Question about Frigidaire Heating & Cooling
Unit does not cool. Original unit was replaced because of defective compressor. Replacement unit worked in store but now does not cool and alternates blowing cool and warm air.
  • mb623 Jul 08, 2010
    This is a new wall unit and the compressor was defective on the first unit. The second one operated well at first, but malfunctioned after only 2 days.
  • 674 Answers
Is this a window unit? Sounds like the compressor may be cutting on and off. That would cause the alternating air temp you are feeling. Make sure the condenser fan is running. If it isn't running head pressure will build up on the compressor until it shuts down. Then the pressure will equalize and the compressor will kick on again. Also check your filters and the condenser coil to make sure it is clean. Let me know what you find.
Posted on Jul 08, 2010
Not cooling
this unit has 2 evaporators one for freezer and one for the refrigerator side,if both are not working(cooling) then its your ptc overload relay on the compressor thats defective,unplug the old ptc off the compressor and get an exact replacement and this will take care of your non cooling problem
Feb 24, 2011 | Samsung RS2630SH Side by Side Refrigerator
MSZ-A26YV only blows air now, (no heating or cooling), no error indication. Worked all fine one day then few days later stopped. Emergency switch does the same. Looks like the external unit fails to pump...
try to check your compressor if working if not check electrical parts like capacitor. overload if defect replace. also try if compressor working observe the condensing unit fan blowing hot air if not theres possibilities of leakage of refrigerant gas need for braze leak then recharge refigerant gas. or possible compressor loose compression need for replacement.
Feb 12, 2011 | Mitsubishi Heating & Cooling
Hi I have a goodman MSG-18HWN1 heating and cooling mini-split unit. The unit keeps going on and off on a cycle of about 5 minutes. 5 minute, unit not started, unit starts for about 5 minutes, stops for...
Due to abnormal temp of out door.Check outdoor fan motor and compressor and also sensor.
Fan motor not working- rectify/replace fan capacitor.
Sensor defective-Replace it
Compressor high amps-Replace running capacitor.
Sensor misplaced or defective-Place correctly or replace it.
Jan 05, 2011 | Heating & Cooling
Light is on, temp is set to cool, but the unit is NOT cool. The unit is 10 years old.
as old as the unit is the compressor has most likley gone bad. For this size compressor the replacement should not cost that much. You can call an appliance repair shop and let them know you unit and that you need a new compressor installed they should be able to quote you a cost on replacement.
Good luck hope this helped
Dave
Feb 22, 2010 | Marvel (6SBARBSG) Wine Cooler
How to locate and replace defrost timer. Seems to stick in defrost mode.
Your unit is not a self defrosting freezer and consequently has no defrost timer. There are only four components required for cooling in your unit. The temperature control, behind the knob in the cabinet. The compressor at the back bottom. The start relay and overload in a box attached to the compressor. The run capacitor attached to the start relay. A failure of any of those will cause the compressor not to run.
Check the wall outlet to be sure you have power.
If the compressor IS running but not cooling, the compressor itself may be defective or the gas charge may have leaked out. Compressor and refrigeration problems are likely beyond your capabilities in terms of knowledge and equipment.
The temperature control may be tested by all connecting the wires of the control to ONE terminal after unplugging the freezer and marking down teh original locations of the wires. If the compressor runs and cools after this by-pass then change the control and return the wiring to the original locations.
If the above does not make the compressor run the next possibility is changing both the relay/overload assembly AND the run capacitor. If these fail to correct the problem you need a new compressor but you will likely NOT be able to return the parts replaced.
Good Luck
Sep 27, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Ac units in apt. is fully charged,but it blows cool to cold air and will constantly run all day with out shutting off. at night when it cools off outside it will run like its supposed to. the fan unit...
Your ac thermostat is defective and not switching off the compressor resulting in excess cooling and need replacement. Also ensure that all doors and windows are closed. Could be some window is opened behind the curtain without your knowledge. That could be yet another reason for your unit continuously running.
Finally check your relay unit and this should solve your problem!
Jul 10, 2009 | Heating & Cooling
Noisy unit, not cooling well, water drip from air intake
First please check the air filter and clean it and refix it.
Please check the refrigerent level next if it continues. Refrigerent leak will result in poor cooling and enhance the noise level.
The compressor could be defective and might take high power to run and only replacement of the compressor could improve the working condition.
In case the unit is more than 5 years old it is wise to replace it with a new unit and save your power bill.
Jul 06, 2009 | Dometic Heating & Cooling
Refrigerator problem
I have a Magic Chef 3.6 cu. ft. Model#mcbr3605 thats 3 years old and has stopped working. When I plug it in you hear it start then you hear a "click" and it turns off. If you leave it plugged in the compressor gets hot. Can this be fixed or is it trash ? Thanks in advance.
Sep 01, 2008 | Magic Chef MCBR440 Compact Refrigerator
REPLACE COOLING FAN ASM
well if your condenser fan shot out, i'd advise that you shouldn't use the unit but all your doing buy putting the fan is doing the job of the defective one. but your causing more stress to the compressor and system, your forcing it to "work overtime" so technically you are cutting the compressor's life
May 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Heating & Cooling Logo
169 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
