Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
Rinnai Energysaver 1001ft I'm trying to remove the flue. I have removed all screws, the flue just spins. I'm trying to get it out with damaging the flue or the wall. Any help appreciated.
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow link.if it helps…
http://www.rinnaiuk.com/5_Downloads/5_Warm_Air_Heater_Downloads_PDFs/14_Rinnai_Energysaver_Vertical_Flues_Installation_Manual.pdf
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 08, 2010
My rinnai energysaver 1001ft will not turn on.It has power to it but it will not power up when switched on.no lights no go.HELP;;
Hello Mark Obrien,
I searched the internet trying to get a HIT from your
rinnai+energysaver+1001ft
and all combinations there-of...
I also went on-line to a MAJOR RETAILER site & poured over their inventory of systems and parts (see below)...
Alpine Home Air Products Contractor grade furnaces heaters air...
Nothing... so:
Assuming you are talking about a heater here
If you are seeing no "lights"...
perhaps checking the SECONDARY side of your
POWER TRANSFORMER would be the best advice...
If that has the required (typically 24 volt output)
continue on to your main control board...
(looking for the Typical FUSE (usually 5 AMP)...
If the fuse is OPERATED... replace it...
f it operates again... IT is time to consider purchasing that
SPARE MAINBOARD you always wanted...
Like a YORK furnace... (verify your OWN NUMBERS)
031 01267 001A OEM Upgraded York Furnace Control Circuit Board by BDP... (PC (Main Control Board)
ALSO CHECK HERE
https://www.supply.com/rinnai-furnaces/b2098
Fuse kit
Amazon com Bussmann NO 44 ATC Blade Fuse Tester Puller Kit Home Improvement
Hope this helps...
Carnac the Magnificent
Jun 25, 2017 | Rinnai Heating & Cooling
What is error code 99 on my Rinnai energysaver wall heater
Check the flue for blockage of exaust air flow ,ice,snow,birdnest ect.
Feb 18, 2015 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai energysaver 556 blinking
Hi jmsocr2315,
If my description of what your heater is doing please read through to the end.
The heater is turned on and a room temperature is selected.
You can hear the noise of a small fan start, which shortly after the heater starts.
After a short period of time the heater stops and the red led begins to flash and shuts itself down.
This type of heater has a balanced flue, which means it draws air in one pipe and exhausts it out another.
Have the balanced flue checked for blockages, the problem will most likely be in the flue pipe which draws the outside cool air into the heater and not the flue pipe which blows out the hot air.
it may be full of cob webs or something else which restricts the air flow to the heater.
A service person can perform a quick test to prove the above theory. At the rear of the heater there are two pipes, one is an insulated metal pipe and the other is plastic pipe.
Disconnect the plastic pipe from the flue box and restart the heater.
If the heater runs normally this will confirm that there is a blockage.
Feb 05, 2014 | Rinnai EnergySaver 556 Air Conditioner
I have a rinnai 1001ft heater but i need the flue is there enyone that has one please
You should be able to get the flue kit from any Rinnai resellers.
There are many different flueing options existing for Rinnai Energysaver depending on where you wish to install it (by a licensed gas fitter only of course).
Depending on what flue kit you need for your own situation you could be looking anywhere between $150 to $800 (AUD).
Go on their website for a list of resellers.
Mar 19, 2013 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
We have a RINNAI ENERGYSAVER 1001FT, if power or gas has been turned off, it takes several attempts to restart it.
If the gas was tunred OFF, yes it would take several attempts for the pilot to light. Because, there is air in the line from the gas line shutoff valve to the heater. Once that's purged, the heater should light. The electrical power shouldn't affect it. Unless, the heater hasn't been serviced in the last year. Unfortunately, they are not maintenance free.
Jul 06, 2011 | Heating & Cooling
How to install
Unfortunately, the installation of one of these units is not quite as simple as 1, 2, 3.
So, I am providing a couple links on the installation process. You can download and print each one.
The first is the Flue Installation Guide.
http://www.rinnai.com.au/images/stories/operating_instructions/Heating/Energysaver/CI_ES_Flue_Inst_Manual.pdf
The second is the Operation Guide, which also deals with proper installation.
The third is the exploded parts view & parts diagram, Which you may need in the future.
I hope all of this information will help you properly install the unit.
Jun 02, 2011 | Rinnai EnergySaver 556 Air Conditioner
I need to find an exhaust manifold for my Rinnai energysaver 1001FT
I'm sure you have looked but the best bet is to go through Rinnai and find local parts dealers or installers who can get you the parts.
Always willing to help, let me know the area you are in country etc.and I will see if i can recommend anyone.
I have contacts in Oz and NZ.
I can also send a link for the parts if that helps or just look up the model you should find a pdf..
Exhaust fluing for these units is tricky to specify as there are lots of different parts available depending on how you want to run the pipe. Recommend getting someone in who has good experience installing these as this will save alot of time (and money). We used to get so many installers trying to return parts that were incorrectly ordered.
Aug 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Have inherited a Rinnai energysaver 1001 FT gas heater - need an exhaust manifold
Found a link to the service manual for starters
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/225.pdf
The flue system looks very similar to some current models. I'd go to Rinnai direct and try and get a list of local service agents who can order the bits in. The flues are very tricky to order because there are so many different bits depending on where you need it to run so order carefully.
Jul 30, 2010 | Rinnai Heating & Cooling
Error code 11 on a Rinnai energysaver 556FTR
Rachel,
The 11 code means Missed Ignition. This is a broad error code. It just means the stove did not light when it was supposed to. I would check the fuel first to be sure the valve is on and you have gas. Next, try to start the stove with the room dark. Look into the window to confirm a sparking. This is the igniter. At the same time be sure the combustion motor is running. You should be able to hear it and feel the stove to confirm this. If the motor does not turn or the flue is blocked you will not get any gas to flow. Look outside to confirm the flue is not blocked.
Keep us posted,
Tom
May 29, 2010 | Rinnai EnergySaver 556 Air Conditioner
Rinnai Energysaver 1001FT, ignites, blows 5mins then shuts down.
Sounds like it is reaching high limit...either the filters on the back are plugged, or the manifold pressure isn't adjusted properly. IF the exhaust were plugged on the unit, it wouldn't fire at all, since it has a pressure switch to verify vent flow. The slightest blockage, the unit will lock out to prevent damage to the unit.
Jul 07, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
56 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
