Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool cabrio WED6400SWD
FI Signal on water supply cycles, on all selections. Cheched hoses and strainers.
    Genius:
  • 1,028 Answers
Probably fill valve ..one of the coils that controls flow to various dispensers may be bad an ohm meter for continuity ckd would be helpful
Posted on Jun 25, 2008
How open wed6400swd
This is my home movie showing a cabrio dryer and how to put it back together. It is not too difficult:
Jun 26, 2014 | Whirlpool Cabrio WED6400SW Electric Dryer
My whirlpool cabrio washer shows LF code
Verify inlet water valve is functioning correctly by selecting each temp while machine is running. Usually COLD temps will run just
ever-so-slightly faster than HOT temp and WARM temp will run faster than both temps separately. Rinse cycle is usually COLD water so i'd suspect the COLD side is malfunctioning. Hope this helps. If not let me know.
Jan 23, 2013 | Whirlpool Washing Machines
Whirlpool Cabrio Platinum water is coming back out of the hot hose
You have a hot , cold and a mix valve ,I would suspect that the mix valve is stuck, try tapping on it
Whirlpool W10372095 Valve AppliancePartsPros com
May 26, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
We can only use hot water in our Whirlpool 7.5kg WFE1070BD 1000RPM - how to we shut off the hot water and use cold water? We have tried only cold but the machine will not operate. Please help. Many...
Turn off the water to the machine. Disconnect the cold water hose from the back of the machine and put it in a large bucket. Turn on the water to see if you get full-pressure cold water from the hose. If not, the shut-off valve or other plumbing has a problem.
If you do get cold water from the hose, check the strainer inside the hose fitting on the back of the washer. Clean it if it is clogged. If you still don't get cold water in the machine, you have a problem with either the solenoid valve or the cold water fill contacts in the timer (the timer won't start until the tub is up to the selected level, but if the valve isn't opening or the supply line is otherwise blocked, the machine will never fill). Sometimes in this case you can hear the solenoid valve humming (normally the sound is masked by the running water).
If the problem is a clogged strainer, clean out the hot water strainer also.
I find I get better wash results with warm water (runs both hot and cold for the wash cycle). The soap is more active than in cold water, so I don't need quite so much, and the machine doesn't take as long to finish a cycle since it fills faster. Of course, the cold water has to be running to get the energy savings compared to hot only.
Jun 06, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Our washer is showing an NF code while biginning the washing cycle
NF = No Fill Error
Check your hose inlet strainers.
Be sure they are free of contaminants.
Turn off the water supply - remove the hose.
On the side of the machine is a small metal strainer which catches debris in the water line.
Remove it using a small screwdriver and clean it.
Otherwise - your water valve is likely failed. (or the CCU not giving it the signal to open) so further testing will be required.
Thanks for using FixYa!!
Feb 03, 2011 | Washing Machines
I have a whirlpool Cabrio, what does LF error code mean and how do i fix it??
The LF error is a water supply fault. Both water supplies must be connected and fully opened. The inlet hoses and valves both have strainers that may need cleaning as this could obstruct the water flow and also check that you don't have any water leaks. The unit requires a minimum water pressure to operate so anything that could prevent the unit getting this pressure will cause this fault. Hope this helps you out!
Nov 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
It is leaking from the bottom during the wash cycle. What is going on?
If you mean its leaking anytime you have water in the drum,the first thing to check is the drain hose connection at the back of the washer,You'll want to do this with the washer pulled out,(don't let the drain hose drop below the water level or you'll have a mess)If its not leaking there you should be able to look under the washer & see which connection it is(usually the inlet to the pump) Might be as simple as tightening the hose clamps.Hope this helps
Jan 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Whirlpool cabrio
LF means long fill, so if your hoses arnt blocked and you are getting good flow, try looking at your drain pipe, it should only go about 6 inches into the actual drain and zip tie it there. any further it could syphon the water out of your machine.
Apr 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
160 people viewed this question
Dan Webster
Dan Webster
Sal De
