Question about FUJIFILM instax mini 7 Digital Camera
Camera flash is not working. Batteries in the
Camera flash is not working. Batteries in the camera have been replaced, but the flash still doesn't work. Is there a replacement part available?
    Sergeant:
    Champion:
  • 230 Answers
If camera flash is not working it must be the high - intensity discharge (HID )lamp of the flash assembly that got busted which needs to be replaced. Parts are available in every local camera shops and they are not that costly. So consult your nearest camera repair shop and have it replaced with a compatible HID flash lamp.
Take care!
Posted on Jul 08, 2010
Pilot light not lighting on 420ex speedlite canon flash
This may seem dumb to ask but have you made sure all batteries are fresh (even new ones can be bad), they\'re inserted correctly observing polarity and the contacts are clean in the flash? (You can clean them using a clean, dry pencil eraser and a Q-Tip dipped lightly in alcohol.)
Also, try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
Feb 28, 2013 | Canon Speedlite 420EX TTL Flash
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
It doesn't power on
Your camera can be defected. If you buy new batteries, and it still doesn't work, than you'll probably want to send it back to the manufacturer. First, call them and tell them your problem, and if that doesn't work, than you might want to carefully examine your camera, to check if everything is in the correct place, and their all working correctly.
Jun 11, 2012 | Canon PowerShot A560 Digital Camera
Toshiba ds-r0227 remote not working
to check if its working, use a camera phone, point the remote at the camera, you should see it flash on your screen,if its doesn't then its kaput!
May 29, 2012 | Computers & Internet
Why does my instax mini have three lights flashing?
According to the manual, you need to replace all the batteries with fresh ones, preferably camera ones, and all the same power/brand.
See the Flickr thread about this - seems like this works some of the time, so if it doesn't work first time, try switching to another set of four batteries and see if it's fixed.
http://www.flickr.com/groups/instax/discuss/72157622943415896/
May 09, 2012 | FUJIFILM instax mini 7 Digital Camera
I have a kodak easyshare c533 camera and it won't turn on. I tried new batteries but all it does is flash the green light. Any ways to fix this?
Green light flashed, turned red, lens would not open. Put in new rechargeable batteries, still nothing. Someone here suggested to try regular AA cheapie batteries. IT WORKED!
Nov 09, 2010 | Kodak EasyShare C533 Digital Camera
The blitz doesn t open at all
at what mode ?
are the batteries fresh
try P mode and press the flash realse button on the camera
if this doesn't work it probably is defective ..
Apr 30, 2010 | Fuji FinePix S5700 Digital Camera
I have a kodak v603 when i try and turn it on i have a red light that flashes under the camara icon on the top left next to the screen. the camara dosent seem to work at all. can any one please help thanks
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 01, 2010 | Kodak EasyShare V603 Digital Camera
The lens will not go back in and it flashes a green light in the back. It has not been dropped and it only is one year old?
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 31, 2009 | Kodak EASYSHARE M1063 Digital Camera
My m340 will not turn on. the small green light flashes once then nothing
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 4. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 10, 2009 | Kodak EASYSHARE M340 Digital Camera
FUJIFILM instax mini 7 Digital Camera Logo
1,434 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
