Question about Apple iPhone Smartphone
It seems like when we plug the cord in to charge we are not getting connect from where the cord goes in to give the battery power?????
  • 502 Answers
Your dock connector needs to be replaced. If the Apple store doesn't help you, there are third party iPod repair services, that will fix it for cheap. Also, I found an DYI iPod repair guide, so you can do it yourself too, not that difficult. Part is available on Ebay.If you can't do it yourself, have a tech savy friend do it for you.
Posted on Jul 12, 2010
No power
Try another outlet, cord/charger, with the EXACT same power specs. Has the cord plug been pulled while pluged in damaging the AC jack? Does the computer boot on battery power?
Feb 20, 2013 | MSI A6200-059US Laptop
Hpdv6500 charger doesn't seem to be connecting
Step 1:
If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop. It should fit firmly in the DC jack without wiggling. If it is loose, use electrical tape to hold it in place so the charger can receive power. This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury. A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible. Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open. The battery should pop out; give it a tug if it doesn't. Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors. Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery. Slide the latch to secure it and plug in the power cord to test it. See if the laptop powers on with the charger only and battery removed. If it does, the battery is the likely culprit and should be replaced. If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number. Call the laptop manufacturer for a replacement charger or search for the part number on eBay. If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems. Troubleshoot Mag Safe adaptors
http://support.apple.com/kb/ts1713
Feb 15, 2013 | HP Pavilion dv9000z Notebook
Laptop won't charge
Step 1:
Feb 12, 2013 | Toshiba Satellite Computers & Internet
Adapter from power cord gets power, but is not charging samsung rv511 laptop
Step 1:
b> If your laptop charger seems broken, it's most likely because the battery will not charge. You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly. When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Feb 12, 2013 | Samsung Rv511
I have a new violation 9053 and first time to charge the green light blinks for about 10 seconds and then goes off and thje battery is now dead it seems, no lights, no power
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 01, 2012 | Computers & Internet
COMPAQ V2000 BATTERY NOT CHARGING
Try to isolate the problem first. See whether it's a laptop issue or an adapter issue. If the adapter has a light, see if the light is coming on when you connect it. Also see if the laptop works if you remove the batteries and connect the adapter.
There could be several issues here:
1. Your adapter's light may be coming on, but it still might not be delivering power to the pin. If you have a multimeter, connect it to the terminals of the charger and see if you get a voltage reading; if not, there may be a problem with the cable running from the adapter to the laptop or the adapter itself may not be giving the right voltage.
2. The second possibility is that the adapter is OK, but the laptop's power connector is faulty. This will require a technician to remove the old connector and solder a new one into place.
3. If both the adapter and the connector are fine, then the problem is most likely with your charging circuit, which is inside the laptop. This circuit powers the laptop through the batteries, and will once again have to be inspected by a qualified technician.
Hope this helps
May 24, 2011 | HP Compaq Presario V2000 Notebook
Battary is not chage its not working
What happens on almost all laptops is that either a: the solder breaks from the constant wiggling of the power plug in the socket causing the socket to become loose and not get a good connection, or b: the power supply module (the little box thing attached to the cord ) goes out, usually because people leave their laptop plugged in all the time, and it was never designed for long term constant use
The cord is only meant for charging the battery, or as a temporary power aupply in the event your battery should give out on you.
Dec 18, 2010 | Computers & Internet
HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Aug 13, 2009 | HP Pavilion zd8000 Notebook
Inspiron E1505 - ac power not always on when plugged in outlet
I've had both the battery and the cord die in my old Dell laptop. Assuming it's like mine and the light is on while the battery's charging and turns off when the it's full....
Dell batteries don't last more than a year or two, so my first question would be how old is the battery you are currently using? When a battery is dying, it essentially isn't able to use its full capacity. So in addition to lasting less than an hour or so, it will try to charge for 6-12 hours trying to get a full charge even though it can't. So the light will stay on until it gives up. It will start charging again if you unplug it and plug it in again. If this is the case, you can either replace the battery ($100+ bucks) or ignore it and don't use the battery.
If the power cord is going, it will only work at certain angles. Play around with wiggling and bending the cord (not TOO far though!!) to see if you can get the battery light to shut off when you move the cord in a certain direction. A new power cord/adapter will cost you around $50 I think, if that's the problem. Let me know if your problem doesn't seem like either of these.
Hope this helps and best of luck!
Jun 18, 2009 | Dell Inspiron E1505 Notebook
Battery wont charge.
Unfortunately, Mintek seems to have gone out of business, so there is no way to purchase replacement parts without finding them online somewhere.
The problem could be caused by one of three things:
  1. The battery is dead and cannot be recharged
  2. One of the battery connections is broken in some way
  3. The cord is bad and will not provide power
If the battery is dead, you're stuck with keeping it plugged in or trying to find a battery online. If one of the battery connections is bad, the only way to test it is with a new battery and you're back to finding one online. If the cord is bad, it wouldn't provide power at all, so it sounds like both of your cords are fine.
May 10, 2008 | Mintek MDP-1760 Portable DVD Player
Apple iPhone Smartphone Logo
41 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
