Question about Bosch Classixx WFL 2066 Front Load Washer
I think that the on off switch is not working properly on mine as it takes ages to switch it on (Have to keep pressing it). Where can I get a new switch from (I am in New Zealand but do not mind the shipping from somewhere as they should be only light)?
  • Bosch Expert
  • 414 Answers
When filling up with water it is leaking from the bottom
I think it may be leaking at the pump. Pull it out from the wall take the back off it and watch it go through a cycle
Feb 21, 2013 | Hoover 24 in. DT999 Free-Standing...
My Fuji HS10 keeps shutting down and rebooting during normal operation.
Your mention of very tight batt. compartment. Try new battery. Tightness in compartment is associated with bulging of the battery due to old age. Try this before anything else.
May 26, 2012 | Fuji Finepix Hs10
Kodak ESP 3250. Error 3527. I put new ink cartridges in.It started to pull the paper thru then stopped. I had to remove the paper buy pulling it back out. It says Printhead cartridge jam. Open printer...
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
Feb 02, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Keys #9, back key and * key are not working
Mine is doing the exact same thing, the 8, 9, # and * keys don't work, with the 5 going down the same route, have to press it so many times for the right letter! Can't find anything on the internet about a solution, just other people reporting the same problem. I've had to make do with copying and pasting the right letter into a text, takes ages. Think it's just excessive use on the buttons, but as a few other people have had this problem, it's obviously a fault with the phone.
Nov 30, 2010 | Sony Ericsson Walkman® W995 Cell Phone
My dell keyboard responds slowly to key presses. sometimes not at all! it takes ages to type email!
I think I finally figured this thing out. On mine it only seemed to happen when I was online. I thought that maybe there was just too much happening at the same time. Well turns out that there may have been. I turned off the gadgets that are on my sidebar on my desktop and voila! Works like a charm. Hope this helps
Oct 03, 2009 | Dell 0Y3740 Keyboard
My brake lights stay on even after car is shut off. I have to take out fuse to keep the battery from dieing please help
Need to adjust the brake light switch located under the dash, at the top of the brake pedal. You may need a partner when you adjust it, so they can let you know when the light goes off. Be sure to adjust it properly, so that the brake lights still come on when the brake pedal is pressed.
Jul 11, 2009 | 1990 Geo Prizm
Wont' turn on! Power button lodged?
It sounds like either the power switch itself or the connection between the switch and main board could be faulty. You would most likely need to have a service centre replace the power switch circuit to rectify the problem. Best of luck!
Feb 27, 2009 | Canon PowerShot S400 / IXUS 400 Digital...
I have a GE side by side refrigerator model # PSS26SGRD and the water and ice dispenser stops working without any warning or symptom intermintently. It will be working find for days or weeks and suddenly...
Well, the solution to this problem was posted in this thread
http://www.fixya.com/support/t1295372-ge_profile_ref_ice_despenser_motor_not
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
Good luck
Dec 07, 2008 | GE Profile¿ 26.5 Cu. Ft. Stainless...
OFF AND ON SWITCH DOES NOT WORK for Philips Philishave HQ7850
Hopefully you discovered it's not difficult to take the shaver apart--at least if it's like mine.
Two screws on the back hold it together--one visible, one under the flip trimmer. They have odd slots but can be undone with a small slot screwdriver, though I think the proper way is with a torxx.
Once you undo the screws, take off the metal clips that hold in the batteries and serve as the screw holes. The batteries can be flipped up carefully (so as not to break the copper wires to the motor).
If your problem is like mine, you'll see a clear plastic piece that has dislodged from under the rubber push switch. Place the round end so that it lays in the rubber dome and contacts the switch.
You can flip the batteries back down in their proper position at this point and test to see if the plastic part is seated properly.
Then simply put the metal clips back and replace the screws. Amazingly simple. Hope that helps.
Jul 26, 2008 | Philips Philishave HQ7850 Electric Shaver
Bosch Classixx WFL 2066 Front Load Washer Logo
7,141 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
