Question about Miele S251 Flamenco II Bagged Canister Vacuum
Dead motor? My 8 year old Miele S251i has worked fine, until I was recently vacuuming and moved the plug from one outlet to another. When I restarted the vacuum, it made rrrrr.....rrrrrr....rrrrr noises and smelled like something was burning. I turned it off, and it's shown no signs of life since. Sound like a motor problem? I've taken the cover off and looked at the cord and seen the motor, nothing looks obviously wrong, but I'm also not mechanical.
SOURCE: power cord broken inside s251i miele How do i open the s251i ????
HOW TO OPEN MIELE 251 VACCUUM: 1-Unplug from wall and disconnect power cord 2-Remove black switch panel at back of top panel: A-Use Phillips screwdriver, remove two silver screws visible between back of hinged top door and front of black switch panel
B-Push back of the panel down while pushing it forward (towards front of machine). There are two plastic notches and clips which are tightly fit together that you need to separate.
Once it releases, push it a bit more towards the front of the machine and lift off panel. It has wires connecting it to the main body so it will not remove completely.
C-Be careful not to lose the springs that simply sit inside of two plastic channels, one under each of the two switches. These are required for your witches to operate properly.
3-Locate screw at bottom of deep rectangular hole now revealed (under former location of black switch panels). Unscrew using Phillips screwdriver. 4-Open hinged top panel. Locate two silver screws, one on each side of main housing. Unscrew using Phillips screwdriver. 5-This will let you lift off the whole top assembly, door and main housing, revealing the plastic chassis and the motor unit within.
You now have access to the motor, wiring connector harnesses, circuit board and the cord reel.
Posted on Dec 11, 2008
SOURCE: How do I take my Miele S251i apart to be able to chenge the powercord?
ukvacfan
  • 328 Answers
SOURCE: meile s251i won't turn on
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Posted on Mar 27, 2009
  • 78 Answers
SOURCE: Miele s251i vacuum plus-red light indicator is on.
you will need to take the unit apart find the screws that hold the unit together 2 under the the bin cover at the hinges 1 holding the black control cover when you have removed the screw then just lift the cover it will be stiff just pull it up under this find all the screws and remove them remove the motor and you will see the pcb on the side of the motor it will have a dry joint on the solder this back up and that should do it make sure you unplug the unit b4 you work on it
Posted on Oct 30, 2009
yeroc
  • 397 Answers
SOURCE: The Miele S251i just stopped working. Is there an
How long has unit been down? There is a inline fuse by motor housing internally in unit, but sometimes these units take awhile for them to reset
Posted on Dec 03, 2009
Miele S251i. While using,operator pulled on cord from another room. Vaccuum stopped.Touch of smoke at outlet.Prong slightly bent.Prong straigthened & plugged in, but still no power.No breaker tripped.
Power cords of portable appliances are vulnerable to internal damage, especially vacuums.
If the power outlet is still good and a different outlet has been tried it would be reasonable to suspect the power lead has an internal break.
The correct method of checking is to partially dismantle the appliance and use an ohmmeter to check for continuity. In practice, because a break is more likely to be near the end of the wire, cutting a couple of feet off and refitting the plug often works.
Apr 27, 2018 | Miele Vacuums
Cost to replace a motor on a miele s251i
Buy a new one. Motors cost almost as much as the unit.
May 03, 2014 | Miele S251i Plus Bagged Canister Vacuum
My circuit board has a short on the soldering for the DC rectifier that supplies the carpet cleaning motor. Where can I order a new circuit board. Miele S251i
Just a suggestion, but you could try to re-solder the connection on the board. some of the circuit boards did not have enough solder on the board coming from the factory.
That being said, if the component is damaged due to the burning, I suggest you contact your local Miele dealer and have them order you a circuit board for the unit.
IF the unit is less than 5 years old as well, that part should be covered under warranty. Do NOT solder it, just have them replace the part.
Good luck
Nov 19, 2010 | Miele S251i Plus Bagged Canister Vacuum
Stopped working while vacuuming...less than 2 years old???
Hi, It's probably the cord. I do wish Mieles were more durable given what they cost. I clean a home 3x per week with a Miele and tend to go further than i should before i unplug and find a closer outlet to plug into. So, it's the tugging on the cord that killed it. I had to take it to a Miele certified repair shop and they replaced the cord itself, which of course had a new plug on it. It was around 60 bucks. The owner didn't speak great English and I don't know Spanish so i'm unsure where the prob was: the spot where the cord attached to the vac, or the plug. In any case, I don't tug on the vac anymore....owner's were unhappy. Lesson learned.
May 14, 2010 | Miele S251i Plus Bagged Canister Vacuum
Miele vacuum powerhead
My power head failed due to the handle switch. It comes apart with the Phillips screw under the vacuum kill slider. Check for continuity across the switch contact solder points.
Mar 01, 2010 | Miele S251i Plus Bagged Canister Vacuum
Dec 03, 2009 | Miele S251i Plus Bagged Canister Vacuum
Meile s251i won't turn on
Mar 26, 2009 | Miele S251i Plus Bagged Canister Vacuum
I have a Miele s251i vacuum that was working just fine until I umplugged it (while running) and re-plugged it in at a closer socket. When I replugged it, it started for a second and then stopped. Will...
I just had exactly the same problem. Opened the vac, checked the circuit next to the motor and it can be clearly seen that the Triac burned thru the PCB. Will replace it and check again. Vac bought long ago, works extremely well.
Jul 29, 2008 | Miele Vacuums
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Will not turn on
Your problem is probably a bad male cord end or the there is a problem with the cord winder. It might need a spacer.
Aug 16, 2007 | Miele S251i Plus Bagged Canister Vacuum
Miele S251 Flamenco II Bagged Canister Vacuum Logo
109 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
