Question about Maytag Atlantis MDE7400AY Electric Dryer
The dryer will not start. It has power to it, the circuit breaker is on and the light is on inside the dryer. But it will not start in any program. What could be the problem?
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryerThe dryer will not start. It has power to it, the - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_noThe dryer will not start. It has power to it, the - 2_bing.gif/a>
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 12, 2010
70 Series Dryer will not start. Checked breaker box. Unplugged unit and checked connections and cleaned out built up lint dust. Door is sealed properly and light inside dryer is still on when door is
Check the motor for a blown fuse or circuit breaker attached to it, maybe a wire is disconnected from it. Another thing to look at is the actual switch on the top. Is it making good contact? Does it have a fuse or circuit breaker attached? Is it getting power?
Jan 11, 2013 | Dryers
Dryer wont turn on. Breaker in breaker box is fine. No light inside dryer. What's wrong?
Dryers run off 220v, and sometimes only one leg of the breaker trips. So you need to flip the breaker all the way off, and then back on. Sometimes the breaker feels off but is not fully reset. Make sure you completely trip it off then back on. Does the dryer light work now? Is there any indication that it's getting some power? If the breaker is fine and your still not getting power, then the next step is to make sure you have power coming to the plug behind the dryer. At this point you should only continue if your comfortable working with electricity. Once you move the dryer you can check the outlet with a meter, or other circuit tester. If you got power here, then you'll need to start checking things on the dryer. you can remove the plate where the cord goes into the dryer and look for loose or burnt wiring there. If that looks ok, then you'll need to start taking the dryer apart; front panel, top, back, etc, as needed to access the wiring and controls. From here you can trace the wiring from the supply to the controls and to the motor, etc. look for anything burn, If nothing looks out of place you can start checking temp sensors, or fusable links. If this is above your head, then stop where your not comfortable and have checked by a service technician.
Sep 20, 2010 | Whirlpool LEB6300 Electric Dryer
GE Harmony dryer does not power on. Light works-
This is an easy check, and it might fix your problem, though it also may be something else. Turn the circuit breaker for your dryer outlet off, then back on. The circuit breaker will be located in the main breaker panel of the house. It should be labeled "dryer" or something like that. It will be a double breaker, meaning that there are two breakers tied together physically.
I am wondering if one of the two breakers has lost contact or tripped. That could possibly allow the light to work, but prevent the motor and heat from working.
It's an easy check, and there is a chance this is all that is needed.
There are other possibilities, but this is a very easy noe to check, so why not start here?
Nov 16, 2009 | GE DBSR453EBWW Electric Dryer
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
Sep 12, 2009 | Maytag Dryers
Has power but won't start. the light inside the
First, go to your circuit panel and turn off then back on the dryer breaker.Second, check for a broken belt. The belt switch will be open if the belt is broken and the dryer will not start. Next.Replace the thermal fuse located on the top right of the heater canister located in the inside rear of the dryer.
Aug 28, 2009 | Hotpoint Dryers
Roper Electric Dryer
Really sounds like a power problem. Start by turning the breaker off and then back on. I have seen breakers trip but the handle does not move. This can drive you nuts as it "Looks" like the breaker is o.k. If this does not help, then you have to start by verifying that you have the correct voltage to the unit. If you do, the problem is anywhere from the plug/ cord, to anything inside the unit. This requires following the circuit one item at a time.
If you don't have the correct power, you need to address that.
Good luck and hope this helps.
Jan 26, 2009 | Roper RES7646KQ Electric Dryer
The main circuit breaker triggers when i have my electric clother dryer on for while
Hello latino,
If your problem has just started to happen ( meaning that it worked ok until recently) .. your circuit breaker itself may be starting to fail. They do have a finite life expectancy and over time, you may experience nuiscance trips. Another consideration is that the wiring coming from the circuit breaker up to the receptacle that feeds power to the dryer may have loosened up at the connection points and when that happens, those connections points become resistive and cause the dryer to require more current to maintain the same power..By requiring more current, you may be exceeding the rating of the breaker.. so those are a few things to check..
If I were there, the first thing I would do is shut off that breaker and open the circuit breaker panel ..make sure the screws that hold the wires to the circuit breaker are snug.. then close that up.. and do the same thing at the dryers receptacle on the wall and the termination points inside the dryer where the power cord connects. After that, I would reapply power and see if the problem persists.. If it does, I would remove and replace the circuit breaker.
One last thing to check might be the drag on the dryer drum.. make sure it isn't binding and requiring the drive motor to work harder ( which means more power demand) to rotate the clothes..
Those are a few areas to investigate.. Hope that helps
Regards,
Rick
Dec 06, 2008 | Dryers
Dryer does not give heat
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Dec 03, 2008 | Kenmore 63942 Dryer
Ge gas dryer
Heating element
Thermal fuse
Wiring
Apr 21, 2008 | GE DBXR463GB Gas Dryer
Dryer problem
Heating element
Thermal fuse
Wiring
Mar 11, 2008 | Whirlpool GEW9200L Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
73 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
