nokia Cell Phones
Samsung le40
Have you checked all the inputs to the television? It might be blinking because it doesn't see a signal. If all the inputs are secure try pressing the input select button on the remote. If that doesn't work it never hurts to try unplugging the power cord, waiting a minute, and plugging it back in.
Dec 18, 2011 | Samsung Televison & Video
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Sep 16, 2011 | Welding Tools
My Ps3 Wont Turn On It indicates on stand by mode(solid red light).i pressed the power button; it wont turn on and it doesnt work or even beeps. i also tried using the ps button on the contoller.same...
Hi Shiman,
Are you seeing any flashingred/yellow lights?
If so this is the red lighterror and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with allof the number crunching however they can get very hot and if they loseconnection the system will either freeze up or turn off and give you the redflashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and theywill fix it for you.
Bear in mind that for the PS3red flashing light error you will be waiting for about 4 weeks and itwill also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3Repair Guide to fix it and this will show you how to stop the heatbuild up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A CompleteReview Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Aug 13, 2011 | Sony Playstation 3 (PS3) Console
My nokia e63 shows "start-up failed contact
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 23E0000B72A30052D437FCB9F02CF8F2EA2E22CE
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
Reading PASUBTOC ...
SIMLOCK PA identifier:
[0] PA_SL2
[1] PA_SL
Waiting for USB device removal ...
Waiting for device boot up ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 20D18815
Jun 25, 2011 | Nokia E63 Cell Phone
I need operating instructions for a Sony CMT-EH10
You can download the operating instructions from the manufacturer's web site at
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CMTEH10
Jun 23, 2011 | Audio Players & Recorders
My JBL DSC 1000 receiver has stopped functioning. When I switch on, the power indicator turns orange, but when trying to operate, it turns to blue but other than that there is no response. No display, no...
We have ran into the exact same problem here, we are currently disassembling it and going to measure what the problem is. We know it has something to do with the powerboard... ill post some more later.
Rik Dollekamp
May 17, 2011 | JBL DSC 1000 Theater System
My Behringer fx600 multi effects pedal flashes rapidly when used with a power adaptor. this happens whether the pedal is turned on or not.
The LED is ALSO used as a battery condition indicator... this is probably indicating the battery is expired. The manual sure doesn't say much!
Apr 26, 2011 | Behringer Fx600 Multi-fx Digital Stereo...
Sony CMT-HPX9 CD Shelf System Logo
79 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
