Motherboards
Problem for Motherboards
Generic problem for all Motherboards
No sound on A770M-A
By Lyubomir on Apr 18, 2008
I recently purchased an ECS A770M-A from www.newegg.com. When I built my computer and installed Windows XP, I started installing the drivers that came with my motherboard. When the sound driver was installing "Error 0001" popped up and said "Installation Failed". How can I fix the problem?
Comments:
Apr 19, 2008
- Thank you very much. I downloaded the sound driver again from the website and everything worked out fine.
Same Problem
Oct 11, 2008
-   I reinstalled the driver and still doesn't work. I have Windows XP with SP3, have tried reseting the CMOS with the jumper setting and downloading and installing the driver from the website, nothing works. Help please.-   nicorivas
Solution #1
posted on Apr 19, 2008
Somewhat Helpful)
map9966
Rank: Guru  Computer Components  Expert
Rating: 89%, 1945 votes
Hi Lyubomir, there are a few things I'd like you to check. It's always suggested to clear the cmos/bios after purchasing a new board. The Mfg, make changes in the bios & they do not clear the bios when they finish. So please reset your cmos/bios jumper pg. 9, in your manual. Boot system & enter bios. Go over your settings & change as needed. When you come to Plug & Play OS choose No. This allows the bios to place IRQ's instead of windows. Also make sure your Onboard AUDIO Function is set to, (Enabled). When fiished save & exit bios. Double check pg. 43 for information spec's for the HD audio driver.
Try installing sound software again. If it still fails or barks the same error message try installing through device manager & point windows to the correct driver folder & OS located on your ESC driver CD. If it still fails. Run windows update untill there are no updates left for software or hardware.
Your link to ECS for A770M-A PCB:1.x
Suggest you save this link in your favorites.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=844&CategoryID=-1&DetailName=Specification&MenuID=1&LanID=0
Please let me know how things work out!
Luck!
Mike
Was this helpful?
Yes
No
Popular Solutions for Motherboards
Questions and Unsolved Problems for Motherboards
Answer
compaq presario mother board, what should I replace it with
Answer
i need to get the get the three wires back together with the motherboard.
Answer
My computer was in sleep mode when a kitchen appliance caused the house earth leakage to trip.... (More)
Answer
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboards Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
