Question about Mtd Garden
Where can I find out how to hook up the wires properly to the Celiniod on a Huskee 5000ST lawn Tractor?
redbeard00
  • 957 Answers
SOURCE: Huskee drives weird
If the belt is fine and it isn't slipping at all then the problem would be inside the hydramatic trany. It isn't serviceable and would cost more then the tractor is worth.
Posted on May 24, 2009
  • 3 Answers
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Posted on Jul 18, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
SOURCE: I don't know how to change the drive belt on a MTD
Go to mtdproducts.com then click on PDF Web Archive then click on "Public Site" then type in your model and serial numbers then down load the online manual then all you have to do is scroll down to page 25 and you're in business.
Posted on Aug 16, 2010
Looking for a LT 4200 huskee manual
Operator Manuals
If you don't find it, give them a call.
Also, here is a link for parts manual online:
https://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/13w2775s031-lt4200-huskee-lawn-tractor-2013/
Apr 27, 2017 | Garden
Huskee Lawn Tractor Manuals LT 4600
http://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/13aj771g031-huskee-lawn-tractor-2009-tractor-supply/
Apr 19, 2017 | Garden
Replaces battery and spark plugs in my huskee lawn tractor it cranks over but won't fire has full tank of gas and battery is charged what could be the problem?
No spark? Check out ignition coil. Make sure the fuel is turned on if you have an on line hose switch for that.
Mar 28, 2017 | HP Garden
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
Trying to locate a 1997 huskee carburetor and inlet manifold
on the front of the engine under a cover should be a fuel line going to it may have to take the left fender of to get in there
Oct 31, 2013 | Huskee Tractor Replacement Riding Lawn...
Huskee drives weird
May 24, 2009 | Garden
50'' Huskee lawn tractor only turns in one direction
the brand huskee is now manufactured by MTD
Parts are available from tractor supply company at www.tractorsupply.com
there are pages of not very encouraging reviews about the huskee mower or about the tractor supply company but you can contact them to see what you can get
as for the problem , if it is a zero turn unit it may be a clutch arrangement needs adjustment
If you do not get any help from that company, you could ring around the mower repairs shops to get an idea as what could be wrong as the principle of operation will be the same .
also there are sites that have pdf versions of the workshop manual for huskee
May 20, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
108 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
