Question about RCA L26HD35D TV
No picture but sound - RCA L26HD35D TV
  • RCA Master
  • 5,127 Answers
There are a couple of possible causes for the problem. Look closely at the screen from about an inch away from the screen. Shield your eyes from the room light and look for a faint image (sometimes a flashlight helps you see this image). If you see an image then it's probably the backlight. If you see nothing, it's probably the backlight inverter (possibly the backlight too but you can't tell without checking both). The manufacturer will recommend replacing the entire board instead of just one part of the circuitry. The inverter usually fails suddenly; the backlight usually fades or makes the image look pink/red as it fails.
If the TV is under warranty, use the warranty repair. Otherwise, open up the TV (the back). Remove the shielding around the boards (ground yourself to the TV by touching some metal part on the housing or use a anti-static wrist strap). Look at the board(s). Do you see any scorch marks or capacitors that are bulging or leaking? The capacitors look like cylinders on tripods. If you see this damage, you could just replace the capacitors and the resistor that acted as a fuse but other parts of the circuit could be damaged. Instead I recommend replacing the inverter. Note the part number on the board and search for that particular unit - including the Rev number if included. (They run $50 to $150. Universal inverters do exist but might cause the controls to be reversed. Up for lower brightness for example) lcdparts.net has many of the parts for tv backlights and inverters but isn't the only source.
If you don't see the damage, you could check the inverter with a multimeter that measure in kHz (50 kHz range recommended) or an oscilloscope. Hold the multimeter probes about an inch above the circuit board and a fraction of an inch apart with the TV on. If a frequency is given or a value of 1 is shown, the inverter is good. If you see a value near zero, the inverter is bad or the multimeter can't measure the frequency (too small a range).
The inverter is relatively simple to replace. Unplug the tv, unplug all of the wires on the original and unscrew it from its mount. Plug in the wires to the new one. The wires connect like molex plugs on a computer. (Power and individual backlights, etc.) The backlights are on the perimeter of the TV and are often molded into the plastic frame of the TV. You have to carefully remove the cover and the reflector among other things then Dremel (or use a similar rotary tool) to remove the plastic to remove the original backlight. Pay attention to how it was positioned originally since there isn't any extra space to jiggle things into place. Google backlight replacement for pictures, videos and text descriptions of the process.
I hope this helps.
Posted on Jul 08, 2010
IGO tv connected with dish sound come from tv but pictur not show only blue color show
Component RCA Connectors are RED, BLUE, GREEN for picture. Sound is RED and WHITE. The red and white for sound work the same with the YELLOW that does picture. If the RED, BLUE, GREEN are in the wrong order you will get a blue or green picture. For the sound, try the other red and white connectors nearby. Make shore the right red connectors are connected correctly for sound or picture. Otherwise there could be a cable fault or a TV fault. If you get the picture right but not the sound, connect the sound into a stereo.
Jul 17, 2017 | Televison & Video
Tip
SONY GRAND WEGA ERROR CODES AND WHAT THAY ARE
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
on Apr 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
The tv has sound but no picture. For
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
My 32' LG LED TV has suddenly lost picture! The sound is all right but the Screen is pitch black. After switching it on the picture flashes for a second and then the screen goes completely black.
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
TV Has Sound But No Picture Troubleshooting Guide - Duration: 2:30. by Repair.com 472,733 views. 2:30. LG LCD TV REPAIR -NO PICTURE ...
Dec 21, 2015 | LG 47LN5400 47" LED TV 1920x1080, 120 Hz....
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
No picture no sound
Last night i set childlock in my nikai ( NTV34010) tv set and tuned off by remote control.Then after some time later i tried to turn on tv but there is no sound and no picture.
will u please help me to solve it out.
Dec 02, 2007 | Panasonic CT-36D32 36" TV
Playback movie pictures or sound
Movie pictures can be played back with the camera, but not sound. However, when the camera is connected to a TV, both movie pictures and sound can be played back. For playing back movie pictures or sound on a PC, the QuickTime™ 4 is required.
Sep 01, 2005 | Olympus Camedia C-3030 Zoom Digital Camera
Sep 01, 2005 | Olympus C-3000 Zoom Digital Camera
RCA L26HD35D TV Logo
615 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
