I want as small a computer as possible - Computers & Internet
  • 88 Answers
Probably you want to have a notebook computer...
Posted on Apr 18, 2008
Where is the small pinhole located on the Dell Inspiron 531 S Model
The only small pinhole in this small form factor computer should be in the front of the c/dvd drive. You might be able to get to it by opening the spring loaded door in front of the drive. It's possible the hole might be obscured by the computers front bezel, in which case you would need to disassemble the front of the computer to get to the small pinhole.
Apr 26, 2014 | Dell Inspiron 530 Desktop Computer
Can I connect a Soundcraft Efx12 to a speaker without using an amplifier?
Yes, but it could be pointless.
Headphones are just small speakers so it is usually possible to drive a small pair of "computer/iPod" type speakers from the headphone output.
True balanced outputs should have a fair amount of drive so try connecting a speaker between pins 2 and 3. The higher the impedance of the speakers the better.
Ultimately, the results will be very quiet and the cost of a small amp or powered speakers for low level use is quite reasonable.
Apr 24, 2014 | Soundcraft Efx12 Mixer 12 Channel Mixer...
Turn signals wont work
Reboot the computer. Yes, you have possibly scrambled it as cars have multiple computers.
Aug 02, 2017 | 1995 Dodge Intrepid
I want to convert my Acer h235h Lcd in to full fledged TV..without computer So wt r the Steps for it n ya 1st of all is it possible or not? i think it is ..so?
Hi!
You are right, it is possible.
All you need is a small and inexpensive device called STANDALONE TV TUNER.
e.g. those:
http://www.compusa.com/applications/category/category_slc.asp?CatId=4641&name=Stand%20Alone
Of course you can check your local computer store for more types, but more features means more money.
Please let me know if it helped.
Aug 10, 2011 | Acer H235H Monitor
Problem with Kingston SD
If the card is intended for your digital camera then try to format it in the camera itself. DO NOT format it in the computer if it's meant for the camera. If it isn't intended to be used in a camera then you could possible attempt a format in the computer. These cards usually arrive ready formatted which makes me think there is a possile fault with the card itself. But try the format routine and see how you go. I know it's new but it is possible a small amount of grease or dirt could have accumulated on the gold connections. Rub these with a small piece of printing paper to clean them up (printer paper is very abrasive and makes a great electrical contact cleaner)
If you have no luck then a trip to where you bought it and see if you can get a replacement.
Apr 25, 2010 | Kingston 4GB Secure Digital High Capacity...
Where and how connect to a pc
I have a Sony but if you look,possibly where the AC Power adapter goes into the camera or possibly the front under a small cover, there should be a couple small holes, they are all different but look kind of like a small version of a usb insert, that the cable that came with your camera will plug into. The other end will have a USB end that will go to the computer.
Did you get a cable with the camera?
Jan 02, 2010 | Samsung SC-L750 Camcorder
I had a paper jam. I removed the paper jam already but computer says it still there. How do I reset it?
It's possible there's still a small piece of paper or dust stuck in the paper feed. Try blowing the area out with compressed air.
Aug 31, 2009 | Brother IntelliFAX 2800 Laser Fax
Cd player tray on my pc will not open
On most CD players and writers a small hole only big enough for a very small pointed object is located usually on the right side and slightly below the tray. Straighten out a paper clip and put that into the hole and press until you find some small resistence. Do not overpress but do press until you feel a small click. Generally the tray will open at that stage. Suggest you remove whatever object or media is located in the tray at the point and reboot the computer. Hopefully the tray will then operate on its own as it should but it is possibly that the drive mechanism for the tray is dead. Test before replacing the drive. The above procedure should only be done with power ' not applied ' to the unit since it may be possible to cause an electrical short on the drive using a metal paper clip.
Aug 21, 2008 | Computers & Internet
Small pictures and fonts not sharp
LCD Monitors always look best when set to there native resolution. This particular monitors native resolution is 1280x1024, also make sure your display settings are set to use the highest color quality possible.
Jan 18, 2008 | Neovo F-417 17" LCD Monitor
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
