Picture and sound goes in and out sometimes it will work fine but for the most part now no picture or sound
  • 4,234 Answers
There are many potential causes of this problem. Depending upon the make and model, the solution will change. Can you please post the make and model? Also, is there any pattern to when the problems seem to occur? In other words, does the problem occur more frequently when the set has been on for a while? or more when first turned on?
Answers to these questions should allow us to prpovide you with potential solutions and costs for those solutions.
Dan
Posted on Jul 08, 2010
TV works fine for 12-18 hrs. Then picture goes off
It seems that your unit has some sort of Thernmal problem or a problem that is shutting down the Power Supply section to the Video side of things.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 21, 2010 | Mitsubishi VS-6055 60" Rear Projection...
Direct TV DVR sound/no picture or pict. no sound
My Direct TV has no sound or picture but does show channel info at the top. Any help is appreciated.
Dec 13, 2008 | Directv (R10) DTV Receiver / 70-Hours...
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No sound on my 8year old panasonic tv.
It worked fine yesterday. Sound on all channels. Sometimes the picture goes black on channel 6. We can get it back by going up one channel, then back to 6. it is due to cable signal ie weak. now there is no sound this is due to sound section 1 loose connect in sound section 2 speaker 3 problem in sound section some part must have failed.
Sep 17, 2007 | Panasonic CT-32SX12 32" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
