Question about Clarion VX409 Car Video Player
The clarion stop working could it be the 15 amp black box behind the deck itself or how can i troubleshoot it
  • 24 Answers
I need the model number to look it up
Posted on Jul 08, 2010
I bought a Clarion db285usb. It has a 3 amp fused wire and a 15 amp fused wire. what do these two wires connect to?
These are connected to the +12volts battery supply ie. on the live side of the fuse box and the fuses protect the equipment in the event of a fault. There is a black wire and this is connected to chassis ie volts (ie. ground)
Apr 11, 2012 | Car Audio & Video
My dxz665mp has two power wires (a 15 amp and a 3 amp) what are they for? I am new to installing and I lost the box and instructions.
Cd players require 3 wires for the unit to power on and thankfully name brand companies have made it easy for the consumer by making the wire harness with standardized wire colors. The wires that have the in-line fuse holders should be yellow and red.
The yellow wire is the constant 12 volt power feed to the the deck. This wire needs to have power all the time for the deck to maintain it's memory (ie saved radio station presets, audio settings, clock etc...).
The red wire is called the switched ignition or ACC (accessory) wire. This wire will only have power when the key is turned on.
The third wire all decks need is the black ground wire. All car electronics need power and ground to turn on.
The other wires are your speaker sets... white (+) and white with a black stripe (-) for the front left speaker, grey (+) and gray/black for front right, green (+) and green/black (-) for left rear and purple (+) and purple/black (-) for right rear.
Other wires...not all makes and/or models of radios have these but, if your's does, here's what they are.
blue with a white stripe - amp turn on wire, used for providing a turn on trigger to aftermarket amplifiers (some factory amplifiers too depending on the make, model and year of vehicle)
orange or orange with a white stripe - illumination wire
solid blue wire - power antenna wire, this makes motorized antennas go up and down when you turn the radio source on/off
Apr 02, 2011 | Clarion DXZ655MP CD Player
When i turn the volume it says amp ground, I pulled the deck out and made sure the ground had a good connection, but it still says it. What else could it be?
Most of the time that means that one of the speakers is grounding out and it shuts off the amp to protect itself from getting fried. Most likely one of your speakers is blown out that is causing this. If you're not familiar with using a multimeter you can disconnect them one by one until it stops doing it.
Mar 09, 2011 | Clarion DB185MP Car CD/ MP3 Player
Hi i trying to figure out how to wire up my rca's i have a pionner deck in on the back of it it has front output,rear output,sub output ,and also a audio output .now im trying to up it to a clarion eq that...
The "Front output" from the Pioneer deck would connect to the "Main In" on the Clarion EQ. I'm assuming that your Clarion EQ can only deal with one input, and will send the adjusted (equalized) signal out both of the outputs.
The "Front output" from the Clarion EQ should go to the "Front Input" on the 4 channel amp.
The "Rear output" from the Clarion EQ should go to the "Rear Input" on the 4 channel amp.
The "Sub output" from the Pioneer deck would connect to the Left/Right Input on the Epicenter. The Left/Right Output on the Epicenter would need a Y-splitter for each side, so that you could connect each amp separately. One suggestion would be to use one sub amp for both subs.
Feb 18, 2011 | Clarion Car Audio & Video
I turn up the volume and it says amp ground the car doesnot have an amp?
Pull the deck out and make sure that your ground wire is attached to a solid ground and that your wiring is intact and sturdy. The deck itself has its own internal amplifier which powers the vehicles speakers.
Dec 11, 2010 | Clarion DB185MP Car CD/ MP3 Player
I am looking for a wiring diagram for a Clarion Rab110D tuner/cassette deck. Can anyone help?
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Jun 02, 2010 | Clarion RAB250D
Cant' install a clarion dxz855mp
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
Feb 10, 2010 | Clarion DXZ855MP CD Player
For the Clarion DXZ945MP CD Player for car audio, I do not know the the wire harness color wire diagram? The wiring harness on my Monte Carlo 2000 reads what color wire goes to what, on the side of the...
3amp yellow battery for deck
15 amp yellow is another battery wire
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
red accessory
hope this helps
pls rate cause people arnt rating
Nov 05, 2009 | Clarion DXZ945MP CD Player
Blinking Head Unit After BAttery Jump
check fuse for memory and constant , from behind the deck . red is switched , yellow is constant 12v
Oct 25, 2009 | Car Audio & Video
Clarion M5675 won't turn on
Take the stereo all the way out and hook the black wire to the negative terminal and the yellow and the red wire to the positive terminal on a charged car battey. If it still does not turn on you may have fuse in the back of the deck. If not it's probably fried.
Apr 19, 2009 | Clarion M5675-RET CD Player
Clarion VX409 Car Video Player Logo
167 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
