Question about Ruud UAMB042 Air Conditioner
Lines frosting over not cooling like it should was just recharged 1 month ago
    Problem Solver:
  • 18 Answers
Dirty evap/inside coil???....no?? got a leak...need more juice.
Posted on Jul 08, 2010
3 year old side by side hotpoint. 3 months ago freezer frosted up & would not cool. Repair person replaced heater & mother board worked until about 1 month ago. Frosted up again. Repair person...
This is the part that is bad....it is cutting off the defrost too soon...
http://www.partselect.com/PS1017716-GE-WR50X10068-Defrost-Thermostat.htm?SourceCode=5&ModelNum=hss25gft
or Click here
heatman101
Aug 02, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have two senville mini split 18000 and they both frost up with in 1 Hr. of use both have been pumped out and recharged
Dear Friend! Before recharging gas.did you check leak testing? If not, again you will same problem.
And some more reasons for frost up:
1. Indoor coil & air filter dust blocked-clean it. 2.Less rpm of indoor fan motor- replace capacitor or motor.
Thanks, it's helpful to you.
Jan 10, 2011 | LG LS-K1830CL Cool Mini Split Air...
Fridge not cooling, motor constantly running
Sounds like low on Freon find the evaporator up in freezer hiding behind back wall or under freezer floor. when removed look at the frost pattern if it is only partial covered in frost , good chance it needs a shot of gas Freon like stuff gas. not sure in your areas what requirements costly in The Great White North. But if there is only a great block of ice from four my best seen it started right where the door panel ends and freezer began 36 hours to defrost. So if ice cube is what greets you Defrost Problems check Defrost timer stuck, Defrost thermostat, Defrost Element, check all wiring in freezer were the last 2 are located.
Mar 17, 2017 | KitchenAid Refrigerators
The refrigerator side is not cooling. I can see frost buildup on the back of the freezer compartment. Freezer is fine. Same problem 1 month ago, defosted and things were fine until now
There is a flap the seperates and controls the air flow from fridge to freezer, they have a tendency to freeze stuck in one direction. Otherwise they can also brake or agitator that controls the flap may be faulty.
Jul 07, 2009 | Maytag MSD2756G Side by Side Refrigerator
(Frigidair refrigerator R134a system) 3 months after a new compressor was installed it stopped cooling, it leaked. I found and repaired the leak. Then bought some automotive R134a it had dye,conditioner,...
The stop leak probably stopped up your cap tube system and the filter drier.You can try by replacing the filter drier, vacuum the system to 500 microns and recharge.The automotive 134a is the same as any other 134a.
Jun 08, 2009 | Frigidaire Refrigerators
How to recharge freezer electrolux FFH17FC7CW0
HI, It is a big job to recharge a unit. If it need recharged, it means there is a leak. Do you have any cooling at all? If this a self defrosting freezer? If it is self defrosting, make sure there isn't any frost building up on the evaporator panel.
Vic
May 21, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Fridge part is not cooling; freezer is frosting up
your ref. has a defrost problem.you will need to take back panel off inside freezer and take your hair dryer again and defrost the system.then you can check your heater,thermostat which is located at top of coils that were defrosted.sometimes the thermostat will pop and not allow it to go into defrost and you need to check defrost timer.
Mar 12, 2009 | Refrigerators
GSS22WGPD WW GE Side by Side Refrigerator
first remove freezer panel in back and check frost pattern on evaporator coil while ref. is running and evap. fan disconnected. should be totally covered in light frost.
Aug 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge and freezer not cold enough since we moved
remove the panel at the reaar of the freezer. you should have a full frost pattern on your evaporator (frosted not snow packed) and the fan should be running. if you do not have a full frost pattern then you have a sealed system leak. covered under the first five years of your warranty
Feb 17, 2008 | Whirlpool ED5SHAXM Side by Side...
Ruud UAMB042 Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
