Question about GE Spacemaker JVM1640SJ Microwave Oven
I keep getting the F3 message, trying unplugging and plugging in, still does not work
  • GE Master
  • 9,047 Answers
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, and the keypad is available for your model as a separate part, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Please feel free to contact me directly with your full model number and we can tell you if yours is one of these models, and if so, we'll also give you the part number you need to order and a link to the best priced supplier.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on Jul 11, 2010
Frigidaire microwave f3 error
The keypad will likely need to be replaced, F3 indicates a stuck key. If you unplug it and plug it back in, does the F3 come back on by itself, if yes, then first, try unplugging it for a few minutes and see if it reappears.
If it does, the touch pad will need to be replaced. I can get you parts info after we see what power cycling it does.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Jose.
Oct 23, 2011 | Microwave Ovens
We are getting an F3 message on GE JVM1750DM microwave. After turning off power and then back on. It works for a few minutes, but then the F3 message come back ?
Hi
F3 error in your GE microwave means that the keypad/touchpad is bad and should be replaced. However, before replacing it you can follow these step by step instructions to clean the touchpad assembly and see if it works:
1) Unplug microwave
2) Remove two small screws from upper face plate
3) Remove screw on upper side of control panel
4) Life panel and pull out
5) Identify flat tape-like harness connecting circuit card to keypad
6) Wipe down harness with an all-purpose wipe
7) Use hairdryer to dry remaining leftover moisture
8) After this put the keypad back if its not solved then replace it.
Hope this helps...please post back for further assistance.
Daniel
Sep 05, 2011 | GE Microwave Ovens
Error message of "F3" appears
F3 or F4
Open or shorted oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Keep us updated.
Jul 10, 2011 | Hotpoint RVM1325WW Microwave Oven
Ge psacemaker microwave oven no working it started with a sensor error and the message change to F3 and beeping. I unplug and plug its still same error.Model JVM1750. What does F3 message stands for?
F3
Key panel (touch pad) shorted This code will occur if a shorted key panel is detected
continuously over 60 seconds. Replace key panel (also called touch
pad).
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't turn on code say's "F3"
The F3 error code for a GE microwave means the control is sensing a stuck or shorted key. Try pushing every button multiple times and do it firmly.
Hold a blowdryer in the corner of the keypad then slowly move it down as you peel it back (but not off). Take a sponge with the tiniest bit of dish soap and run it over both the sticky part (back of the circuits) and the place it is stuck to. Blowdry this til touchably dry and then reapply the kaypad face. Wait about 10 minutes until you plug in again for it to cool off.
If that doens't work, UNPLUG the unit and try to gain access to the electronic control board. If you can there may be a ribbon cable you can unplug from the board and try wiping the end of the cable hard between your thumb and index finger then wipe with a paper towel and reinsert the ribbon cable. May work but more than likely you will need to replace the touchpad.
Jun 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
When pluged in the exhaust fan runs all the time and the key pad does not respond to any touch controls. this happened after an electrical stom. no other appliances have been affected.
It sounds like you need a new keypad. Unplug the microwave and then plug it in again. if you get an F3 error message it will confirm the keypad is bad.
Oct 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Sensor Microwave model JES1456wf001 error code F3....how do we fix . Microwave comes on when plugged in and then reads to set clock and then it rings several times and we get an F3 code
F3 is a shorted key pad. To prove this, unplug the ribbon cable of the key pad from the control board and this symptom should go away when you plug the AC cord back into the wall. BE CAREFUL!!!
Sep 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a ge spacemaker xl1800 - f3 error
I had the same problem. I removed the grill and opened the control panel as I read an answer from "GENE" on APP (Appliance Pros) that this indicated a short in the circuit board (TouchPad). I was going to replace the faulty circuit board but when I opened the control panel there it was......One wire harness had just came unplugged!! I plugged it in, reassembled and the microwave works again!
Mike
Tampa, FL
Jan 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
78 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
