Question about Kodak EasyShare C310 Digital Camera
Trying to format screen says filesys error e00100 how do you fix this
  • 85 Answers
If you already try to fromat the memory card into the camera and there's an error come.try to format your memory card from your computer if you have card reader.if the problem still occur you memory card have a problem and you need to buy new one.
thank you
Posted on Jul 08, 2010
SOURCE: formating new 2gb card get error message filesys error e00100
just format it on fat32 file system
Posted on Jan 04, 2009
SOURCE: it says the memory card
The Kodak Z612 only accepts standard SD cards up to 2GB. As you rightly point ot the physical charactreristics are identical, its the internal format of the card that defines SDHC.
Standard SD cards use FAT - which has a 2GB limit.
SDHC cards use FAT32 - which has a limit of 32GB.
Stick with 2GB or smaller standard SD cards.
Posted on Jan 16, 2009
  • 34 Answers
SOURCE: FILESYS ERROR E00100
Which size has the card?
Is the write protection enabled?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Posted on Jun 09, 2009
Obertelli
  • 3006 Answers
SOURCE: i have a kodak c310, trying to format the card and
The c310 will only accept SD cards up to 2GB.
You haven't said which card you're trying to use but the symptoms are typical of those encountered if you try either a larger capacity SD card (which go to 4GB maximum) or if you're trying to use a later SDHC (the HC means High Capacity) card. The c310 was designed and manufactured before SDHC cards were manufactured and is incompatible at the basic hardware level. SDHC's will fit inside as they have the same form as SD cards, but your camera is unable to use them.
If you have tried using the wrong card then all you need to do to fix the error is to replace it with a standard SD card not exceeding 2GB. In practice you'll find that your camera may have issues with some brands/models of 2GB SD cards but that it will work fine with any make or model of 1GB SD card. The smaller capacity card will also ensure that your camera does not become awkwardly slow in operation.
Hopefully I've answered your question; all I ask in return is that you return the favour by rating my answer.
Posted on Oct 21, 2009
  • 11967 Answers
SOURCE: tried to format sd card screen reads filesys error
E-mail your question to this address: http://www.kodak.com/global/en/service/contactKodak/email/consumerDigital_contact.jhtml?pq-path=13452
Posted on Jan 10, 2010
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
Cannot format sandisc 2GB memory card in my Kodak easyshare CW330 camera. it says filesys error e00100
Use a card reader and format on a PC. When card is inserted go to my computer and the disc should be there, right click and go to format then proceed as per screen instruction.
Dec 29, 2010 | Kodak Easyshare C190 12MP Digital Camera...
Trying to format screen says filesys error e00100, camera wont format chip, chip is brand new.
Your Kodak camera can only work with a card that has a capacity of 1GB MAX anything more and it just wont work.
Aug 10, 2010 | Kodak EasyShare C310 Digital Camera
Tried to format sd card screen reads filesys error e00100 kodak easyshare c330 card is a kingston 4 gb
Jan 09, 2010 | Kodak EasyShare C330 Digital Camera
Filesys error e00100 when attempting to format a Scandisk 2.0 gb memory card.
Hi ,Welcome
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 02, 2009 | Kodak EasyShare CD33 Digital Camera
    Trouble Formatting New SD card
    try to format using a card reader through PC...
    Feb 10, 2009 | Kodak EasyShare V803 Digital Camera
    FILESYS ERROR e00100 2.0GB PNY technologies
    try formating
    u get warranty on this and hence approach the point of sales
    Jul 01, 2008 | PNY 2GB microSD Memory Card
    Formatting c530
    Your camera will only accept a 1gb card Max! Go to www.kodak.com/support
    May 24, 2008 | Kodak EasyShare C315 Digital Camera
    Kodak EasyShare C310 Digital Camera Logo
    556 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
