Question about Kenmore Elite 45986 Front Load Washer
The drawer at the bottom keeps sliding forward
Whats the fix for the bottom drawer that does not lock into place
    Sergeant:
  • 222 Answers
There is no lock raise the front of the machine slightly by lowering the front legs gravity keeps it shut
Posted on Jul 09, 2010
How to remove center desk drawer
Some drawers have slides that have latches that have to be manually depressed simultaneously, in ordert to remove the center drawer. Look at the slides and see if there is a button, or possibly a machined strip of metal, that releases a latch that keeps the drawer from falling off the end of the slide.
Sep 17, 2017 | Hal Leonard Music
Passenger seat won't lock in place
The adjusting lever for seat position is not locking into place. On the bottom of seat are runners on each side with holes in them that the adjusting lever tabs will lock in and hold seat in place. The seat slides on the runners if those tabs are raised. There is also a connecting wire or rod from the lever to the other side of seat so when lever is pulled up, tabs on both runners are raised for seat to slide. Something is keeping the tabs from locking into the holes on the runners in your car. Maybe the adjusting lever is broken somewhere, or the wire/rod came loose, or the lever is just dry and sticky and needs a shot of WD40 to loosen it up. If you can't see it and fix it with seat in place, then pull the seat back off for the repair. Good luck. Post back if my explanatiopn is not clear or you still need help.
Jun 19, 2012 | 1998 BMW Z3 Roadster
I have a fisher and paykel dd24ph6 model that will not lock. Where is the locking mechanism located?
the way the dish drawer locks is the lid lowers onto the drawer..on the sides of the drawer are motors that lower and lock the lid into place ..to get to them the drawer must be removed,to remove the drawer remove th pins from the side of the drawer,slide down and off the front panel and push and and release the tabs that lock the drawer to the slide rails..then push the slides back slightly and lift off drawer..on the sides connected to support bracket on each side will be a lid motor. It is advisable to replace both at once
Aug 24, 2011 | Fisher and Paykel DS605I Built-in...
I need to replace the 3 button control panel which is one piece along the top of the draw many thanks wayne
Hi - this should help you out ..... enjoy.
9.1 Drawer Front Removal
9.1.1 Slide open drawer.
9.1.2 Locate draw pin on either side of the tub.
9.1.3 Using a sharp pair of long nose pliers or slip jaw pliers grasp the center dividing web of the pin and pull away from the tub to remove the pin. Support the drawer front with your hand while doing this. Note: The pin web is vertical.
9.1.4 With both pins removed the bottom of the drawer front can now be eased out slightly.
9.1.5 Now carefully pull the drawer front down to allow it to come free from the handle and top locating slots.
9.1.6 Carefully remove the earth wire from the tab on the drawer front. (if it is an integrated model you will also need to unplug the integrated badge from the isolating module)
9.1.7 Refit in reverse manner ensuring the drawer slides are right forward and the pin secures through the hook on the front end of the slide.
Note: When reinserting the pins make sure the dividing web is vertical.
9.2 Tub Removal
9.2.1 Open the drawer fully.
9.2.2 Depress the right-hand tub clip and push it back about 30mm (1 inch). Repeat for the left-hand side.
9.2.3 The tub may now be lifted up off the drawer runners.
9.2.4 Slide both runners back into the product.
9.2.5 Refit in reverse manner.
Drawer and LCD Display Removal
9.3.1 Remove the drawer front as per instructions in 9.1.
9.3.2 The handle fits onto a lip at the top of the tub and then slides from left to right to lock into place. Push the right-hand end of the handle to the left until it feels free then remove it out towards you.
9.3.3 Disconnect the six wire harness from the electronic controller to the LCD interface.
9.3.4 The handle may now be lifted clear. The LCD display is held in place by a spring tab on one
end and a clip in the centre. Use a small blade screwdriver to carefully release the tab and centre clip as shown. The LCD assembly can now be removed.
9.3.5 The wiring harness can now be unplugged from the LCD.
9.3.6 Refit in reverse manner.
Jul 07, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher beeping and displaying F1 on screen. HELP!!
F1 error means that the flood switch has been activated. To reset the flood switch you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Once the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position.
Mar 17, 2011 | Fisher and Paykel 23 in. DS603H W Built-in...
Bottom Draw Wont Close
Check the sides of the drawer on the dishwasher and make sure that the sliders that the drawer rides on are not locked in place you will notice on the front of the slider near the door panel there are plastic clip like press in tabs that hold the drawer securely in the tracks try to put your hand up under the door and move the track if the track moves in the slider you will need to hold the door secuely with one hand while sliding the track to the most open position on the slider track. if the sliders are not locked in you will be able to pull the slider forward and the slider should clip into place.Repeat this for both sides and the door should operate like new once again.
Jan 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water pump on F&P DD603
behind the bottom drawer taped on back wall of inside of unit is atech sheet, with a pretty good troubleshooter. to remove the drawer push in rectangler hinge locks in hte bottom front corner of drawer front, just below the circles(no noeed to remove the circles)push themin and slide back the drawer will lift off and your able to set it aside(wont come out to far its connected by the hoses but itll come out enough(reset the door unto the hinge slides and pull hte lock latch foward to lock back into place
Feb 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel double drawer dishwasher
Hi. I am a plumber who has had this problem before. To reset the flood switches you need to remove the bottom dish drawer to be able to access the reset buttons. To remove the drawer you press in the rectangle buttons and slide them back under the drawer, they are located right behind the front panel at the bottom of the drawer. It may help to have someone help hold the drawer for you. Once they are slid back all the way place the bottom drawer on the floor to the left side of the washer as you look at it. This will give you the access you need. Lie down on the floor so you can see in the bottom. There you will see a white coloured plastic box on each side, one is for the top drawer the other is for the bottom drawer. Make sure the power is off to the dishwasher. Place your finger underneath the box and you will feel a small pin/lever. This is attached to the magnetic flood switch and resets it when you click it one way and then the other. Once you have done this turn the machine back on before you put in the bottom drawer as if it does not work then you will need to activate it maybe a couple of times. Oncw the F1 alarm disappears you are good to go. Place the drawer back in the opposite way to removal. Slide one rack forward and rest the drawer on it. Then slide the other side out and it will snap lock into position. This procedure literally takes me about 3 minutes and should save you about $120 for a serviceman to come out. The principal is the same on all dishwashers its just a matter of locating the reset switch. All the best and save yourselves a fortune.
Jan 09, 2008 | Dishwashers
Kenmore Elite 45986 Front Load Washer Logo
57 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
