Question about Science & Laboratory
Nikon Optiphot-2 Does anyone know where I could get a repair schematic for a Nikon Optiphot-2 microscope? Or maybe, better yet someone has dealt with one of these when the projector lamp won't light. The lamp is a quartz 100W 12V bulb. The bulb appears good, also the main fuse in the bottom of the unit. It appears that the 12 volts comes from a built-in 12 volt dc supply. I looked over the circuit board and found nothing obvious. Sure could use a schematic diagram...
  • 45 Answers
You should start by changing the bulb, even though it looks ok chances are that it's no longer working. Do the same with the fuse if the new bulb doesn't work.
Test that power is reaching the socket with a voltmeter or a multimeter so ensure the wiring is ok with the new fuse. If no power is reaching the bulb socket, then you will need to check the wiring every step of the way.
Posted on Apr 28, 2008
You can purchase a variable power supply that will light this lamp and control its intensity if you determine that the power supply in the microscope is bad. This may be the easiest way to fix the problem. Parts for many older microscopes are no longer available and this is a common way to repair the microscope. It's also a common modification made to many laboratory instruments for research purposes. Carefully check the lampsocket as well. It's common for them to fail and replacement is the only cure. The lamp socket is not expensive.
Posted on May 22, 2008
I have nikon microscope alphaphot2, YS2-H and I need complete PCB for power of lamp 6V 20W ! Please, informe me where can I order this board! My mail is:
try to find on ebay or on the manufacter support or with technicians who work repairing micorcopes.
this micro. is already considered obsolet \ not in production. i have one. so if it's yours and you know about engineering\electronics it would be better\easier fix it yourself making a new board or adapting other lamp.
i guess that my one the bulb is burn from i remenber and i'm thinking in adapt a led lamp. so add me in facebook that if i change my board i tell u how i do or maybe i could my original board if it's working
Mar 26, 2013 | Nikon Science & Laboratory
Pinion gear for raising & lowering condenser tray is broken need part #
In the Optiphot there are two small grub screws under the left hand side of the condenser column. Once loosened the metal housing of the pinion can by pulled or pushed out and the new one inserted. You may need a small mirror to see the screws due to their hidden position. You can then replace the pinion in which the black nylon gear will have broken
Jan 15, 2013 | Nikon Microscope Alphaphot-2 Ys2-t 4...
I need a manual for a nikon ys2-t microscope
this is the manual , the model is alphaphot 2 look at the picture in the page 4 . i have this same microscope and it have a label with ys2-t writed .
Jan 20, 2012 | Nikon Science & Laboratory
Remove collector and open base of Nikon Labophot
send an image of your microscope so that I maybe could help you,my email address
Feb 18, 2010 | Nikon Science & Laboratory
Nikon Optiphot stage is falling
This might be sign of trouble, because the Nylon gears inside might be worn out. I did not noticed a tension ring on Optiphot 1 or 2. The Nikon S and Metaphot from 1960s to 1976 have Nylon gears with tension ring adjustments.
Nov 25, 2008 | Nikon 7314 Binocular Microscope
Nikon Optiphot-2 microscope: tube length?
The Nikon Optiphot 2 tube length is 160 mm DIN finite. It is a 1990 vintage microscope. Any objective lens with the standard RMS thread, -160 engraved on it will work. It will not work with other brnads with the infinity symbol engraved on it or infinity tube length Nikon 200 mm, CFI60 objectives for 2000 vintage to present microscopes. - Lawsen Lew
Oct 22, 2008 | Nikon 7314 Binocular Microscope
Science & Laboratory Logo
1,088 people viewed this question
Top Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Science and Laboratory Expert? Answer questions, earn points and help others
