My seagate 500gb sata drive will only format to 128gb on my intel d915pgn motherboard. I installed the drive to an external usb 2.0 enclosure and it formatted fine. Removed the formatted drive and installed it to the motherboard sata port and windows 2000 says the drive is not formatted.
Http://forums.macosxhints.com/showthread.php?p=359325
never buying maxtor again....
Posted on Jul 11, 2008
    Problem Solver:
  • 95 Answers
Was the usb enclosure usb to ide or sata? maybe the diffrence bewteen the 2 and how they track the data on the drive.
Posted on Apr 21, 2008
USB port broke off. Can I connect to something else to get the data off the drive? I cracked open the case and it's a barracuda 7200 but I don't recognize the pin connections. Please help? Thank...
Yes just fixed mine. Went to radio shack bought a gigaware sata 3.5 external enclosure.
Took the harddrive out of old enclosure. pryed off external alluminum case to expose a panel that sticks out to the side where the broken usb plug went. Wiggled that off then placed in new enclosure fits good. secured with old screws. plugged it in and it works great. The new usb plug is much sturdier. The external case cost me about $40.00 and some change but Im glad i retreaved my data. I will never buy another seagate. Hope this helps...Alan
Jan 04, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Why i cant format my seagate 500gb potable hard drive, when format it in quick format its show an error that the hard drive not successfully formatted. what should i do? please help me, i need it asap....
The disk-drive inside the enclosure is "dying".
If the warranty still is valid, exercise the warranty to get it replaced, at minimal cost to you.
If the warranty has expired, open the enclosure, remove the disk-drive, and take the disk-drive to a computer-store. Buy a new, compatible, drive, and then "transplant" it into the enclosure, to "revive" your external file-storage appliance.
Nov 17, 2010 | Seagate 500GB USB 20 5400RPM Portable 500...
My seagate external hdd 500gb is not working and is not detected and regonised in any pc..
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 07, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Cannot format a sata drive completely, i have installed a new master hdd which is 500GB, however when formatting I can only see 128GB
Check drive for partitions. Also, you can use a program such as Seagate DiskWizard to format and setup for loading. That program is available from Seagate's web site.
Jun 17, 2010 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
I have a 500GB Seagate FreeAgent external hard drive with a lot of media on it that I really don't want to lose. It's USB connection is broken so that the port sort of just floats around inside. Could...
If you cannot get the USB port fixed you can take the drive out of the inclosure and install it as a second drive in another computer that has SATA capability to get the data off of it. You can always put it back in if you can get the enclosure repaired.
Mar 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate 120 gig HD in Dynex enclosure not recognized by XP system
Ok, you didn't say if the drive had data or not? Anyway, if it is a drive with no data etc, you will first need to Initialize, & Format the drive before use. Is there any way you can connect it up to an "Internal" or "External" SATA port, & "See" if the drive is recognized, then at least you know the drive is OK.. Also try another USB port if available. If you know it is OK, then go to device manager and Uninstall the entire USB layer, reboot, it will re-install the USB again, with default settings, it NOW may be "Seen".
Feb 22, 2010 | Dynex USB 2.0 Hard Drive Enclosure Kit...
I bought this Seagate Freeagent external hard drive less than a year ago and the other day when I plugged it in I came to the cold realization that it had overheated. There is a known problem with the...
Most of these external hard drives are just regular old 3.5" or 2.5" hard drives in some sexy looking enclosure. Hopefully just the power supply to the drive overheated and did not do any damage to your data.
Disconnect the unit from the mains (duh!) and carefully disassemble the unit until you can get at the drive itself. Disconnect the drive, and see if it is an EIDE or SATA drive. Again, the drive itself is going to look a lot like one your've seen inside your computer because in 99% of cases it is the same thing.
Purchase another external enclosure for the proper type of interface (SATA or EIDE), or , if there is room in the PC itself, actually install the drive in your PC as an auxiliary drive.
Data retrieved.
Voila!
Mar 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have had to reinstall my operating system and drives but now the Seagate 500 GB external is not recognized. What now?
Are you using eSATA for the External or USB. If it is eSATA you may need to get the respective drivers for your motherboard for it.
Jan 30, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Help
An external USB drive consists of tow parts:
a hard drive (usually a standard IDE or SATA drive), and
an enclosure
The enclosure is the box containing the drive. It also includes an interface to convert the data from the IDE or SATA interface on the drive to a USB (2) signal. Some enclosures include and internal power supply. The Freeagent has the power supply externally.
Hope that's what you mean.
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Open Questions:
How do I fix my Toshiba laptop? Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Customer Care like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Jun 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
