Question about Microsoft Xbox 360 Console
My hp deskjet f4400 printer won't print. i have a green light on and three other ligths on in the copy setting area. i can't turn the printer off by pressing the green button.
3 Suggested Answers
AshMan182
  • 40 Answers
SOURCE: Console wont boot up
Your xbox is dying. Is it still under warrenty?
Visit http://support.xbox.com/support/en/us/nxe/default.aspx
Posted on Jan 16, 2009
penheadsprod
It's probably not dying. Just spend the time replacing the thermal paste on the heat sinks with Silver Thermal Paste from Radio Shack. Takes awhile, and you have to do it right. Don't be lazy and impatient with it while prepping the surfaces, and maybe it will all be alright. I switched out those 'X' clamps on mine with 4- 5mmX12mm machine screws, and 4 - 5mmX20mm machine screws...4 - #10 washers to even the mother board with the rest of the casing, A #10 Teflon washer on top of the motherboard(to keep it from shorting out in the future, and for heat expansion), another #10 metal washer on top of that, and then screwed them evenly into the heat sinks..Works fine now... Had to grind a few of the washers to have a flat side, and drill some 3/16 holes to make the casing holes a little bigger than factory size...but it was easy.
Posted on Feb 17, 2013
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
I have a HP Deskjet F4400 All-in-one series. Under the icon for it, there is a box that says the printer is stopped. I can click on it and it will say "Start" but below there is a line that...
Hi rjrust958,
The easiest way to correct this problem is by uninstalling and reinstalling the software and driver of the unit. Please visit this link for the updated driver of HP Deskjet F4400 All-in-One Printer series. For additional information on how to uninstall/reinstall software and drivers please visit this link.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | HP Office Equipment & Supplies
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Solution
Close the print cartridge door.
Cause
The print cartridge door is open.
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
HP 920c Deskjet feeds blank paper constantly. Will not print. Just shoots paper out.
deskjet 920c will not print, green light flashes and blank paper comes out. Printer will print test page perfectly.
Nov 07, 2009 | HP DeskJet 920c InkJet Printer
HP Deskjet 5550
Here is a HP document on what causes the green (power) light to blink and how to T/S it:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00035263&dlc=en&product=71896
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 08, 2008 | HP DeskJet 5550 InkJet Printer
Hp deskjet f4180 all in one
i have a hp deskjet f4185 all in one printer but i lost the cd. i need the sofware or it will not connect to print or scan please help me where can i get the sofware?
Feb 15, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
Light flashing printer no print
unplug the (USB or Parallel) cable of the Printer from Printer backside which is connected to the Computer
open the top lid of the printer and check whether the carriage comes to middle or not?
It it moves automatically, then its fine.
Check the cartridges.
click the URL Link giveb below it will open a webpage. If it does not open a webpage then please copy the entire link and paste it in the address bar of the internet browser and click on "GO"
HP Deskjet 800 Series Printers - Fixing Blinking Lights
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09169&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
HP Deskjets - What are the front panel lights and buttons on the 800 series printers?
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09133&cc=us&lc=en&dlc=en&product=59305&dlc=en&lang=en
Check the End of warranty date on both the cartridges.
Deskjet 882c printer does not support reserve mode printing.
Means, even if only cartridge is defective or expired the printer will not print with other cartridge which is fine.
Both the cartridges should in inwarranty and fine.
Shake the cartridges well
With the color and black cartridges touch a clean, slightly damp cloth (squeeze out excess water),
to the printer nozzle area on the print cartridge, to see if you can make the ink flow freely.
Be careful not to touch the nozzle area (with holes on it) on the cartridges.
Wipe the copper-colored electrical contacts with a clean distilled water or clean tap water and then with a dry lint-free cotton cloth
Also using a new swab, clean the electrical contacts inside the printer, in the carriage.
Install both the cartirdges in the printer, disconnect the printer from the computer and try to print a self test and diagnostic page
Running a sample page
Turn the printer on.
Press and hold the RESUME button until the printer starts printing.
Release the RESUME button.
Running a diagnostic test
Press and hold the POWER button.
Press the RESUME button four times.
Release the POWER button.
Nov 20, 2007 | HP DeskJet 882c InkJet Printer
Microsoft Xbox 360 Console Logo
328 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
