Question about Mitsubishi WD-52725 52". Rear Projection HDTV
My WD-52725 Projection TV will not turn on. The
My WD-52725 Projection TV will not turn on. The timer light is flashing. How do I reset? The reset button does not fix the problem.
Where is the reset button on a 65 CD Mitsubishi HDMI TV
Posted on Sep 27, 2015
I have a same problem, i press the reset button and the faulth continued
can you help me please
thank
Posted on Aug 11, 2010
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Tv won't turn on. Timer light fast blinking
either wait until the light stops flashing or press the reset button. if teh problem persist it is most likel several boards that need to be rplaced
Feb 22, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi model WD-52725 has a fast blinking timer light on constantly and tv will not power up. Tried unplugging and resetting with no success. Now What?
It sounds like you need to replace the lamp for your TV unit. Also don't forget to replace the lamp use hours timer otherwise the TV unit will not recognize a new lamp has been installed. I hope this helps. Good luck.
Sep 17, 2010 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WD-52725 Projection TV. I
Call MITS, and try to get a tech to assist. Green timer flashing is "waiting for CPU to boot". Normally 70 seconds after plug-in. If doesn't stop, then not booting, and you won't be able to turn on. It only boots after being unplugged.
Apr 22, 2010 | Televison & Video
Timer light is flashing and I cant turn on tv
The V26 DM repair kit should take care of that issue. The kit has the caps and the instructions. You can get it at www.tvrepairworld.com
Aug 03, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
475 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
