Question about HP Pavilion ze2000 Notebook
Hp ZE2000 laptop Don't turn on???
I had tryed to turn on my computor, with and without AC adapter and it don't turn on
  • Micropain Apr 26, 2008
    I had recieved another power cord to see if it was the power cord, so I had taken the laptop apart to see if there was something wrong with the inlet for the power cord, and had taken the replaceable part out with two screws to test it with a Multimeter and it showed it was OK power was going threw it, yet it did not power up the motherboard??
  • 45 Answers
It may be the ac connector but a Notebook has the Battery too...
borrow a fully charged Battery that fits your Laptop and with every thing else Removed insert the Full battery in your computer then Turn it on.
If it works u know it is the AC conecter that can be fixed with a Replacement.
otherwise Your Notebook needs to be serviced at a service center.
Posted on Jul 17, 2008
    Producer:
    Uploaded 30 video answers.
    Filmmaker:
    Uploaded 5 video answers.
  • 72 Answers
If the system runs with a fully charged battery it sounds like the tiny power pin has been damaged. It's a fragile component, EZ to damage by tugging or pulling on the power cord. It can be fixed if you are comfortable working on things like that. The part is usually under $10. Do a google on "replacement laptop power pins". If you do the work yourself take your time....take careful notes about what screws go where for reassembly. I've done a few and it's not that hard, just tedious and slow. When you get it repaired get a cable retention device to keep the power cord from damaging the power pin a second time.
Here's what I use. . .
Posted on Sep 22, 2008
    Guru:
  • 1,342 Answers
Others with the same problem. Seems to be an issue with this model.
More suggestions.
It's probably the ac connector.
Posted on Apr 20, 2008
My hp netbook wont turn on, what shoud i do?..
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement HP Mini 210 AC Adapter Cord 30Watt 19V 1.58A
Nov 05, 2012 | HP Mini 210-1030NR Netbook
Wont start up
Remove the battery and AC Adapter cord, and press and hold the power button for 30 seconds. Then, without replacing the battery try plugging in your AC Adapter to see if you get any love. If that doesn't work, remove the AC adapter, reset the board again, and this time hold the power button down as you plug in the AC Adapter cord. If you still don't get any lights, you could try removing your memory, reset the board, replace the memory, plug in the AC Adapter, and try one more time.
If all of this fails...you should take advice from experts,call at-http://www.vtechsquad.com
Sep 05, 2012 | Acer Aspire 7750G-6662 - Core i5 2.4 GHz -...
Hp laptop dv6000 won't start how to solve
I think you can try this step and see if it makes your laptop work.
1. Unplug the AC adapter and Remove the Battery
2. Press and Hold the Power Button for 30 secs. without the battery and ac adapter
3. Put it all back in and see if the machine will work.
If happened it doesn't work. Try this.
1. Turn off laptop, unplug laptop, and remove the battery.
2. Unscrew all panels on the back of the laptop.
3. Reseat RAM and Hard Drive.
4. Check if the power port is loosed.
If happens those steps don't work it could be with the Motherboard, CPU, Video Graphics or LCD itself that's having a problem.
Hope it helps somehow.
Apr 25, 2011 | Computers & Internet
Does the hp pavilion ze2000 have a build in wireless adapter
According to the hardware specifications for the HP Pavilion ZE2000, found on PCWorld.com, it does have built-in 802.11g wireless. You can look at the specification list here (look under the "Communications" area).
Mar 08, 2011 | HP Pavilion ze2000 Notebook
My HP PAillion ze2000 PC Notebook will not charge
I had this problem with my laptop and the way to solve it is.... guess!!
Get a new power cord!!
Dec 31, 2009 | HP Pavilion ze2000 Notebook
Sent e-mail
Any time I need a power cord I go to Ebay. Here is one for you.
http://cgi.ebay.com/AC-Adapter-for-HP-Pavilion-DV4000-ZE2000-ZE4900-ZT3000_W0QQitemZ330298334850QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item330298334850&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1307|301%3A1|293%3A1|294%3A50
Jan 30, 2009 | HP Pavilion ze2000 Notebook
My Laptop wont power on
Hi
Since your computer is not starting up at all its probably not a problem in the hard drive (where the files are stored) It is most likely a problem in the motherboard. Try removing the battery and ac then plug in the ac and try starting up, is the ac working? do you have a power light on the laptop that turns on when you plug in the ac adapter?\
If you don\t have a power light you need to get the ac adapter tested if the adapter is fine then most likely the issue is in the motherboard.
This seems to be a old problem and if you don\t need assistance in solving it. It would be great if you would share to the world how you fixed your problem so other users can benefit from your experience.
Thank you,
Ekse
Aug 02, 2008 | HP Pavilion dv6227cl Notebook
Hi. HP pavilion ZE2000 Turning off when i try to instal windwos xp
Unless you have a FRU manual for your model and you feel very comfortable taking your laptop I would avoid it and send it out for repair. If your laptop is restarting I would remove the CPU, clean and put thermal paste and put it back together. You can use canned air to clean many of the parts that you can see.
Sep 08, 2007 | HP Pavilion ze2000 Notebook
My pavilion ze2000 is turning off
Could be problem with the hard drive, could always f disk it to clear the hard drive then do a fresh install of windows xp.
HP Pavilion ze2000 Notebook Logo
326 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
