Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
How do I adjust the carburetor on a Poulan 38cc chainsaw? Someone has messed with the low and high adjustment
    Brigadier General:
  • 4,088 Answers
Turn both jet screws CW to stops (lightly), then back out CCW 1-1/2 turns each. This is a basic setting and the engine should start and run. Be sure to check the fuel filter, air cleaner, and muffler for plugging. Start the engine and allow to warm up--pull the throttle full on and adjust H jet needle CW until the engine starts to speed up, but still 4-stroking. Proper adjustment is reached when the engine 4-strokes at speed, but immediately 2-strokes when cutting. Release the throttle and adjust L jet needle CW until the engine idles fairly well, but will allow the engine to 'follow the throttle'. Set the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
Posted on Jul 09, 2010
How to adjust carb. on a poulan chain saw 38cc model 2175
If the carb is adjustable, it will have two small screws on it ( maybe covered with a plastic cap) One is low speed and the other is high speed. Adjust very little at first.
Sep 24, 2014 | Garden
Adjust idle up on poulan pro 42 cc chain saw
Adjust the low side out another quarter turn first before messing with the idle screw.
Sep 15, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Solo 662 chainsaw carburetor adjustment
most non professional grade or smaller saws are only adjustable by re jetting the carb. if they are adjustable there will be a low, high and idle adjustment on the side of the carb, however unless you have a portable tach and know the rpm limits or are experienced doing it "by ear" i wouldnt suggesting messing with it as youll more than likely burn up the power head.
Jan 08, 2014 | Solo 662 667 Chainsaw Carb Carburetor
The small saw serial #1J295L669 starts O.K. and runs for about a minute, but then dies on me. there is a high and low adjustment screws;however the cover over the carb. seems to have an effect before and...
Most of carburetor has three buttons to adjust. L (low), H (high) for fuel injection at low and high speeds. There is also a minimum (the chain must be stationary if it is well tuned). The chainsaw is set at low rpm throttle with screws ( L ), and its vivacity is set at high speeds ( H screw ). In the beginning is good put both to set at 1.5 turns from full closure. And then, if the chainsaw starts, you can adjust a carburetor work. Careful with adjusting with H due to high speed.
Sep 06, 2011 | Poulan Garden
How do you adjust the carborator on a 2.5 stihl chainsaw?
Most Stihl carburetors built after 2000 have limiter caps that prevent much adjusting. the standard for adjustable carburetors is 1 turn out on both high and low then set rpm of idle and high end to specs.
If you need to adjust the engine to get it running there is a problem somewhere else in the systems.
see a dealer like www.arcolawn.com for help.
good luck
Nov 07, 2010 | Poulan Pro 14" Gas Chainsaw 33CC P3314
The screws do not have a flat head? How do I adjust the carb?
if you have plastic caps on the screws you have to pop them off to turn the screws. some screws have a slot and some don't.
for the one's that don't use a pair of needlenose plyers to turn them.
Jun 23, 2010 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Hi, I have a Poulan Model 1800 and previous owner has messed with air and gas mixture adjustments. I can fire it up and run it full throttle but it dies out at low speeds - idle adjustment makes no...
The default setting for the H and L carburetor jet is usually to turn them in all the way till they stop and back them out a turn and a half. You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Nov 28, 2009 | Computers & Internet
My idle is struggling
start out with both of them set at 1 1/2 turns out and then fine tune from there if needed. hope this helps you
Oct 05, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Base adjust. on carb high and low needles on carb polen 42 18" thanks
The standard setting on needles is to screw them in all the way and then back them out 1 and a half turns.
Oct 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
1,303 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
