Question about Adobe Premiere Pro CS5 for PC
Premiere sequence won't export
An "unknown error" occurs when I try to export my sequence through Media Encoder. I've tried removing empty frames, changing the resolution and format, everything! I have an HP laptop, and the footage in the sequence is in .mp4 format, and when it tries to export, in the preview screen most of the frames are green. Then, sometime while exporting, the "status" icon changes to the error icon. The error log reads "Encoding Failed. Unable to compile movie. unknown error."
2 Suggested Answers
  • 75 Answers
SOURCE: Rendering problem in Premiere Pro CS3
I would suggest u to reinstall the software. after this it should work
Posted on Jun 27, 2008
MAPI error message when import or export messages in Outlook Express
·You import mail from Outlook into Outlook Express, but you removed Outlook from your computer before you tried to import the mail into Outlook Express.
·You configure Outlook Express to be the default Simple Messaging application programming interface (MAPI) client.
·You import or export mail from Outlook Express, and you do not have Outlook installed on your computer.
To resolve this issue, try one of the following methods, as appropriate for your situation.
Method 1: If you want to use a special program you can use Outlook Express Fix Toolbox
Method 2: Change your MAPI Settings
Configure Outlook Express to not be the default Simple MAPI client before you import the mail items. To do this, follow these steps:
1.Restart your computer, and then start Outlook Express.
2.On theToolsmenu, clickOptions.
3.On theConnectiontab, clickChangeto open theInternet Propertiesdialog box.
4.On theProgramstab, click an e-mail application other than Outlook Express in theE-maillist. ClickApply, and then clickOK.
5.ClickOKagain to close theOptionsdialog box.
6.Exit Outlook Express, and then restart Outlook Express.
You can now import or export messages.
May 31, 2016 | ErrorExpert
Why do I have an Unknown error on Windows Live Mail?
It seems like you have linked to your Live Mail account.
If yes, try to delete/remove that account and then try retrieving the mails again.
Jul 22, 2014 | Microsoft Windows Live Mail
How do i fix my computer from crashing with adobe creative cloud primere pro when exporting?
hi a sudden turnoff of ur laptop with no error message or black screen like attached normally indicates overheating issue.specially that it is working for shorter period...if you notice a heat issue or loud fans..try to use external fans..or maybe using power saving mode may lower the CPU or gpu clock and reduces power and heat produced 5_22_2014_6_24_57_pm.jpg
May 19, 2014 | Computers & Internet
How to use adobe premiere pro 2
Adobe premiere pro is software for video producers that takes you from the start to completion of your video project. You will run into less conflict working with other video formats due to the "Native Editing Support" from "SD" to "HD" that is provided in this software. A convenience is that every workspace has a separate panel and when using multiple panels they can be docked where you want.
Please follow the below step.
Step 1: Open the premiere software and choose which project you will be working with, either a previous, recent or new project. No need to change the default settings at this time.
Step 2: Go to the "Capture Format" menu and choose the type of format you want to capture, for example from the web or a dvd. (
Step 3: In the dialog box at the bottom give your project a name and determine the folder you are going to use to save your project. Before you click OK, select the "Scratch Disks" tab to create your own folder structure, this will make it easy when it comes time for you to move the media and archive. Now choose the folders you want to store the captured media you identified in step 2 and when you are ready, click "OK."
Step 4: Work with your sequences in the "Workspace Layout." This area is divided into sections, the top left and middle contain the project panel, source monitor and effect controls. The top right of the workspace contain the audio mixer and program monitor. The left lower section contains the media browser, info panel, effect panel, sequence and history panel. The bottom right panel contains the tracks, time-line, clips and audio meter.
Step 5: Edit your sequences using the "Timline Panel." Each sequence you add will appear as a tab within the "Timeline Panel." You are not limited to the amount of sequences you create or number of timelines you open.
Step 6: Create your video and audio using the "Tracks" feature. Each clip you add to the sequence needs to have a track identified. This is where you are adding sound to your sequences within your "Timeline Panels."
Step 7: Trim your clips using the "Source Monitor." Here you can add or remove a sequence by double clicking on the clip in the "Project Panel." You can then play back the clips in the sequence you assembled to view your project.
Step 8: Access the "Project Panel" and "Media Browser" for links to the different aspects of your video project when you need to add, change or remove sequences. When you are ready, go to the "Effects Panel" and begin setting the desired effects to the sequences you created.
Step 9: Open your "Tools Panel," which provide shortcuts on the keyboard for several of the functions mentioned in earlier steps. This is the beginning steps in using adobe premiere pro, to continue to the end of your video/media creating follow the prompts.
Thanking you
Jun 02, 2011 | Adobe Computers & Internet
What is Error Code 5100 please
I asked around and this error ..its also instruct you to turn off and on the printer is a warning for an obstruction in the printing process ...most of the times the obstruction having mechanical origins..So look around for sliding parts and in general parts that suppose to move in a certain pattern and now are blocked or not well lubricated or something is blocking them ..
May 13, 2010 | Canon PIXMA MP470 All-in-One Printer
''Jerky'' play on Adobe Premiere Pro CS4
Try maxing out your temp file storage from within the options in the program. Also does the file play jerky when compiled as a finished file. Using an external player. When the file is played or previewed from within the app it was created, with the GUI loaded and possibly the file not being saved, the amount of memory consumed is exponentially increased.
Mar 08, 2009 | Computers & Internet
Jun 26, 2008 | Adobe Photoshop 7.0 for PC
Making movies smaller
1. Convert video to *.avi (DV Format) 2. Use Adobe Premiere, convert to Quicktime, or Mpeg I or II, or Real Media. 3. or try Windows Media Encoder (Which is free.) 4. or MPEG4 encoding used for Sony's PSP. To make files smaller You can try 1. Reduce frame rate; 2. Reduce audio bit rate to 128 or 96kbps 3. Reduce frame size, e.g. 320x240 4. Use a mpeg4 encoder
Sep 15, 2005 | Sony Cyber-Shot DSC-M1 Digital Camera
Open Questions:
Adobe Premiere Pro CS5 for PC Logo
508 people viewed this question
Top Adobe Computers & Internet Experts
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
