Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
My frig is extremely hot to the touch on the metal face that separates the freezer and frig. Any thoughts on what might be causing this problem. If it helps, we just moved the frig from another home. Kenmore Coldspot 106.56649500
Likely the cooling fan has died. This happened on my unit. The fan is visible from underneath on the rear left side. Use a flashlight to see if it is spinning. I used a broom handle to tap it and it started to run, which cooled the metal you found hot. I ordered the part on line and replaced it. Heating problem went away.
Posted on Jul 17, 2010
Section between refrigerator and freezer extremely hot.
Check your owners manual troubleshooting. See if you find an answer. Please be more specific. Sounds like it's "stuck" in defrost mode, since it uses electrical heating elements to make the freezer coils melt ice off, but only lasts long enough to remove the collected ice. I would guess the unit runs constantly, or cannot maintain temperature. If the defrost cycle is not working there is a timer not working, or relay, or somehow a very rare short in the defrost system.
Feb 18, 2015 | Whirlpool 25.6 cu. ft. Side-by-Side...
The partition that separates the freezer from the refrigerator on my unit is EXTREMELY hot to the touch. the fridge works ok, as does the freezer, but the partition between them is so hot, you can hardly...
It's usually caused by the condenser fan which is underneath around back. If it's not running when the compressor runs it will cause the problem you describe. You will need to remove the cardboard backing on the back of the fridge to access the fan.
Apr 11, 2011 | Refrigerators
The freezer is freezing up behind the panel causing the frig side to become hot
check with dealer or company regarding frig in back panel.side always become hot due to inbuilt condenser.place in such a way that front and both the side facing to open area.do not face to wall either of the side.back panel towards the wall will do
Nov 17, 2010 | GE Refrigerators
Frig not very cold & metal between freezer and frig gets hot
Poor cooling and a hot divider mean that air is not moving effectively over the condenser coils under the fridge. Check to see if the fan is blowing under there while the compressor is running. If not, then the condenser fan has failed and needs to be replaced. If it is, then use a vacuum with a long nozzle to give it a good cleaning under there.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire #FRS24XHA is hot to touch and freezes food on the left
Hi: Those areas are designed to be warm to keep moisture from forming there(Moulion coil). When they get hot it means the fridge is over working. The condenser coils remove the heat from the fridge. When clogged the heat will leave anywhere it can. The moulion coil is the strip you described,and will overheat when the condenser coils wont disperse the heat. Most likely the coils need a good cleaning, on the bottom of the ref. Use a coil brush and a vacuum. Or even an air compressor to blow the dust and hair out; plan on dusting the house too. Pull the grill off the front and clean them. If real bad pull the panel of the lower back and clean it out too. Since you work in detroit the dust and hair on the coils would be like putting a blanket over your radiator. Parts would heat up. I hope it's just the coils. If a compressor is failing you can get the same symptoms. I hope it is the latter for you, as I'm in your boat also. I hope this helps, Jeff
Jun 09, 2009 | Frigidaire Refrigerators
What would cause the metal face between the doors of a side by side to be extremly hot to the touch?
A condensation heater is located in this panel to prevent moisture from forming.
Some refrigerators have a energy saver switch that when selected will turn this heater off.
Apr 12, 2009 | Whirlpool Refrigerators
I have a side beside whirlpool refrigerator/freezer. today I noticed the strip between the frig and freezer was very hot and coil under frig are almost too hot to touch. It has been this way since about...
no danger of fire, they(Whirlpool) run a copper heat tube through the center mullion of frig, to cut down on amount of undesirable condensation that may build up between doors, reason for extra heat can be from leaving door open too long, perhaps the coils under the frig need to be vacuumed,
Oct 12, 2008 | Whirlpool Refrigerators
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Any thoughts?
Any noises from frig at all??? cicking humming???pull the unit out and remove back cover. Is the compressor(football)size motor in back hot to touch??Lights are on in frig right?
Feb 26, 2008 | Refrigerators
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
298 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
