Question about Kodak Carousel 4400 Slide Projector
Focus Lense Will Not move using the remote or the dial - What can I do? Kodak Carosel model 750H
    President:
  • Kodak Master
  • 412 Answers
The KODAK Carousel 750H was manufactured from roughly 1971 to 1981.
If you can push the focus knob toward the outside of the projector and manually remove the lens, then the problem is the gear on the focus shaft (the shaft the focus knob turns). The gear has either cracked and fallen off or is cracked and slipping on the shaft. Either way, the focus shaft needs to be replaced by a factory-trained repair technician.
Posted on Nov 04, 2010
How to change kodak carosel projector ektanar lense
The projection lens will can easily be removed by pushing the focus knob toward the slide tray with one hand while pulling the lens out of the projector with your other hand.
Aug 02, 2012 | Kodak Office Equipment & Supplies
Focus of the camera is not coming out how can i fix it?
If the camera is not focusing correctly, clean your focus meter on the front of the camera and clean the lense.
If the lense is not coming out, try moving it around to try and unjam it. Else, you will need to send this camera in to Kodak for repairs.
http://support.kodak.com/app/intfSel/intf_redirect/L2FwcC9ob21lL29yaWdfaW50Zi9rb2Rha19iMmNfZW4=
Jul 02, 2011 | Kodak EasyShare C643 Digital Camera
When remote button is pushed the unit will not cycle unit is jammed kodak carousel 750h
The projector may not be jammed. It is very common in this generation of projectors for the cycle solenoid "link" to be broken. The "link" connects & transfers power from the cycle solenoid to the slide change mechanism. If this is the case, you can still get parts from: www.micro-tools.com
The problem now become this is a difficult repair if you have no experience inside a Kodak Slide Projector. My advice is to contact a factory trained repair dealer with this information (although it very well may be cheaper and faster to buy a used projector on the internet !). Good Luck !!
Jan 24, 2011 | Kodak Office Equipment & Supplies
Kodak 750H corousel slide projector remote and on projector buttons not advancing slides. Just hums.
Chances are, by your description (and my estimate of the age of this model of projector), that you have a broken solenoid "link". The "link" connects the cycle solenoid and the slide change mechanism. The "link" is made of plastic, and gets brittle & cracks over time. This is a difficult repair, but you should still be able to find parts available. My advice is have this repair done by a factory-trained repair dealer and your projector will run another 20 years.
Nov 22, 2010 | Kodak Office Equipment & Supplies
I have a 750H Kodak slide projector. Where do I find a bulb for it?
The KODAK Carousel 750H uses a 300 watt, 120volt lamp with an ANSI code of "ELH". You can order "ELH" lamps from Bulbman (www.bulbman.com).
Aug 19, 2010 | Kodak Office Equipment & Supplies
Kodak 750H and 760H neither will advance carolsel without manual
This is a common problem with older projectors like this. There is a "link" that connects the slide cycle solenoid to the slide change mechanism. The "link" is plastic and gets brittle & cracks with age, rendering cycling non-functional. this is a difficult repair, but parts are still available. I recommend you contact an factory-trained repair dealer to get your projectors repaired.
May 12, 2010 | Office Equipment & Supplies
Both of these models were manufactured by KODAK between 1971 and 1981 (roughly). My guess is that they both have the same failure: The "link" that connects the cycle solenoid to the slide change mechanism is broken. This "link" is plastic, and gets brittle & cracks over time. While parts are still available, this repair is best done by a factory-trained tech with the service manuals.
Mar 20, 2010 | Kodak Office Equipment & Supplies
Carosel 750H dark shutter does not stay open to be able to view slide and selector button does not work to allow tray to be rotated to a specific slide. Are these problems repairable?
Sounds like a timing problem with your projector. Both problems are repairable. Contact a factory-trained repair dealer to get them addressed.
Feb 07, 2010 | Kodak Office Equipment & Supplies
Model 750H overheated and guide says
That is correct. There are 2 thermal fuses: 1 near the lamp, 1 on the power motor. This repair should be made by a factory-trained tech.
Sep 17, 2009 | Office Equipment & Supplies
No manual or remote advance on kodak 35mm carosel slide projector no reverese either
You didn't specify the model, but chances are that the cycling problem is caused by a broken "link". The "link" connects the cycle solenoid plunger to the slide change mechanism. The "link" is made of plastic, and gets brittle & cracks over time, rendering slide change non-functional. Parts are still available (www.micro-tools.com), but this is an involved repair requiring disassembly & a service manual - - best left to a factory-trained repair dealer.
Apr 01, 2009 | Kodak Office Equipment & Supplies
Kodak Carousel 4400 Slide Projector Logo
394 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
