Question about Poulan Pro Super Blowervacuum
No start/fire. Got spark, compression & fuel Poulan Pro blower
Will not start/fire. Got spark, compression and fuel. what else can I check
  • 6 Answers
SOURCE: poulan bvm pro 200 gas blower not getting gas
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
Posted on Nov 19, 2008
  • 15 Answers
SOURCE: Poulan Pro 200 Leaf Blower won't start. I have
Ok. Good job on doing what you could, right off! The simplest things are the most overlooked, and the most unforgiving.
So, you know your plug is wet, so you got some fuel flow.
Now let's figure out the plug no-fire problem. (This is under the assumption you haven't beat on this blower with a sledge-hammer at one point. The whole "key-way" is fried thing.)
1. Grab ahold of that plug THEN crank away. One time will tell you yes or no on spark. No, I am not joking, and yes, it is better than staring at the end of a plug and wondering if your eyes are bad.
In fact, better than a cup of coffee......in a bad way.
2. Check your kill switch. It is either: Grounding, or Open (open like it should be, UNTIL you push it, click it, or slide it, whatever you got). One CHEAP and fast way: Unhook the kill switch.
Then crank away. No spark? Not the kill switch then!
3. Check your spark plug GROUND. Let's say you got some shocking results from grabbing onto that bad boy. NOW check where the plug meets the cylinder head when she is screwed down in there. Believe it or not.....if it is funky, she won't ground right!
Hence, no worky.
4. You got no spark at all.....STILL. Let's look over your Spark Plug WIRE. Is she wore through? Is SHE grounding out? Has she heat failed? Then do #5.
5. STILL no spark. Let's check the last 2 things......
Rotor Magnets, and Magneto (ignition coil).
IF you have a volt/multi-meter, hook her up to the plug wire. No juice = Bad Magneto, or Bad Plug Wire. SOME juice = Good Magneto, but Bad Plug Wire (in some mowers/weedeaters, etc., remember that the Magneto is where the kill switch hooks too.
See if it is somehow grounding you out, by being loose but still touching the cylinder, etc.)
6. Failing Magneto. This can happen, and it does. You get SOME juice, just not ENOUGH juice. 2-Strokes make a lot of heat, even Magneto's give up the ghost after a while, sometimes. In this case, find a replacement!
Posted on May 30, 2009
  • 15 Answers
Alright, remember that 2-Stroke motors are meant to do 2 things:
Break down, then Frustrate you.
So, here we go: (Electrical)
Rotor Magnets, Magneto (ignition coil), Spark Plug Wire, Spark Plug, Spark Plug Ground (Cylinder Head).
In that order!
Check your "fire" from the Magneto:
1. Check your Kill Switch. In other words, leave everything normal, and unhook it. Did she start? Kill Switch it is! Kill Switch/Wire comes from the Magneto (single wire/ground) to the Switch itself. So check that wire AT the Magneto (Is it loose and grounding out? Is the Kill Switch grounding you out where it is, because of crud, junk, or because it is touching the block when it is not supposed to?)
2. Check your Spark Plug Wire. Easy, unook it from the plug, stick your finger in, give it a crank (non-MultiMeter way). Did you get shocked? Then it ain't your Plug Wire and Magneto!
With a Multi-/Volt Meter, simply hook her up, and check for juice WHEN you pull the rope. If you got juice, it ain't your Plug Wire or Magneto!
Checking Spark the "normal" way: Grab the Plug with a pair of insulated pliers, hold the plug end against the cylinder head, and pull your rope. Any Spark? What color?
3. STILL no fire. It leaves: Magneto and Plug Wire.
Luckily, they are both in the same place! Tear your blower down, and check to see if the Magneto has slipped out of place (gap is WAY out), or if the Plug Wire has worn to the point it is grounding you out. While you are there, check your Kill Switch wire, to see if she is grounding you out then and there.
4. STILL no fire. That means: Magneto Failing, or Magneto JUNK.
Buy another one, replace it! (Or steal one from another junk Blower/Weedeater. These things are fairly standard, and easy!)
Or, Bad Plug Wire. Meaning she has failed out on you.
Wait......that means: Replace your Magneto! Lucky the things are built together right?
  • 1129 Answers
SOURCE: have poulan pro gas blower,it is geting fire but
spray carb cleaner in the carb with throttle at full then hold the throttle wide open for three pulls, if it doeasn't start remove air cleaner and put a finger over the carb hole and have an assistant or yourself pull the cord this may clear out the debree blocking the flow of gas otherwise the carb must be removed cleaned and the vacuum diaphram replaced.
Posted on Jul 15, 2009
bulldogchief
  • 388 Answers
SOURCE: what type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Posted on Sep 11, 2009
I have a Poulan pro leaf blower. It will not start. I rebuilt the ZAMA carb, have spark and 40 lbs compression. Any ideas on where to go from here?
back to the carby for a check on what you have done
normally it is the diaphragms position or blocked jets
check the quality of fuel ( E-Mix fuels are not good for small engines and the oil you are using ---some engine oils block the jets )
Oct 31, 2015 | Poulan Garden
It is getting fuel but has a weak spark and will not start.
DO NOT , I repeat do not use starting fluid on a 2 stroke chainsaw or trimmer. you will score the cylinder or the piston. When trying to diagnose a hard to start motor just give it a small squirt of mix in the carburetor. If it won't fire you have a compression problem or an ignition problem. when you test for spark make sure you have a good plug, that is well grounded and not in bright sunlight which can make it hard to see the spark. if you have spark, do a compression test.
Mar 19, 2015 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Won't start
Starting problems with 2-cycle engines are usually traced to fuel line/filter clogging due to jelling of the fuel mixture while the engine is idle. Best fix is fuel mix pretreatment with some kind of gas saver in the gas can. Marine grade additives are the best, such as 2+4 gas treatment. Now your stuck with pulling the fuel lines and blowing them clean. If the carb has a primer bulb, you can sometimes force the fuel through, but a complete cleaning is in order. Pulling the plug and putting a few drops of fuel mix directly into the cylinder head, (or in the air intake), can sometimes get the motor to fire. This proofs the problem as being fuel starvation.
Jun 01, 2010 | Poulan Pro Gas BlowerVacuum ()
Won't start .is 70# compression enough. Spark and fuel ok. Took off carb and cleaned it. Doesn't even fire with small dose of starting fluid
70psi compression indicates it's rebuild time; the compression should be double that. You can confirm what the compression should be with good rings by putting a few drops of oil in the spark plug hole and testing compression "wet". That figure will be what a new saw would have.
May 20, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro won't start
1. You may have old gas in the tank.
2. Fuel mixture may not be quite right. Pour out and put new in it. Otherwise you may need to clean the carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Nov 29, 2009 | Poulan Featherlite Gas Blower, with Low...
Weedeater will not start. was running, shut it off and then will not crank. I have checked all the obvious(spark plug and wire, has good fire, fuel filter and lines,took apart carb and cleaned good) still...
Pull the spark plug after pushing the primer bulb and cranking a few times...if the plug is "wet" (indicating fuel is present in the cylinder) then the next step will be checking the compression...compression should read above 90psi (preferrably 100-125psi)...if compression is below 90psi, the most likely culprit will be a stuck piston ring.
Sep 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My Poulan Pro 200 model #200pbv200le will not start.Replaced the carb, fuel, fuel filter,plug. When I pull the cord sometimes I see a spark, sometimes- most of the time I don't see a spark.Replaced fuel
Check your compression...if it reads anything less than 100psi you need to tear it down and replace the piston ring. Looking for the spark is unreliable, get an in-line spark checker and check for spark. Loss of compression due to a stuck piston ring is very common in the pbv200 series.
Aug 31, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Blower will not start, will not fire
Doubtful. Clean the bolts and re-mount but I doubt that'll fix your problem. Check spark with an in-line spark checker. Be sure you have the right oil/gas mix...or you will burn it up. How did you check compression, what is the reading? Anything less than 100 means the piston ring is stuck.
Aug 15, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan Pro Super Blowervacuum Logo
337 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
