Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
Samsung side by side refrigerator ice dispenser flap stuck open...
HVACRH20
  • 237 Answers
SOURCE: GE side by side refrigerator ice dispenser
If you take a look at this diagram, you should be able to see all the inner workings of that area and decide if you want to repair it. I think anyone with the most basic mechanical skills could easily handle this repair. See parts 62,63,67, etc. Could just be the spring is off or broken. Let us know what you find! http://www.partselect.com/Schematics/GE/00112435i01.gif
Posted on Jan 08, 2007
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
watugot
  • 290 Answers
SOURCE: Frost buildup in ice-dispenser tube
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced. The problem you describe is almost always air laekage around that flap. Post back if you need more help.
Posted on Oct 20, 2007
SOURCE: Maytag Ice20 refrigerator
There's a very detailed guide explaining how to fix this yourself for about $5 in parts. Some basic experience with soldering is helpful.
My Maytag dealer did not offer to fix for free, so I resorted to doing it myself rather than spend $300-$400.
http://www.liny.net/MaytagIce2O.htm
Posted on Jan 30, 2008
  • 46 Answers
SOURCE: Flap on ice dispenser door won't close
clean it again and make sure when you use it that all the ice falls out if not and its open a little it will cause it to freeze open
Posted on Jun 26, 2009
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
Our new 48" Viking side by side does not feed ice cubes adequately. If you need several glasses of cubes it stops feeding and when one opens the freezer door they are piled up and fall all over the floor....
I experienced the same problem several times with our VCSB483DSS also.
What I found was that the ice come down the chute side way and got stuck at the flap in the door. As you continue to press for ice, the machine pushes more ice & they all back up in side the chute and in the door, ready to dump on unsuspecting person who open the freezer door.
I think the the problems are:
1 - over application of foam insulation in the chute pathway in the door.
2 - possible bad timing on the flap opening causing the falling ice to get stuck.
My solution for the past 6 years:
1 - clean out the over application of foam insulation - this reduce the incident frequency from once a month to once or twice a year.
2 - inform my family member that if while you pressed for ice, and the ice is not dropping, but you hear the motor still cranking away, stop pressing for ice immediately. Stick you finger up the dispenser to make sure the flap is open, and push the ice to un-stuck them. And finally, be prepare to get 2 cups full of ice.
Viking may make professional quality fridge (13 years experience in restaurant business), but ice & water dispenser is not their strong point.
Oct 09, 2010 | Viking 42 in Built In Professional...
MAYTAG ZIG-ZAG FRIDGE-FREEZER WANT DISPENSE WATER
Sounds tome that there is a short in the dispenser control circuit, keyboard or Control Board. If you had the model number I could help you better than this. I possibly would be able to walk you through this, Let me know, Sea Breeze
Nov 19, 2009 | Maytag ZigZagW / B Side by Side...
Ice dispenser is not operating. will dispense ice occasionally. noticed the light in the dispenser opening gets dim. Water is dispensing normally.
When it doesn't dispense , do you hear the auger turning ? If so , then the dispensor flap is not opening completely . This is caused by a rusted plunger in the solenoid which opens the flap . If you use crushed ice often , then could be a build up in the ice shoot which has to be cleaned regularly .
Jul 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Jun 26, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice Dispenser flap not closing
the front panel should just pop off,but you want to look at the solinardmthat is most likey what need replaced,let me know if it is rusted in the open position-mike
Apr 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice machine makes ice but doesn't dispense when the lever is pres
I would check for an electric "flap" that opens & closes when ice lever is depressed. My GE has one and it has been fouled before causing the ice to be stuck inside the door. Hope this helps!
Mar 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice dispenser flap won't close automatically
replace the flap spring and selenoid in the despenser area
call ge at 300-851-6200 with the model number and they will send you the parts about 40.00 dollars
May 07, 2008 | Hotpoint FFU00 Side by Side Refrigerator
Ice maker is not despenisng ice.
Icew flap solonoid faulty or the flap has become detacheed from the lever. Regards Advisor
Jul 14, 2007 | Samsung RS2534 Side by Side Refrigerator
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
299 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
