Question about Camco Battery Fridge Refridgerator Alarm Rv Motorhome
I have a coleman cheyenne 2000 pop up camper and none of the lights will turn on to include the carbon monoxide alarm. All of the outlets work fine. We checked the fuzes and flipped the switch. We also disconnected and reconnected all the plugs. We tried the switch under the gallay but i do not have a multimeter to check the switch. The two cables are connected to the switch. The converter fan is not turning on. Any suggestions
  • Mike Butler
    Mike Butler Jul 10, 2010
    Did you check 30 amp main fuses in converter, or on back of it, depending on what model it is? Do you have a breaker for power to converter, or does it plug in behind it? If it plugs in behind or elsewhere, try a light or something else in that receptacle and see if it works to indicate power to plug. Let me know what you find.
  • Pam Thill Jun 27, 2013
    I am having this same problem! Outlets and air work! Lights on ceiling and frig. Won't work.
When towing my camper it seems my running lights do not stay on andmy brake lights and turn signals do not work properly. I can giggle the harness wires and everything works.
Posted on Apr 19, 2011
My camper has been in storage for 2 months. The carbon monoxide detector beeps every 30 seconds. I pushed the reset button and it does no longer beep. Is it still safe to use this detector?
Dale, My alarms beep like that to warn me of batteries needing replaced. What I do is hit the test button and ensure it sounds. I would still replace the battery(ies) and retest when you do.
Mar 07, 2015 | Kidde Carbon Monoxide Alarm Model Kncobb
How do I dispose of Carbon Monoxide Alarm & Fire Alarms?
If it's no longer working, just discard in trash. It doesn't contain any hazardous materials. If it's still working, then donate it.
Sep 23, 2014 | Kidde DC-Plug-In Carbon Monoxide Alarm...
Need 2000 owners manual for coleman niagra pop-up camper
Try this link
http://www.popupportal.com/index.php?action=media;sa=item;in=2985
Apr 23, 2012 | Coleman 10' X 10' Sundome Tent 9160K101
I have model kn-cob-lcb-ca...it does not have a digital display, it was made in 2009..a few nights ago it started beeping...4 beeps, 5 second pause then 4 beeps continuously..the manual says this is a...
send the detector back and have it replaced,
The CO sensor will not alarm to levels of CO below 30 ppm and will alarm in the following time range when exposed to the corresponding levels of CO: 70 ppm CO Concentration 60 - 240 minutes 150 ppm CO Concentration 10 - 50 minutes 400 ppm CO Concentration 4 - 15 minutes The alarm shall include a piezoelectric horn that is rated at 85 decibels at 10 feet. When the unit detects carbon monoxide, the alarm pattern will be four (4) short beeps - followed by five (5) seconds of silence - followed by four (4) short beeps. The unit shall incorporate 2 LED's. A green LED will be illuminated to indicate the alarm is operating properly when plugged into an outlet, and will flash every 10 seconds when on backup battery power. A red LED will flash to indicate that carbon monoxide has been detected until the device is reset or CO is eliminated or will flash to indicate low battery or alarm malfunction. The unit shall at a minimum meet the requirements of CAN/CSA 6.19-01. It shall also include a 10-year manufacturer's limited warranty or
Test/Reset Button - Tests the unit for proper operation. Resets the carbon monoxide alarm.
• Tamper Resist Feature - If activated, unit goes into constant alarm mode if it has been unplugged or has come loose from the outlet.
Sep 20, 2011 | Kidde Nighthawk Combo Gas/co Detector
Good Morning, My nighthawk CO detector went off with a loud continuous alarm this morning while all were sleeping. I reset it and it is not alarming now. I pushed the peak button and it reads 19. The...
When a carbon monoxide detector sends an alarm, there is cause for concern. You mentioned that the other CO detector did not go off, but maybe it is too far away to monitor the carbon monoxide levels that was in this area.
The instructions in your manual would direct you to evacuate the house immediately and ventilate. Your next step is to get a professional to inspect what may have caused the carbon monoxide leak.
A reading of 19 indicates that there is carbon monoxide in that area of your house, unless your CO detector is not working properly. Your local fire department will give you the best advice for what action to take when a carbon monoxide detector sends an alarm.
Be safe, don't assume a carbon monoxide alarm is cause by a defective CO detector, have it inspected.
Jul 30, 2010 | Kidde Nighthawk Combo Gas/co Detector
My nighthawk carbon monoxide alaram is keep biping
Check your user manual for issues dealing with beeping alarms.
Your local fire department may be able to help educate you on the proper installation and use of Carbon Monoxide Detectors. A CO detector alarm should be taken seriously and you should follow the manufacturer procedures included in the package.
NEVER dismiss a Carbon Monoxide Detector Alarm for a malfunction.
ALWAYS treat an alarm as an emergency and follow manufacturer procedures.
Check our website for more industry information or for buying replacement Carbon Monoxide Detectors.
Jul 16, 2010 | Kidde Nighthawk Combo Gas/co Detector
Where or how do I get a owners manual for a 1997 coleman by fleetwood - cheyenne pop-up camper?
You can visit the web-site www.managemyhome.com which may take you to www.managemylife.com. This web-site provides user manual and troubleshooting steps to fix it on your own.
You can give it a try.
Vinay
May 01, 2010 | Coleman Refrigerators
My First Alert Carbon Monoxide Alarm has failed
If the carbon monoxide detector chirps, the battery may be dead. New batteries can be defective. Check if the light is yellow when the alarm is chirping, it means the battery is low, replace with a new battery.
Warranty service information:
UNITED STATES
BRK Brands, Inc.
3901 Liberty Street Road
Aurora, Illinois 60504
For consumer inquiries call: 800-323-9005
CANADA
Jarden Branded Consumables Canada
88B East ****** Creek, Unit 6
Richmond Hill, Ontario, Canada
L4B 4W2
Tel: 905-482-3720
Fax 905-731-8267
For consumer inquires call: 800-323-9005
If you are looking for new Carbon Monoxide Detectors, visit my website.
Oct 01, 2009 | First Alert Safety & Security Carbon...
Same alarm problem setting offf
As a camper myself, I know that one of the last thing we check is our Carbon Monoxide detectors in our unit. I had an old Class C motorhome with a CO detector that failed to alert me, and my kids got to the point of being nauseous. We were lucky to discover the problem.
A Carbon Monoxide Detector needs to be changed after 5 years because the sensor is designed only to last this long. If your unit needs to be changed, you can shop online on my website http://carbonmonoxidedetectoralarms.com/
Good luck and happy trails.
Jul 02, 2009 | Safe T Alert Carbon Monoxide Alarm Rv ...
I have a Class C motorhome. The unit is in storage and when I arrive to check on the motorhome, the alarm is going at low alarm or needs replacing noise. I had the unit checked as well as the motorhome....
hi chuck. the source of the carbon monoxide is outside of your unit. for example other engines running near by sending fumes into your unit and setting off your alarm
Jun 25, 2009 | Safe T Alert Carbon Monoxide Alarm Rv ...
Camco Battery Fridge Refridgerator Alarm Rv Motorhome Logo
661 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
Mike
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
