Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
My air conditioning has stopped working and i wonder if it has something to do with my emerson thermostat. the thermostat is reading ''system on +2''. the unit usually reads ''system on'. could this be an issue?
  • 99 Answers
“System On” indicates when heating or cooling stage is energized. “System On +2” indicates when a second stage is energized. This means that the thermostat is sending the correct signal to your AC equipment to run but your unit is not responding on the call of the thermostat, Most of the case this is a system issue not the thermostat, you need to contact your installer to resolve the problem.
Posted on Jul 09, 2010
Problem with AC thermostat
You are correct about the "er" message. Best bet is to check your user manual for error codes and then take it from there. If nothing in book it is possible that the answer might be on manufacturer web site.
Could be issue with thermostat itself if the other zone is being cooled properly.
Aug 05, 2016 | Heating & Cooling
Home air condition thermostat is blank. My home's central air condition stopped working. So the first thing I did was check the thermostat and it was blank. I then went down to the basement and got the...
Put new batteries in the thermostat. Make sure that the switch that power the furnace is in the "on" position. Sometimes people mistake that switch for a light switch and turn it off.
May 23, 2014 | Heating & Cooling
I have a Philips 615 DVD recorder that has worked wonderfully since I got it in 2005. However, this weekend it decided to stop reading any DVD put into the tray. I was recording something and finalized it....
Sometimes a blank DVD will not be the proper format. Upgrades have been done to DVD-R disks, and your recorder might not recognize the upgraded format on the newer disks. This has happened with Philips, Emerson machines- they all use a Funai burner. I have found with my FUNAI/Philips/Emerson recorder that purchasing the Philips, 1-16 speed DVD-R blank disks fixes this problem on my 2 machines. If you have an older DVD-RW 2 speed disk, it should work as well.
Jul 01, 2017 | Televison & Video
Space heater stops working after 2-3 minutes
The problem is most likely the over heating sensor thermostat located directly under the heating elements - The reason the over-heat safety thermostat sensor is tripping the warning buzzer is because either the cool air fan intake is obstructed with dust / dirt, or the fan motor stopped rotating, or the over-heating condition thermostat is defective, or over sensitive - Usually when the cool air intake is obstructed for any reason, the heating elements will glow brighter, and hotter without good air flow, and the elements may start to bow downwards closer to the over-heating safety thermostat - However, if the safety thermostat is defective, it can trigger the warning buzzer even though there may not be an over-heating condition / event present - The buzzer warning going off prematurely also occurred with my Holmes space heater - I checked the air flow first, and then the appliance tip-over switch second - Both were found functioning properly - It wasn't until I replaced the safety over-heating thermostat, did the buzzer stop going off moments after I plugged the space heater in an outlet.
Jan 05, 2014 | Holmes Products HRH316 Mid-Size Heater
My air conditioner blows warm air when stopped and idleing
Possible problems.
Air conditioner blows warm air?
Possible solution, system may need to be recharged.
You also wrote, temp light come on, gauge reads hot.
First check coolant level, always check this first.
Next, check your radiator hoses.
Next, have your thermostat checked, or change it. Their rather inexpensive.
Good luck.
Jun 20, 2012 | Air Conditioning and Heat for Pontiac...
Why won't my lg ductless heat pump regulate the room temperature?
After I have been reading up on your unit it appears that the thermostat is not operating correctly. I found this real basic information on installation for your unit. This link I am giving is pretty basic instal schematics. But seems to be something about your thermostat needs to be dialed in or is not working properly.
http://www.premsales.net/docs/GE/GE%20Minisplits.pdf
I hope this helps some. Mike
Oct 21, 2011 | GE Quiet-Aire Ductless Mini Split System...
Furnace cycles too frequently. Installed new wall thermostat,didn't stop problem. Furnace is installed horizontal in rafter space.
Systems are designed for a maximum of 6 cycles per hour. If you are experiencing more than that, you have leakage in your duct work or poor insulation or the system is too small for the area you are trying to heat. Some newer thermostats have an adjustment on them to allow you to set how many cycles per hour you want. Look in the instruction manual and adjust the DIP switches to your preference.
Mar 30, 2011 | Emerson Heating & Cooling
FR23SL Uses Peltier Cooling - No compressor nor freon....
Luzer - Thanks for the very helpful solution. My cooler has the problem described. When I take off the back and plug it back in, all three fans run, but the unit does not get cold. Is it possible that it needs new fans anyway (like maybe they are going but not moving enough air to generate the effect)? Or woudl it be something else?
Thanks!
Mar 25, 2010 | Emerson (025806803716) Wine Cooler
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
913 people viewed this question
Top White Rodgers Home Security Experts
Tom Chichester
Heatmeister99
Level 1 Expert
A Hoffman
A Hoffman
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
