Question about Lexmark E232 Laser Printer
What does a "symbol" stand for?
Have just put in new toner cartridge. The fourth symbol out of the five on the printer is now yellow. The symbol looks like 2 dots and a graph. What is the error? Many thanks.
  • sherry h Apr 30, 2008
    I had a paper jam and now the same light is constantly on and I can't print. What does this mean?
    Thanks Shaule
    Problem Solver:
  • 5 Answers
Yep simple problem ..
step 1 : close the machine (power off)
step 2 : push the button in the right side (up) of the macheine (means with your left hand)
step 3 : open the cover and pull the toner
step 4 : normally you shoul find a remaining piece of paper not correctly printed stuck inside
step 5 : take it off..power on ..there you go :)
dr prince..
Posted on Aug 15, 2008
What is the last symbol for , looks like a exclamation mark. Printing only 3/4 of the page.
please advise.
Thanks
AV
Posted on Jul 06, 2008
HI
NORMALLY AFTER PAPER JAMS SMALL FRAGMENTS OF PAPER STILL REMAIN ON THE INTERNAL ASSEMBLY OF THE PRINTER REMOVE THESE AND YOU`RE ON YOUR WAY
Posted on Jul 24, 2008
The printer will not accept new toner cartridge
So are you getting the toner out light? The light that looks like a stack of 6 dots? Or are you getting another symbol? If you are still getting the stack of 6 dots then your new toner must be defective.
Nov 24, 2011 | Sharp AL-1217 Copier
HOW TO REPLACE THE OLD TONER CARTRIDGE WITH NEW ONE?
Here's the process:
1) Make sure that the printer is turned on. Open the front cover. 2) Take out the drum unit and toner cartridge assembly 3) Push down the green lock lever and take the toner cartridge out of the drum unit. 4) Be sure to seal up the toner cartridge tightly in a suitable bag so that toner powder does not spill out of the cartridge. 5) Unpack the new toner cartridge. Hold the cartridge level with both hands and gently rock it from side to side five or six times to spread the toner evenly inside the cartridge. 6) Pull off the protective cover. 7) Put the new toner cartridge firmly into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically. 8) Clean the primary corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times. 9) Put the drum unit and toner cartridge assembly back in the printer. Close the front cover.
That's it. You may also want to download the user manual as it has photos along with the instructions above. You can obtain that at: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Hope this helps!!
Jun 20, 2011 | Brother HL 2140 Laser Printer
I was unable to loace the Toner Cartridge. Could you please tell me where to open up and how to replace the tomer cartridge? Thank you. Regards, Lisa Li
Make sure that the printer is turned on. Open the front cover. Slowly but firmly pull the drum unit and toner cartridge assembly out of the machine. Push down the green lock lever and take the toner cartridge out of the drum unit. Unpack the new toner cartridge. Hold the cartridge level with both hands and gently rock it from side to side five or six times to spread the toner evenly inside the cartridge. Pull off the protective cover. Put the new toner cartridge firmly into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically. Clean the primary corona wire inside the drum unit by gently sliding the green tab from right to left and left to right several times. Put the drum unit and toner cartridge assembly back in the printer. Close the front cover.
If you want even more detailed information, there is a how to guide with ilustrations on each step on the Brother website.
Dec 07, 2010 | Brother HL 2140 Laser Printer
New yellow toner cartridge but no print due to "low yellow toner"
if you got the seals of of the new cartridge, then sometimes opening and closing the toner door will help the indicator go away. I have 2 of these and sometimes it takes a bit for the toner to work it's way into the system.
Feb 20, 2010 | Ricoh Aficio CL2000N Laser Printer
New yellow toner not fitting properly
try to install the cartridge again and see if it can print.or u can reinstall the printer drivers. if the problem still persists then visit below mentioned link for a free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | Samsung CLP 300 Laser Printer
Installing Epson TO88120 on Epson NX1000
On the LCD display choose the 'Reset Menu'Then within that menu keep going through the (many) options 'till you get to 'Change Toner K' (K for black, C for Cyan, M for magenta,Y for yellow).
Once you select the appropriate Toner it will rotate to offer the toner for replacing.
Open up the cover at the front, reach inside and change the position of the coloured part of the toner cartridge on the R/H side to the Unlock symbol and then ease the cartridge out. It comes out at a slight angle as the part you move to unlock it comes out slightly ahead of the other side.
Put the new toner cartridge in and turn the coloured part to the locked symbol and close up.
Please take a moment to rate this solution, thanks.
Apr 08, 2009 | Epson Aculaser C1100 Printer
Brother 2140 toner light on, won't even try to print.
To get every bit of toner powder out of the cartridge, first remove the toner unit from the drum assembly. Second, find the little circular window on the right-side of the toner cartridge. Third, place a piece of black electrical tape over the clear window, cannot be clear tape. Fourth, re-install the toner cartridge into the drum assembly. Last, put the complete unit back into your printer. This worked for me.
Apr 05, 2009 | Brother HL 2140 Laser Printer
Lexmark E250d
I had the same problem today with my printer. All of a sudden, the first and fourth light lit up. I contacted Lexmark and they said my toner cartrigde needed to be replaced.
The problem is caused by the little chip under the cartridge. I replaced the chip with an old one I had on another cartridge and I got the printer to work again.
You can buy a replacement chip from Lexmark or from a jobber selling replacement cartridge or toner refills.
Hope that helps.
Sep 30, 2008 | Lexmark E250dn Laser Printer
Keeps showing J1 error, toner light is flashing
The J1 error means the toner cartridge needs to be replaced. Since you just replaced the cartridge, you should remove the cartridge and repeat the following steps.. Shake the new toner cartridge horizontally four or five times and then remove the cover. Slide the new toner cartridge in until it locks in place. It sounds like the cover may still be on the cartridge.
May 14, 2007 | Xerox WorkCentre XD103F All-In-One Laser...
Lexmark E232 Laser Printer Logo
446 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
