Question about Brother MFC 9600 All-In-One Laser Printer
How do I print in color & can I download the software off the internet with the brother mfc 9600 all in one
  • 150 Answers
This printer only prints black. Down load drivers from brother.com Thank you, Steven 805-520-3003
Posted on Jul 08, 2010
My 9600 just prints pages and pages of numbers and symbols when I send anything to print
Sounds to me like you are using an incorrect printer driver, or corrupted settings. Please disconnect the printer USB or LPT cable the under control panel >>Printers , uninstall your printers. Surf to the brother website and download a new driver for your printer and Operating system version Vista / XP ect. then install the new driver software and reconnect the printer. Kind of a pain, but it will fix it. Take care
Aug 29, 2010 | Brother MFC 9600 All-In-One Laser Printer
My printer will not print in black. It will use the other colors, but not black. When I try to print a black and white document, it prints in blue.
if u want to print selected document in black than open the document select print go to printer properties select grayscale printing
always print in black
go to printer properties than go to maintenance than go to ink cartridge setting select ink cartridge black only for balck and white printing only.
OR
CHANGE CARTRIDGE
Jun 18, 2010 | Brother MFC 240C All-In-One InkJet Printer
Toubleshooting and routine maintainance is what comes oout on myscreen
Found this on the web. Click on link below to print the entire manual out to keep. Below are steps to do cleaning. If you find this helpful pls rate me. Thanks and Good Luck.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_210C_420CN_EN_286.PDF
How to improve print quality Cleaning the print head
To ensure good print quality, the MFC will regularly clean the print head. You can start the cleaning process manually if needed. Clean the print head and ink cartridges if you get a horizontal line in the text or graphics on your printed pages. You can clean Black only or three colors at a time (Cyan/Yellow/Magenta), or all four colors at once.
Cleaning the print head consumes ink. Cleaning too often uses ink unnecessarily.
Caution
Do NOT touch the print head. Touching the print head may cause permanent damage and may void the print head’s warranty.
1 Press Ink.
2 Press or to select Cleaning.
Press Menu/Set.
3 Press or to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished, the MFC will go back to standby mode automatically. If you clean the print head at least five times and the print has not improved, call Brother Customer Service (see Brother numbers on page i).
Checking the print quality
If faded or streaked colors and text appears on your output, some of the nozzles may be clogged. You can check this by printing the Print Quality Check Sheet and looking at the nozzle check pattern.
1 Press Ink.
2 Press or to select Test Print.
Press Menu/Set.
3 Press or to select Print Quality.
Press Menu/Set.
4 Press Color Start.
The MFC begins printing the Print Quality Check Sheet.
5 Check the sheet to see if the quality is OK by following these steps:
Color block quality check
The LCD shows:
6 Check the quality of the four color blocks on the sheet.
7 If all lines are clear and visible, press 1 (Yes), and go to Step 10.
OR
If you can see missing short lines as shown below, press 2 (No).
The LCD will ask you if the print quality is OK for black and three colors.
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
8 Press 2 (No) for Black or three colors
with a problem.
The LCD shows:
Press 1 (Yes). The MFC will start cleaning the print head.
9 After cleaning is finished, press Color Start. The MFC will start
printing the Print Quality Check Sheet again and then return to
step 5.
10 Press Stop/Exit.
Jan 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
Cannot print keeps saying clean printer cannot find info to do it
Caution
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
The LCD shows:
OR
OK Poor
Is Quality OK?
1.Yes 2.No
Black OK?
1.Yes 2.N
with a problem.
The LCD shows:
step 5.
10 Press Stop/Exit.
There is more, but too long to put here.
Jan 13, 2010 | Brother MFC 210C All-In-One InkJet Printer
Print is faded. I just replaced the ink jets.
You said you just replaced the ink jets. Did you clean the print heads? Here is Link on Web. If you find this helpful pls rate me. Thanks
once.
unnecessarily.
Caution
1 Press Ink.
Press Menu/Set.
Press Menu/Set.
numbers on page i).
Jan 11, 2010 | Brother MFC 210C All-In-One InkJet Printer
Laser MFC 9600 IS PRINTING BLACK LINES ON COPIES
Take out the drum and toner and slide the tab on the top right cover 15 times. Also clean the two Scanner glass windows under the cover.
Jan 06, 2010 | Brother MFC 9600 All-In-One Laser Printer
Manual
Hi - You can download the manual from the link underlined in blue below:
MFC 9600
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 28, 2008 | Brother MFC 9600 All-In-One Laser Printer
Print manager
if you go to the www.brother.com site, and look under downloads, by model number, one of the options should be to get a print management s/w package. it's a nice utility for maintenance
Jun 16, 2008 | Brother MFC620CN Home/Office Color Inkjet...
Need User Manual for Brother MFC 9600 All In One
Here's the link; http://www.amazon.com/Brother-MFC9600-Flatbed-Laser-Multifunction/dp/B00004U4A0 Under "product details". Hope this helps :)
Sep 11, 2007 | Brother MFC 9600 All-In-One Laser Printer
Brother MFC 9600 All-In-One Laser Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
