Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt 500 WFMC3301UC Front Load Washer is leaking water somewhere inside the unit. It is only doing this from the hot water source. All connections are tight and there are no external leaks. The cold water source is not leaking. I have also removed the water filter from the back of the machine and it is clear. You can hear a 'drip' sound but I am unable to locate the source or cause.
  • Bosch Expert
  • 414 Answers
It sounds like it may be the hot water valve, the valve itself may be leaking or the water pressure from your hot supply may not be high enough to 'lock' the valve fully when not energized. The second problem could be rectified by using a 'y' piece splitter on you cold supply and running both valve on cold water,
Link to parts diagram valve is position 407.
https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=WFMC3301UC%2f16&ESHOPTYPE=S
Posted on Jul 08, 2010
Testimonial: "Thanks for your quick and accurate response. The hot water valve inside the unit is leaking and needed to be replaced. I had a service technician come in to replace the valve."
I replaced the original leaking washer hoses on my Nexxt 500 machine with metal ones. On quick wash cycle, water does not flow at all. Does the Bosch Nexxt 500 require OEM hoses only for water flow?
A hose is a hose is a hose. Type of hose won't make any difference.
If you can, try to do a wash cycle that allows you to see if both the hot and cold water are working. You may have loosened a wire connection to one of the valves for the hot or cold when you connected the new hose, or possibly there was something inside the new hose that is now blocking one of the valves.
Aug 17, 2016 | Bosch Washing Machines
Bosch WFMC3301UC washer. The water will not flow into the machine. After a few minutes we see an error msg E02. I had replaced the hot water inlet valve two months ago because it developed a leak. No...
Bosch WFMC3301UC washer. The water will not flow into the machine. This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Aug 12, 2011 | Bosch WFMC 3200 Front Load Washer
What is error message E-02?
Check the user manual for a troubleshooting guide. There is a link attached in case you no longer possess a manual. http://www.retrevo.com/support/Bosch-WFMC3301UC-Washers-manual/id/925ci465/t/2/
May 06, 2011 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Looking for part number of the Transit/transport Bolts
Hi
Thanks for using FixYa. Please check these links for the parts of your Bosch washer:
Bosch WFMC3301UC Parts
Bosch WFMC3301UC Parts-2
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Washer leaks when it isn't packed full of clothes.
check your door seal if leaking in the front if the back its probably one of the water lines leaking
Feb 24, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch nexxt washer fabric softener not draining
is there a drain on the bottom left corner if so drain the contents its usually under a small panel
Sep 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch washing machine leaks at right bottom
The part that you removed, was the pump filter, the pump is located behind the filter, possibly, the pump itself is leaking, or the filter cover is not fastened in tight enough, pr the filter seal is defective, if after tightening, it still leaks, suggest you replace the pump.
Please rate my solution.
Thanks.
May 26, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Our Bosch Nexxt washer uses very hot water on all
there is a mixing valve that uses a solenoid to open and close (and mix) the hot/cold inlet water based on your selection.
If you verify the correct model # I can point you in the right direction for a new valve if you are so inclined.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 14, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
822 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
