Question about Sanyo VPC-S880 Digital Camera
When i turn on my Camera the lens comes out for a moment goes back in then turns itself off. i have charged my batteries what do i do?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 08, 2010
  • Dotty775 Dec 18, 2010
    Thanks for the advice. I followed the steps in order and the best one was #7. I was getting a new camera anyways for Christmas since my camera is about 3 years old. So I thought I would try the steps since it was pretty much garbage anyways. I did #7 and I figured out if I pull the lens out lightly when pressing the on button it functions normally. I tried getting some sand or dirt out if any was in the lens part with some compressed air but was a no go.This will probably be my backup camera. thanks for the info it really helped.
2 Suggested Answers
  • 411 Answers
SOURCE: Camera shuts off immediately after turning on.
camera systems,lens unit,flash unit,mother boradetc,must be defective,so the camera get shuts off.ao take it to kodak service station
Posted on Mar 06, 2010
WB610 Camera buttons & lens aren't working as they should?
As soon as the camera is switched on, the lens barrel will come out. Everything should be ready to shoot pictures. If it is not responding to the buttons, you could try to remove the battery for a few moments. It will cause the camera, to start from scratch. Call it a cold boot. But then after switching on, it should respond normal, like you used to work with it. If it stays frozen, visit your dealer or contact a Samsung certified repair centre.
Mar 10, 2015 | Samsung WB610 Digital Camera Black
Lens won't come back
If the battery is discharged then it is likely the lens is stuck . If you can get the battery to charge and then turn on the camera it should help the lens come back. The camera will not turn on when the battery charger is connected. So you will have to wait until the battery is charged and turn on the camera only after disconnecting the charger.
Apr 28, 2014 | Nikon 26302 Coolpix S6300
Turn on camera lens comes out then goes back in and turns off
Have your camera battery been charged fully? It seems problem about battery or the lens If your battery are AA batteries please note the battery type of the battery if your camera support else If the battery is OK, there maybe something wrong with the lens
Sep 24, 2011 | Cameras
I was taking pictures, but paused for a moment to find a better angle. I guess I got distracted for a few minutes. I went back to the camera to see that the screen was black. I thought it had turned itself...
Hi. Yes, that happened to me once. Battery went dead and doesn't have enough power left to retract the lens. Camera worked fine after I put in charged battery. I hope this is your case too.
Aug 25, 2010 | Cameras
When I turn the power on, green power light comes on, lens comes out half way but then freezes and green light goes off, camera unresponsive. battery is fully charged and I have taken it out and put it...
Hi.
This is a common problem , generally indicated as lens error. The problem is often caused by dirt or dust in the lens gears.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
You can attempt tapping gently the back of the camera while turning the camera on. Sometimes this can help the lens out.
If that does not work, then the lens must be taken apart.
I summarized the problem in this article: Lens Error.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Regards.
Aug 09, 2010 | Canon IXUS 960 IS Digital Camera
Mar 06, 2010 | Kodak EasyShare V1073 Digital Camera
When you turn it on the lens goes out and right back in and turns off
Hi Dear,
This issue is because of discharged battery. The when there is not enough power supply for the camera to support it for longer time. The reserve power supply switches on your camera for a moment resulting in roll out of the camera lens. But as the camera detects that there is not enough battery available, it agains rolls in the camera lens in and then shuts down.
Hope this is one of the reasons. Please charge the battery to the fullest and then try to use it on the camera.
If the problem persist then do write to us again. We will be glad to take your problem once again.
Have a nice day.
Nov 06, 2009 | Cameras
Power keeps shutting down.
It sounds like you may have a bad lens assembly, but you did not mention if it seems to be fully extending or not. If it is sticking, it will usually buzz. If it fails to open all the way, it will turn itself back off. This sounds like what may be happening. I can fix this for $40, or you can send it to Pentax in Arizona. I don't know what they charge for a lens assembly, but the minimum charge for this camera seems to be about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Oct 05, 2008 | Pentax Optio A10 Digital Camera
Olympus FE-190
on the right side of the camera where the memory card goes in thats where it is usally loose it it does that. try not to touch the part that slides out when you take the pictures or turn it on and it will be back to normal.
Jul 08, 2008 | Olympus FE-190 Digital Camera
Sony Cyber-shot DSC-W55...
Dear Julie339
Battery of your camera has less charge storage/ got weak.
Replace with new battery and try it. Hope problem would be solved.
May 18, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sanyo VPC-S880 Digital Camera Logo
313 people viewed this question
Top Sanyo Cameras Experts
teddyboy
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
