Question about Bionaire BAP1500-U Air Purifier
How do I clean the filter on a Bionaire BAP1500 Permatech ionizing air cleaner?
4 Suggested Answers
SOURCE: Bionaire filter replacement- reset indicator
I think that this method for resetting the filter does not work UNLESS you first unplug the unit. (Note: I have tried this only on model BAP1175/1300. I recommend unplugging it for an hour, but I really have no specific minimum time for this; in the past I unplugged it for five minutes as recommended by Bionaire phone tech personnel, but the reset did not happen.) Then, after an hour, plug in the unit, and press the On/Off button (on my unit, this button reads, "Off") and Sleep button (on my unit, this button has a "crescent moon" icon) simultaneously. (Again, not sure how long, but I recommend that you hold these down for at least 20 seconds.) Then, you can turn the device on, and it should reset to 99%. Good luck!
Posted on Mar 09, 2008
  • 114 Answers
SOURCE: Fan does not work..any suggestion how to fix this
after cleaning the filters or changing them it does take a minute for it kick on... Now if it hasn't kicked on yet, you might need to reset it. there should be a reset button on the top, if not what you need to do is shut it off and then unplug for about 5 minutes. somtimes the fan might be dirty or clogged so i would check that as well and make sure nothing is interferring with it moving. if that doesn't work, cause i have used this product before. what you need to do is call the manufacturer let them know your warranty. as long as your under the warranty they should be able to replace the unit for you. they will need the date code/ or the reciept to verify the warranty. If you have the reciept they will ask you to fax it in because it is quicker. once they have that, they will give you a call back to discuss other options if you are still under warranty.
Posted on Aug 19, 2009
  • 114 Answers
SOURCE: Black Filters for Bionaire BAP1500
the only other places that you could check would be like a hardware store. kmart, wal-mart. if you have those in your area. ace hardware. places that would normally carry that unit. the big ones mainly are lowes and menards.
Posted on Aug 20, 2009
Are Bionaire F150/150S/150W available?
Refer your inquiry directly to Bionaire.
Jul 21, 2014 | Bionaire Air Purifiers
Tip
BAP1500 FILTERS GOOD TIP FOR RECYCLING!
I had a Bionaire BAP1500 which was broken, light up but nothing happens.
i also have a BAP412 and BAP242 which need to have their filters replaced every 3 months - which is very expensive.
I thought i would try the permatech filters from my 1500 in the other 2 purifiers to see if they would fit - they do! and they both work perfectly with the filters installed..no more buying filters for me
So just a tip to say if you have a BAP1500 and its broken, keep the filters because you can use them in a much cheaper model!
on May 09, 2008 | Bionaire BAP1500-U Air Purifier
Where can I get a replacement filter for bap4010?
According to their website:
PERMAtech Permanent HEPA Type filter traps 99 % of all allergens and dust down to 1.0 micron.
PERMAtech Permanent Filter Never Needs Replacement!
Simply vacuum the filter every three months to maintain performance.
Requires less cleaning and maintenance than other permanent filter systems.
Built-in Ionizer assists in cleaning the air from dust and allergens.
Oct 10, 2011 | Bionaire PERMAtech BAP4010-U Air Purifier
I have recently purchased a bionaire bap 1550 air purifier. Is it normal for the recirculated air only to come out of the left hand side of the front grill
no that isn't normal. it should be coming out of both sides cause the air intake is in the back of the unit where the filters are. try to reset the unit but the pin hole at the top or unplugging the unit for about 10 seconds.... if that doesn't work i would call the manufacturer and to see what other ways or if the unit can be replaced.
Oct 29, 2009 | Bionaire BAP1500-U Air Purifier
May 15, 2009 | Bionaire PERMAtech BAP1500-U Air Purifier
Mar 29, 2009 | Bionaire BAP1500-U Air Purifier
Lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Dec 04, 2007 | Bionaire BAP825-U Air Purifier
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Bionaire BAP1500-U Air Purifier Logo
89 people viewed this question
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
