Question about Kenmore Kitchen Ranges
Kenmore range c970-688334 The electronic oven control board just simply blacked out. Nothing appears anymore (not even the clock) and commands to the oven do not respond when pressing on the buttons. The stove top still works though (the 4 main elements)
5 Suggested Answers
  • 7 Answers
SOURCE: Frigidaire electric range
is there voltage going to the erc (electronic range control)?
Posted on Feb 09, 2008
  • 1314 Answers
SOURCE: Frigidaire oven heating elements **** the bed
open the bottom drawer and get the model number off the serial plate on the left hand side i think its a slide in with the controls on front
Posted on Mar 31, 2008
reg501
  • 413 Answers
SOURCE: Kenmore range model 790.90152300 the
The electronic oven controller has failed. The cost is around $160.00.
Posted on Jun 26, 2008
duby1990
  • 370 Answers
SOURCE: bottom element on range doesn't work although its been replaced
You have to replace the clock. That will definately fix your problem.
Posted on Nov 18, 2008
Ging control panel on kenmore electronic oven
Oven Control Board Replacement - Kenmore Electric ...
? 2:46
https://www.youtube.com/watch?v=D_uIhhCducE
Nov 14, 2013 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing theoven ... Oven Control Board Replacement - Kenmore ElectricRange Repair (Part #318296822) .... while installing control paneloverlay to stove to keep spills out.
Oct 15, 2015 | Kenmore Kitchen Ranges
Self-cleaning electric range
Hi
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1Safety flip flopReplace Electronic Range Control/Clock (ERC) F2 - E0Shorted keypadReplace Electronic Range Control/Clock (ERC) F3 - E0Oven temperature sensor or oven temperature sensor fuse openedReplace oven temperature sensor or fuseF3 - E1Oven temperature sensor shortedReplace oven temperature sensor F3 - E2Oven too hotReplace oven temperature sensor F3 - E3Clean temp too hot Replace oven temperature sensorF5 - E0
F5 - E1 and E2 Door latch problemCheck door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of yourmodel # 0-5 that will determine which control it takes. Once you havethat # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
Oct 08, 2008 | Kenmore Kitchen Ranges
Electronic Oven Control on my Kenmore 95321range is not working
I just replaced mine and it's an easy fix even if you're only moderately handy. You'll need to purchase a new or refurbished oven control board. This generally is just the internal components and does not include the overlay, if any, for the clock. This will depend on your model. Here's a video showing you how easy it is.
Aug 28, 2014 | Kenmore 95320 / 95321 / 95322 / 95324 /...
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Range Model YKESC307HWO: Received Voltage Spike from Power Supply Company resulting in damage to several appliances including my Kitchen Aid Range. The control panel does not light up anymore, resulting in...
It sounds like the control board of the timer is faulty. Do you need the electronic timer/clock. If you don't it is normally easy to by-pass the timer altogether. Find the main active wire coming into the timer. Then identify the load wiring which runs from the timer to the oven thermostat control. These two wires simply need to be connected and the timer is bypassed and the oven will work.
Feb 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
Kenmore Electric Double Oven Mod 9114832592992 got F2 code in middle of selfclean what do I need to fix?
Hi, i found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
OR....
OR
F2 Temperature runaway detected (Bake/Broil: 600 - 700 F; Clean: 930 - 1000 degrees F). Sounds alarm and resets to non-cook mode. Check relay board for stuck contacts. Check oven temperature sensor for normal room temperature resistance (1085-1097 ohms at 75 degrees F). Check sensor wiring connectors for a loose or high resistance connection. Check electronic range control (also called clock or ERC) functions Replace relay board if necessary. Replace oven temperature sensor if other components check normal. If failure repeats, replace electronic range control (also called clock or ERC)
Oct 26, 2010 | Kenmore Ovens
Self-cleaning oven F2 error message
Well I found three all same series... If it's occasional I'd leave it 'till was always on? Anyway .....
OR....
OR
Feb 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag MGR5875QD stove problem
bake and broil feature not even responding to touch???? its one component " the electronic range control" clock assy. after trying to unplug and possible resetting the control. i would say youll need to replace the control unit.
Mar 23, 2008 | Maytag MGR5875QD CleanDesign Gas Kitchen...
BEEPING OVEN
The F1 and constant beeping is an error code indicating that your electronic control board (clock/timer) is defective. The fault cannot be reset and the control board must be replaced. This can be an expensive repair if your range is no longer covered by a warranty or service plan. The cost to buy a new control board can be in the neighborhood of about $200. Sorry...but I do hope this helps you.
May 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
108 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
