Question about Craftsman Garden
I have a Craftsman High Wheel trimmer that will start fine then run for a few seconds then stop. It's seems like a fuel problem but not sure. I changed the air filter but thats all. Any ideas
    President:
  • Craftsman Master
  • 1,545 Answers
Lots of things can go wrong with fuel delivery on these machines. carbon builds up[ in the engine and muffler system...ethanol laced fuel helps break down the sensitive carb parts and especially the fuel lines.
If you feel like it,open up the carb and take a look inside for any debris especially on the real fine mesh screen on the fuel pump side under the mylar diaghram. Check inside the fuel tank for a bad/dirty fuel filter and/or brittle fuel line...Fuel lines develop cracks and holes, thus leaking air and affecting the carbs operation. A rich mix starts these engines but if the mix becomes too lean, they won'd idle and if you run them too long this way you can cause engine damage due to the lack of gas./oil used with so much air entering the system. Don't be afraid to look around and poke around for other problems. Pull the spark plug and either clean it real good or replace it. It gets a build up on it sometimes that needs to be removed (especially down around the electrode insulator (the white part under the tip).
Posted on Jul 10, 2010
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
Engine starts then quits
does it have a fuel filter, or air? If it does make sure they are both clean and free of debris as priming will force fuel up line but will die as soon as its burned out
May 30, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman Weed Eater only runs on choke (not at all now!)
Check the mounting screws holding the carburettor and the plate behiend the carb, they often become loose, also the gaskets, they might need renewing. Your carb. could need cleaning and new diaphrams. stephen.
Sep 20, 2009 | Craftsman 25cc Gas Line Trimmer
Runs on choke a little
sounds like the carburetor has gummed up a bit, and may need adjustments - or, the fuel pickup in the tank has come loose [i.e.: deteriorated fuel lines] - also, make sure your gas mix is FRESH. if your gas mix is more than 2 months old, dump it
Sep 19, 2009 | Craftsman 25cc Gas Line Trimmer
4 cycle cub cadet will start but as you increase RPM it dies
Check at the exhaust port. Clean out any carbon buildup there. Believe me, it makes a big difference. Hope this helped and best wishes.
Sep 04, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
180 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
