Question about Kenmore Ovens
How to remove warming drawer on oven
How does one access ignitor on kenmore gas oven mod # 790.75862301
  • 142 Answers
SOURCE: My oven isn't warming up
can you verify the ignitor is working (ie: can you hear it sparking)?
1. If no, and you are absolutely sure there is not a buildup of propane inside the oven (or house for that matter), you can try lighting it with a match. If that works, you need to replace/reposition your ignitor.
2. If yes, do you smell propane after trying to light the oven?
A. If yes, STOP and get it fixed..
B. If no,
1. Check to see that your propane tank isn't empty?
2. Verify the regulator supplying the oven with propane is actually sending gas to the over (might need a repairman for this)
Posted on Apr 06, 2008
localwonder
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
  • 89 Answers
SOURCE: Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
Posted on May 27, 2009
localwonder
  • 6784 Answers
SOURCE: after self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Posted on Jun 03, 2009
  • 220 Answers
SOURCE: My Kenmore Warm and Ready drawer self cleaning
Hit cancel or kill the power at the electrical/breaker box.
Posted on Sep 03, 2009
Bake cycle wont work gas kenmore with electric controls you can set temp it goes to preheat and nothing happens broiler works and all the tops work
here is a tip i wrote covering that
What the problem is when your gas oven ignitor glows,but no heat for the...
MessageRate.ThreadID = 9947539; MessageRate.ProductID = 0;
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Aug 03, 2011 | Kenmore Ovens
The oven would not light, the broiler works and the stove top but the oven would not light up
the ignitor bar underneath the bottom of the oven bottom is bad and you need it replaced,remove the pan drawer to access the mounting screws and wires to it
Nov 26, 2010 | Maytag CWG3100A Gas Single Oven
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Kenmore gas oven 362.7163191 wont light, what could be the problem ?
    The glow bar ignitor in the oven is going bad. Remove the oven racks. Remove the base pan in the oven. This gives you access to the glow bar.
    Turn the gas off to the oven. Place a clamp on amp meter on one wire of the ignitor and turn the oven on to Bake. If the amp draw is 3.2 or less,replace the glow bar ignitor.
    Nov 22, 2009 | Kenmore Ovens
    On my gas kenmore oven, the oven first wouldn't get up to temperature, and now 3 months later it just doesn't heat at all. There is no gas smell or indication that there is a pilot light. My gas broiler...
    Replace the glowbar ignitor in the oven. Turn off the gas supply. Remove the oven racks. Remove the base pan in the oven to access the ignitor. Most plug in. Some have wire nuts.
    Your local appliance parts store will need the model number or the ignitor for a correct replacement.
    Oct 31, 2009 | Kenmore Ovens
    Kenmore gas oven won't light. The pilot light is on but no gas. What do I do?
    Put a torch on the probe. If the flame comes on them the thermocouple is weak.If nothing at all replace the safety valve.That is if you have a standing pilot. If you pilot is an electric one then it should be so bright it is hard to look at but if it is dim orange it is weak.
    If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
    Sep 07, 2009 | Kenmore 30169 Electric Single Oven
    Electric warming drawer will not heat
    Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
    Feb 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    Kenmore Gas Oven
    Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
    Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
    rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
    Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
    Feb 05, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
    790.7921
    Does the bottom ignito glow when the "bake" option is selected? If not, replace the ignitor. Even if it glows, it may not be achieving the electrical resistance value needed by the safety valve to open thus allowing the gas to flow to the burner.
    Aug 23, 2007 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Ovens Logo
    285 people viewed this question
    Top Kenmore Ovens Experts
    Are you a Kenmore Oven Expert? Answer questions, earn points and help others
