Question about Daewoo DWC-056CL Air Conditioner
Ac wont come on trip plug lights for 1 sec then goes out.
The plug has 2 test trip settings.unit comes up w light then immediately goes out, what can i do to get it on??
    Problem Solver:
  • 18 Answers
QUESTION?? WHY DAEWOO?? DID YOU EXPECT ANYTHING ELSE?
Posted on Jul 08, 2010
My unit does not go on. I press the on button and hear it then 10 sec pass hear it but it doesn't light and red light doesn't go on and then it shuts off
tep 1: Check the thermostat
  • Make sure that your thermostat is set to "cool" and not "heat" (if it's set to heat, your AC won't turn on no matter what).
  • urn the temperature setting 5 degrees below the current temperature to see if your AC will turn on.
  • No good? Then you need to...
tep 2: Check the air filter
  1. Find your return vent's filter (the return vent is where air gets sucked into the air conditioner).
  2. Check to see if the filter is dirty (if you can barely see light coming through it, it's too dirty).
  3. Change the filter if it's dirty.
    "Wait, why am I doing this?"
    A dirty air filter blocks air from returning to the AC, reducing airflow over the evaporator coil, causing it to ice up.
    This causes a low-pressure switch to trip and shut down your AC's compressor (the heart of your air conditioner) to prevent it from being damaged.
    So you need to change the air filter to prevent all that.
Sep 28, 2016 | Heating & Cooling
95 sl500 check engine light reset and comes back on after it sits over night. any idea?
What code is it throwing ? Some codes are what are called two trip codes ! You clear the codes an start an drive the vehicle ,no check engine light . Park the vehicle over night an bam next time you start an drive the vehicle the check engine light comes back on .
??There are two types of DTC's, 1 trip DTC's and 2
trip DTC's
??A 1 trip DTC is for a condition that requires
immediate attention such as a catalyst damaging
misfire.
??A 2 Trip DTC is one that a condition must be found
during 2 consecutive trips such as an EGR fault.
??Most Monitors do not set a DTC and light the MIL
when a vehicle fails a test for the first time during a
DRIVE CYCLE. If a test is failed on a second
consecutive DRIVE CYCLE the MIL will light and a
DTC is stored in the vehicles powertrain control
module (PCM).
Feb 07, 2016 | Cars & Trucks
Faa08759a frigidaire ac wont turn on
Have you cleaned the unit and its filter at all? Reset the unit and make sure the unit's breaker is not tripped.
Aug 26, 2012 | Heating & Cooling
Watkins vanguard spa will not heat
bad heater element if ok bad recirculation pump
Aug 21, 2017 | Pool & Spa
My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
Ok here's what you will do
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Tablets & eReaders
Model PinZ40, will not turn on, I unplugged it and plug it back up, it beeps, & lights up for a second, hear a click on the board, a red led light near the back of the board goes out. Will not do...
i would take the cover off the base and take note of the status of all the LED lights during the following actions.
1. remove the safety key.
2. Plug the unit in, note what happens. LEDs that light, do they stay lit.
3. if the unit does not trip off. insert the safety key.
4. note the lights again.
your unit probably has a short on one of the control boards, and is over-current tripping the unit off. that's the click you are hearing. Unplugging the unit probably resets this.
Since the motor should NOT be running during initial Power up. the problem is somewhere within the main power board or transformer.
if you have any electrical testing background you can use a clamp on amp meter to measure the current draw of the AC input lead, during power up.
if your current draw is greater than 10 amps (just guessing), then you DO have a short, and it's your circuit breaker that's keeping you from frying your boards.
if your current draw is low, I expect only 2 amps or so, you may have a faulty circuit breaker on your board, that is tripping at TOO low a current. Either way you may end up changing out your power board.
I realize i didn't give you any definite answers, but i hope it will get you started in the right direction. Anything to keep from hauling it to a repair guy!
Jan 26, 2010 | Keys Fitness Exercise & Fitness
SHR 1040 "Froze Up"
You can try holding down mode and channel 2 at
the same time for 10 secs. This should reboot the recorder.
Dec 23, 2007 | Samsung 4 Channel Dvr
Daewoo DWC-056CL Air Conditioner Logo
99 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
