Question about Car Audio & Video
My ADF-242 amp
It needs to be repaired parts are burned out.
  • 52 Answers
It would be cheaper to buy a new one than to take in to a service tech
Posted on Apr 20, 2008
My HP Officejet Pro L7780 faxes off & on. Motor is running w/in ADF, but the pick assembly does not grab paper
There should be a textured seperator pad, if that's worn out, replace it. Also check the ADF rollers should not be smooth. You may need to just replaced the ADF maintenance kit. It should include the roller assembly and seperator pad.
Jan 17, 2013 | HP Officejet Pro L7780 All-In-One InkJet...
Repair and parts manual for rmm air compressor model#DB1552
I believe this is a product made in Taiwan. Check out the site Unoair.com.tw I can get parts as I deal with a local distributor of Unoair. Some parts are generic anyways. Doug 513-242-4500
Oct 20, 2012 | Air Tools & Compressors
HP M3035 ADF has two black plastic pieces that interact with the roller gear assembly. One black piece has a cutout that fits around the blue button that you press to release the roller gear assembly and...
Unfortunately for this model the ADF section isn't broken down into it's individual components,
the part numbers available for the ADF are as follows: (direct from the Service Manual)
Control Panel
CB414-60101
Cover, ADF
CB414-67902
ADF feed roller kit
CB414-67904
Input tray, ADF
CB414-67903
ADF assembly
CB414-67916
Scanner assembly (ADF assembly is not included)
CB414-67905
However your best bet would be to call around to all of your local printer repair shops in your area and asking them if they have any of these M3035's sitting around for spare parts.
Otherwise I could try to find a good picture of the ADF Feed roller kit and see if it contains the parts you're looking for.
Hope this helps! If so please don't forget to leave a positive review for me. :)
Jun 07, 2011 | HP LaserJet M3035xs MFP All-In-One Printer
Íå óñòàíàâëèâàþòñÿ äðàâåðà íà çâóê
3Ware RAID card is the only game in town!
Use SSD for parity to best performance.
IDE is slow.
Use SATA or SCSI 3Ware card for the job.
Jan 25, 2011 | Computers & Internet
Error 3
Hi Adil,
This E3 error message means ADF backside scanning optical alarm (upper optical unit ADF) which indicates ADF (back) lamp intensity check. Please follow the steps provided below:
1. Is the lower glass (white sheet guide)of the reading section dirty?
Open the ADF, and clean the sheet guide (white part) and the glass.
# When operating the scanner, the ADF’s inside glass becomes very hot. Take serious caution as the heat can cause burns. Before you clean the inside of the scanner, turn off its power and unplug the AC adapter from the outlet and wait (at least three minutes) until it gets cold.Be careful not to pinch your fingers when the ADF cover is being closed.
Note: Cleaning should be done approximately every 10,000 sheets scanned, though it may vary depending on types of
documents scanned. More frequent cleaning is necessary when the following types of documents are scanned:
- Smooth surface document such as coated paper
- Documents printed on almost entire surface
- Documents processed with chemical materials such as carbonless paper
- Paper with a high calcium content
- Pages with pencil lead
- Document where toner is not fused sufficiently.
If the above does not help, then the issue is caused by any of the followings for which you may have to contact the Fujitsu Expert/Engineer.
1. Upper Optical unit ADF may be dirty. (Remove any dirt inside of the mirrors and lens of the Optical unit ADF with blow brush. Do not use air sprays which may build up condensation on the mirrors.)
2. Upper lamp may not be functioning properly.
3. The connecting cables might be damaged.
4. The connectors are not connected properly.
Hope the above information is helpful.Please revert you have any doubt.
Regards,
TechSatya
Jul 02, 2010 | Fujitsu fi-5750C Flatbed Scanner
I have a ADF-242 that is having sound output problems
If the car was running when testing sub and heard noise this could be engine noise and an inline filter would cure that problem and also have a good ground no more than 15 inches away from the amp.And good metal contact for ground.
Jun 06, 2010 | Audiofonics ADF-242 Car Audio Amplifier
My amp
4 CHANNEL-1100w MAX
HIGH ENDURANCE SLIM AMPLIFIER
4 CHANNEL [2 OHM] 110W x 4
4 CHANNEL [4 OHM] 80W x 4
2 CHANNEL MONO [4 OHM] 220W x 2
2 OHM LOAD CAPACITY
VARIABLE LOW [40-250Hz] PASS FILTER
VARIABLE HIGH [40-250Hz] PASS FILTER
BASS BOOST
RCA PRE-AMP LINE OUT
SPEAKER LEVEL INPUT
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
This is a really good site to learn about repairing amps and anything else you want to know about car audio. Are you wanting to replace the board or looking for someone to repair your amp.?
Apr 18, 2008 | Audiofonics ADF-242 Car Audio Amplifier
Amp fan not working
If you have any experiance with electronics remove the casing and check the fan with a external 12V power source. If the fan still does not work, it needs to be replaced, try and get a brushless fan as it will last alot longer.
Mar 10, 2007 | Audiofonics ADF-242 Car Audio Amplifier
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
